Forum Index : Microcontroller and PC projects : Conway's Game of Life written by ChatGPT5 (and me) for PicoMite
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12058 |
Currently set for 80x60 but you can change CS to alter this. Run at 378MHz for best effect. ' Conway's Game of Life PicoMite + ILI9341 (320x240) ' Byte-per-cell grids + fast MEMORY SET clear + framebuffer single-blit per tick . ' Toroidal edges, diff-only drawing, sparse seeding by default. ' NOTE: PEEK/POKE/MEMORY SET BYTE must NOT have '(' right after BYTE. Option EXPLICIT Option BASE 0 Option DEFAULT INTEGER ' ---------- Display / grid ---------- Const W = MM.HRES, H = MM.VRES Const CS = 4 ' cell size (pixels Const COLS = W \ CS ' 160 Const ROWS = H \ CS ' 120 Const NPIX = ROWS * COLS ' 19,200 bytes per grid ' Colours (RGB888; firmware maps to FB palette automatically) Const COL_OFF = RGB(0,0,0) Const COL_ON = RGB(255,255,255) ' ---------- Tunables ---------- Dim delayMs% : delayMs% = 1 Dim seedPct% : seedPct% = 12 ' sparser starts; try 815 ' ---------- Tiny heap: INTEGER array as raw byte heap ---------- ' Return byte OFFSETS (0 valid). Keep absolute BASE address for MEMORY SET/PEEK/ POKE. Const HEAP_BYTES = (2 * NPIX) + 4096 Const HEAP_ELEMS = (HEAP_BYTES + 7) \ 8 Dim HEAP%(HEAP_ELEMS - 1) Dim HEAP_SIZE% : HEAP_SIZE% = HEAP_ELEMS * 8 Dim HEAP_PTR% : HEAP_PTR% = 0 Dim HEAP_BASE% : HEAP_BASE% = Peek(VARADDR HEAP%(0)) ' address of first elemen t (bytes) Function MMALLOC%(bytes%) ' 4-byte align bytes% = ((bytes% + 3) \ 4) * 4 If HEAP_PTR% + bytes% > HEAP_SIZE% Then MMALLOC% = -1 ' -1 = failure (0 is a valid first off set) Exit Function EndIf MMALLOC% = HEAP_PTR% HEAP_PTR% = HEAP_PTR% + bytes% End Function ' ---------- Current/Next byte grids ---------- Dim curOff%, nxtOff% Dim paused% : paused% = 0 ' Fast clear of a whole grid using MEMORY SET BYTE (absolute address). Sub ZERO_GRID(baseOff%) Memory SET BYTE HEAP_BASE% + baseOff%, 0, NPIX End Sub ' ---------- Framebuffer setup ---------- FRAMEBUFFER CREATE ' create FB F matched to LCD FRAMEBUFFER WRITE F ' send graphics to FB CLS COL_OFF ' ---------- Drawing (diff-only into FB) ---------- Sub DrawCell(c%, r%, isAlive%) Local x%, y% x% = c% * CS : y% = r% * CS If isAlive% Then Box x%, y%, CS, CS, 0, COL_ON, COL_ON ' x,y,w,h,[lw],[c],[fill] Else Box x%, y%, CS, CS, 0, COL_OFF, COL_OFF EndIf End Sub Sub ClearFB CLS COL_OFF End Sub ' ---------- Indexing helper ---------- Function CellIdx%(r%, c%) CellIdx% = r% * COLS + c% End Function ' ---------- Seeds / clear ---------- Sub SeedRandom(pct%) Local r%, c%, v%, ci%, baseCur% ZERO_GRID curOff% ZERO_GRID nxtOff% ClearFB baseCur% = HEAP_BASE% + curOff% For r% = 0 To ROWS - 1 For c% = 0 To COLS - 1 v% = ((Rnd * 100) < pct%) If v% Then ci% = CellIdx%(r%, c%) Poke BYTE baseCur% + ci%, 1 DrawCell c%, r%, 1 EndIf Next c% Next r% End Sub Sub ClearBoard ZERO_GRID curOff% ClearFB End Sub ' ---------- One generation (inline neighbours, absolute PEEK/POKE) ---------- Sub StepLife Local r%, c%, rm1%, rp1%, cm1%, cp1% Local baseCur%, baseNxt%, rowUab%, rowMab%, rowDab%, outRowAb% Local n%, isAlive%, newv% Static count% Memory SET BYTE HEAP_BASE% + nxtOff%, 0, NPIX ' fast clear next baseCur% = HEAP_BASE% + curOff% baseNxt% = HEAP_BASE% + nxtOff% For r% = 0 To ROWS - 1 rm1% = r% - 1 : If rm1% < 0 Then rm1% = ROWS - 1 rp1% = r% + 1 : If rp1% = ROWS Then rp1% = 0 rowUab% = baseCur% + rm1% * COLS rowMab% = baseCur% + r% * COLS rowDab% = baseCur% + rp1% * COLS outRowAb% = baseNxt% + r% * COLS For c% = 0 To COLS - 1 cm1% = c% - 1 : If cm1% < 0 Then cm1% = COLS - 1 cp1% = c% + 1 : If cp1% = COLS Then cp1% = 0 ' 8 neighbours (absolute byte reads; no parentheses after BYTE) n% = PEEK(BYTE