Local Time 07:22 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : python program turns image into a picomite vga picture 64x64
tenij000
Posted: 11:18am 22 Aug 2025
from PIL import Image
import os
import tkinter as tk
from tkinter import filedialog
def image_to_16_color_pixel_commands(image_path, output_filename="pixel_commands.txt", target_width=64, target_height=64):
   Reads a JPG image, resizes it to 64x64, quantizes it to a 16-color palette,
   and generates a text file with PIXEL x,y,RGB(r,g,b) commands for each pixel.
   Args:
       image_path (str): The path to the input JPG image.
       output_filename (str): The name of the output text file.
       target_width (int): The desired width for the processed image.
       target_height (int): The desired height for the processed image.
   try:
       # Open the image
       img = Image.open(image_path)
       print(f"Successfully opened image: {image_path}")
       print(f"Original image size: {img.width}x{img.height}")
       # Resize the image to the target dimensions
       # Use Image.LANCZOS for high-quality downsampling
       img = img.resize((target_width, target_height), Image.LANCZOS)
       print(f"Resized image to: {img.width}x{img.height}")
       # Convert the image to a 16-color adaptive palette
       # 'P' mode uses a palette. Using Image.Quantize.MEDIANCUT as it's a more
       # generally available method when LIBIMAGEQUANT might not be compiled in.
       quantized_img = img.quantize(colors=16, method=Image.Quantize.MEDIANCUT)
       print(f"Quantized image to 16 colors using MEDIANCUT method.")
       # Ensure the image is in RGB mode for consistent color output
       # (quantize can sometimes leave it in 'P' mode, getrgb() handles this,
       # but converting explicitly ensures we get R,G,B values for output)
       quantized_img_rgb = quantized_img.convert('RGB')
       print(f"Converted quantized image to RGB mode for pixel value extraction.")
       # Open the output file for writing
       with open(output_filename, 'w') as f:
           f.write(f"' --- Pixel data for {os.path.basename(image_path)} ({target_width}x{target_height}, 16 colors) ---\n")
           # Iterate through each pixel and write its command
           for y in range(quantized_img_rgb.height):
               for x in range(quantized_img_rgb.width):
                   r, g, b = quantized_img_rgb.getpixel((x, y))
                   f.write(f"PIXEL {x},{y},RGB({r},{g},{b})\n")
       print(f"Successfully generated pixel commands to {output_filename}")
   except FileNotFoundError:
       print(f"Error: Image file not found at {image_path}")
   except Exception as e:
       print(f"An error occurred: {e}")
def select_image_with_gui():
   Opens a file dialog to allow the user to select an image file.
   Returns the selected file path or None if no file is selected.
   root = tk.Tk()
   root.withdraw() # Hide the main window
   file_path = filedialog.askopenfilename(
       title="Select an Image File",
       filetypes=[("Image files", "*.jpg *.jpeg *.png *.bmp *.gif"), ("All files", "*.*")]
   root.destroy() # Destroy the hidden window after selection
   return file_path
# --- Example Usage ---
if __name__ == "__main__":
   print("Please select an image file using the pop-up window.")
   selected_image_path = select_image_with_gui()
   if selected_image_path:
       print(f"Selected image: {selected_image_path}")
       image_to_16_color_pixel_commands(selected_image_path)
   else:
       print("No image file selected. Exiting.")
