Local Time 07:22 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite: How to determine if audio is configured ?
Posted: 08:56am 20 Aug 2025
Hi folks,
There is a user of Z-MIM on the PicoMiteVGA reporting this error when the "bell" plays:
[650] If type% And con.SCREEN% Then Play Tone 329.63,329.63,100
Error : Audio not enabled
This is on a "reference board" without audio.
Is there a way to determine if audio is enabled/configured or do I need to ON ERROR SKIP ?
Posted: 09:12am 20 Aug 2025
mm.info(option audio)
} else if(checkstring(tp, (unsigned char *)"AUDIO")){
           if(Option.AUDIO_L)strcpy((char *)sret,"PWM");
           else if(Option.AUDIO_MISO_PIN)strcpy((char *)sret,"VS1053");
           else if(Option.AUDIO_CLK_PIN)strcpy((char *)sret,"SPI");
   else if(Option.audio_i2s_bclk)strcpy((char *)sret,"I2S");
           else strcpy((char *)sret,"NONE");
           CtoM(sret);
           targ=T_STR;
   return;
Note I2S not included in current releases - will return NONE
Edited 2025-08-20 19:16 by matherp
Posted: 09:15am 20 Aug 2025
Hi Tom,
MM.INFO(OPTION AUDIO)
returns NONE when no AUDIO
EDIT: response crosses Peters.
Edited 2025-08-20 19:16 by Volhout
Posted: 09:20am 20 Aug 2025
Super, thank you.
