Forum Index : Microcontroller and PC projects : How to change DEVICE SK2812?
Hansaplast
Posted: 10:53pm 26 Sep 2025
Hello together
Big question for the Command "DEVICE ws2812 w" command.
How to change or modify the timing as i use a different RGBW LED which have a very different T1H and T1L timing.
Is there any way?
Thanks for your help
Edited 2025-09-27 08:57 by Hansaplast
Posted: 12:37am 27 Sep 2025
Perhaps experiment with 'type' O, B ad S to see if one of them is better.
WS2812 type, pin, nbr, value%[()]
AlbertR
Posted: 11:50am 27 Sep 2025
If it is to special and nothing helps,
you can program the interface by PIO.
In the thread
Question about PIO DMA TX interupt
I post an example code for this. By using RGBWs the autopull-value should be changed to 32(0)!
Albert
