Local Time 06:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PICO 2W - MMBASIC - Trying to read analog joystick on ADC0 and ADC1
Askjerry
Posted: 06:05pm 27 Sep 2025
I have been tinkering with this for a couple hours now... using GEMINI AI which is usually pretty good... but getting one failure after another.
In a perfect world, I would have two variables Jx and Jy, which would connect to ADC0 and ADC1, I'd read them maybe 10 times a second or so, and use the variables to do stuff.
The last attempt was...
' Define variables
DIM JX AS FLOAT
DIM JY AS FLOAT
' 1. Configure the pins as their ADC Channel
' Use the special syntax SETPIN <pin_number>, ADC<channel_number>
' GP26 is ADC Channel 0.
SETPIN 26, ADC0
' GP27 is ADC Channel 1.
SETPIN 27, ADC1
' --- Main Loop ---
DO
   ' 2. Read the analog voltage using the PIN function (Single Argument)
   ' Once configured as an ADC channel, PIN(n) should return the voltage.
   JX = PIN(26)
   JY = PIN(27)
   ' Display the values (JX and JY should be voltages from 0.0 to 3.3V)
   PRINT "JX (GP26/ADC0): "; JX; "V", "JY (GP27/ADC1): "; JY; "V"
   ' Wait for 0.1 seconds
   PAUSE 100
LOOP
Of course it's failing... anyone have any code that works?
Jerry
Posted: 08:32pm 27 Sep 2025
SETPIN GP26, AIN
SETPIN GP27, AIN
You can refer to pins by their GPxx number or physical pin number. With the proliferation of boards, it is safest to refer by GPxx
On a 'normal' pico board, pin 31 = GP26
ADC0 and ADC1 mean nothing to MMBasic. They are assumed to be a variable.
If you always use OPTION EXPLICIT, that will be evident.
Next time you are talking to Gemini, tell him/it to read the manual!
Edited 2025-09-28 07:05 by TassyJim
Askjerry
Posted: 10:37pm 27 Sep 2025
I could have sworn that I tried doing a SETPIN GP26, AIN and that I got an error... But it's working well...
SetPin GP26, AIN
SetPin GP27, AIN
Print Pin(GP26), Pin(GP27)
On the X-Axis I get 0.95 to 3.07 with 1.67 being the center, and on the Y-Axis I get 0.26 to 3.16 with 1.84 being the center.
Interesting... in Thonny I was getting a range that was much larger... about 12 bits. Probably a difference in how BASIC is reading the data.
This revision works...
' JOYSTICK EXPERIMENT - ADC0 and ADC1
' Define Pins as inputs
SetPin GP26, AIN
SetPin GP27, AIN
' Start working with the TFT Display
CLS
text 220,10," JOYSTICK READINGS: "+ FORMAT$(Pin(GP26),"%.2f") + " , " + FORMAT$(Pin(GP27),"%.2f"),CM,2,,RGB(white),RGB(blue)
Pause 0.0100
loop
end
Edited 2025-09-28 09:04 by Askjerry
Posted: 07:05am 28 Sep 2025
Using PRINT PIN(GP26) will display the voltage relative to AVREF that's on the pin. So, if you use a LM4040 3V0 on AVREF and OPTION VCC 3 then GP26 will read from 0.0 to 3.0, with the mid point at 1.5. These are all floating point numbers, of course.
By default AVREF is tied to the 3V3 supply on the Pico so the mid point will be at about half the VCC rail, normally around 1.65. The accuracy of the centre point depends on the pots on the joystick. Few are accurate and the more expensive joysticks include trimmers. You can also compensate in software, of course. :)
Askjerry
Posted: 04:26pm 28 Sep 2025
This is the joystick that is part of the breakout board.
BREAKOUT BOARD
Edited 2025-09-29 02:27 by Askjerry
Posted: 05:08pm 28 Sep 2025
I refuse to guess then. :)
That's how MMBasic reads ADC inputs anyway. You get a voltage and it's up to you what you do with it. I usually scale it so that I get 0-100% of travel by multiplying the voltage by (100/3.3). Some fiddling with the endpoint voltages that you read centres it up.
Posted: 05:42pm 28 Sep 2025
You can use SETPIN n,ARAW to get numbers in the range 0-4095 (manual page 153)
Edited 2025-09-29 03:43 by matherp
