Forum Index : Microcontroller and PC projects : Touch Screen - ST7789_300 on a breakout board - PIN HELP
| Askjerry Newbie Joined: 21/09/2025 Location: United StatesPosts: 13 |
I purchased a really nice breakout board on Amazon, https://www.amazon.com/dp/B0C98G37PW The board has a 420x320 color TFT... and I have most of the options figured out now. WebMite MMBasic RP2350A Edition V6.00.03 OPTION SYSTEM SPI GP2,GP3,GP4 OPTION SYSTEM I2C GP8,GP9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 150000 OPTION LCDPANEL ST7796S, LANDSCAPE,GP6,GP7,GP5 Written on the board are the pin assignments... SCLK = GP2 CS = GP5 MOSI = GP3 DC = GP6 MISO = GP4 RST = GP7 IC2 =GP8, GP9 All the above I figured out... just two remaining... and I think they are for the touch screen... TPRST = 10 TPLNT = 11 I just want to know the correct pins to type in OPTION TOUCH I tried OPTION TOUCH GP10, GP11 then tried the GUI CALIBRATE, but not seeing any change when I put my finger on the target. I tried OPTION TOUCH GP11, GP10 and again, no reaction to touching the target. Of course after each failure... I have to clear the flash, then renter all the options again. (Not horrible, I copy from NOTEPAD++, click on TeraTerm, and Right-click to copy.) But... it's not working... any ideas??? (First post here... let's make it a head scratcher!) THANKS in advance!!! Jerry |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12058 |
It uses a GT911 i2c capacititive touch controller. This is not supported by MMBasic - sorry. |
Well Phooey I guess I won't be able to use the interactive GUI components. The breakout board has a JOYSTICK... if I can figure that out, it could be used to navigate a menu, and there are 2 buttons... I'll have to think about that. Thanks for the quick reply, Jerry |
Most Options can be individually removed with :- OPTION xxx DISABLE Leaving the rest intact. |
Ok, nice and good to know... that way I don't have to keep restoring each one. If anyone gets the same breakout board as me... this is what I have currently set... WebMite MMBasic RP2350A Edition V6.00.03 OPTION SYSTEM SPI GP2,GP3,GP4 OPTION SYSTEM I2C GP8,GP9 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CONTINUATION LINES ON OPTION CPUSPEED (KHz) 150000 OPTION LCDPANEL ST7796S, LANDSCAPE,GP6,GP7,GP5,,INVERT It all seems to be working well. This is the BREAKOUT BOARD that I got. |
