Local Time 07:22 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Lemmings Sprites 13x20
vegipete
Posted: 03:14am 19 Aug 2025
I dug up the sprite sheet I found for the larger 13x20 lemmings, as used in the animation demo in this post.
Attached is the PNG sprite file, plus a short program for MMB4W to show the various animation sequences. Each sprite is 64x32 pixels, although there is a large amount of blank space, so shrinking is possible. I likely slightly hand modified/tweaked/resized the sprites used in the demo linked above.
MMB4W was used because the image is 1280 x 704 pixels, which won't easily load on any Picomite I have set up, and I didn't try on a CMM2.
LemSpriteDraw.zip
Posted: 06:37am 19 Aug 2025
Vegipete thanks,
I'll start playing with these...
They look awesome..
