Local Time 06:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : VL53L0X time-of-fligt distance sensor code
ville56
Posted: 03:37pm 27 Sep 2025
For whom it may be of interest ....
I've ported the VL53L0X code from C++ to MMbasic (to my best knowledge, of course). The code is able to handle multiple sensors and is also able to be loaded as library into a PicoMite under MMbasic. The code is tested on a RP2350A and doing fine so far.
In the zip-file there is a file for
- the library code (can also be included 1:1 in the main code if needed)
- a main program to test it (uses a LCD display)
- a .txt file with some documentation
Comments are welcome, there is certainly much room for improvement   and I apologise for my programming style already upfront. It' not very elegant, but it seems to work.
VL53L0X.zip
maybe someone can use it ...
Gerald
73 de OE1HGA, Gerald
Posted: 05:29pm 27 Sep 2025
Here's version for ssd1306 oled display.
OPTION EXPLICIT
OPTION DEFAULT NONE
Dim d$
Const i2caddr=&H29
I2C write i2caddr,0,2,&H89,&H1
Font 2
Pause 200
CLS
getdistance
Pause 100
Sub getdistance
I2C write i2caddr,0,2,0,1
I2C write i2caddr,1,1,&H1E
I2C read i2caddr,0,2,d$
text 0,0,(Str$(Str2bin(uint16,d$,BIG),3,0))+" mm "
Edited 2025-09-28 03:31 by stanleyella
ville56
Posted: 06:41pm 27 Sep 2025
Sure, if you do not want control over the sensor you can use the default settings and get away with this very simple code. This is one of the charming features of the VL53LX0. I'd liked to do some experiments to see what one can do with the little beast ...
Posted: 07:22pm 27 Sep 2025
Matherp wrote it converted from GBasic.
The VL53LX0 is accurate to 10 mm up to 1 M, it's more for gesture control but good for object avoiding robots.
https://www.youtube.com/watch?v=s5-5DNa36jk&t=16s
ville56
Posted: 08:51pm 27 Sep 2025
impressive !!!
Posted: 09:19pm 27 Sep 2025
I played with a pair of modules.
https://www.thebackshed.com/forum/ViewTopic.php?TID=16690&PID=217225#217225#217225
The video is no longer available.
Posted: 03:50pm 28 Sep 2025
it's a small pcb that could be hidden in a walking stick... ultrasonic is okish, use one port on/off quick and it resonates 40khz then make port input
and it gets echo back.
used to use it for object avoid robots, preferred VL53LX0 for particular application.
blind walking stick but surely someone's done that .. commercially?
glad more VL53LX0 code posted
Posted: 05:11pm 28 Sep 2025
mmb i2c is underrated.. imho
you can do loads like port expander (for 2 stepper motors), ssd oled and VL53LX0
same time easy. thanks