rowUab% + cm1%) n% = n% + PEEK(BYTE rowUab% + c%) n% = n% + PEEK(BYTE rowUab% + cp1%) n% = n% + PEEK(BYTE rowMab% + cm1%) n% = n% + PEEK(BYTE rowMab% + cp1%) n% = n% + PEEK(BYTE rowDab% + cm1%) n% = n% + PEEK(BYTE rowDab% + c%) n% = n% + PEEK(BYTE rowDab% + cp1%) isAlive% = PEEK(BYTE rowMab% + c%) If isAlive% Then newv% = (n% = 2) Or (n% = 3) Else newv% = (n% = 3) EndIf If newv% Then Poke BYTE outRowAb% + c%, 1 If newv% <> isAlive% Then DrawCell c%, r%, newv% EndIf Next c% Next r% SwapBuffers Inc count% Text 0,0,Str$(count%),,,2,RGB(red) FRAMEBUFFER WAIT FRAMEBUFFER COPY F, N End Sub ' ---------- Buffer swap ---------- Sub SwapBuffers Local t% : t% = curOff% : curOff% = nxtOff% : nxtOff% = t% End Sub ' ---------- Init & main loop ---------- Randomize Timer curOff% = MMALLOC%(NPIX) : If curOff% < 0 Then Print "MMALLOC% failed for cur": End nxtOff% = MMALLOC%(NPIX) : If nxtOff% < 0 Then Print "MMALLOC% failed for nxt": End SeedRandom seedPct% FRAMEBUFFER COPY F, N ' show initial frame ' Controls: SPACE pause/resume | R random | C clear | S step (paused) | +/- spee d | Q quit Do If Not paused% Then StepLife If delayMs% > 0 Then Pause delayMs% Else Pause 10 EndIf Select Case Inkey$ Case " " : paused% = 1 - paused% Case "r","R" : SeedRandom seedPct% : FRAMEBUFFER COPY F, N Case "c","C" : ClearBoard : FRAMEBUFFER COPY F, N Case "s","S" : If paused% Then StepLife Case "+" : If delayMs% > 0 Then delayMs% = delayMs% - 1 Case "-" : delayMs% = delayMs% + 1 Case "q","Q" : Exit Do End Select Loop FRAMEBUFFER CLOSE CLS COL_OFF Print "Game of Life ended." End Edited 2025-08-16 04:05 by matherp |
Several instances of comment lines wrapping and giving syntax errors. Fixed those, and it runs with no errors but nothing appears on the lcd. Should it work with this: option list PicoMite MMBasic RP2350A Edition V6.01.00b8 OPTION SYSTEM SPI GP18,GP19,GP16 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 378000 OPTION LCDPANEL ILI9488, LANDSCAPE,GP21,GP20,GP17 PicoMite, Armmite F4, SensorKits, MMBasic Hardware, Games, etc. on FOTS |
By putting a Print in each Sub / Function to identify where it stops found:- Function MMALLOC%(bytes%) Print "Function MMALLOC%" ' 4-byte align bytes% = ((bytes% + 3) \ 4) * 4 If HEAP_PTR% + bytes% > HEAP_SIZE% Then MMALLOC% = -1 ' -1 = failure (0 is a valid first offset) Exit Function EndIf MMALLOC% = HEAP_PTR% HEAP_PTR% = HEAP_PTR% + bytes% Print "HEAP_PTR%";HEAP_PTR%, "bytes%"; bytes%, "HEAP_SIZE%";HEAP_SIZE% End Function Is as far as it gets. > RUN Function MMALLOC% HEAP_PTR% 4800 bytes% 4800 HEAP_SIZE% 13696 > So lack of memory in the RP2040 doesn't appear to be the issue. > option list PicoMite MMBasic RP2040 Edition V6.00.03 OPTION SYSTEM SPI GP18,GP19,GP20 OPTION FLASH SIZE 16777216 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 378000 OPTION DISPLAY 55, 133 OPTION LCDPANEL ILI9341, LANDSCAPE,GP15,GP14,GP13,GP16 Edit. Similar on RP2350A VGA using MODE 1 and 2 Edit 2 Corrected a few more wrapped lines, but Life is short! Edit 3 This appears to work. ' Conway's Game of Life PicoMite + ILI9341 (320x240) ' Byte-per-cell grids + fast MEMORY SET clear + framebuffer single-blit per tick. ' Toroidal edges, diff-only drawing, sparse seeding by default. ' NOTE: PEEK/POKE/MEMORY SET BYTE must NOT have '(' right after BYTE. Option EXPLICIT Option BASE 0 Option DEFAULT INTEGER ' ---------- Display / grid ---------- Const W = MM.HRES, H = MM.VRES Const CS = 4 ' cell size (pixels Const COLS = W \ CS ' 160 Const ROWS = H \ CS ' 120 Const NPIX = ROWS * COLS ' 19,200 bytes per grid ' Colours (RGB888; firmware maps to FB palette automatically) Const COL_OFF = RGB(0,0,0) Const COL_ON = RGB(255,255,255) ' ---------- Tunables ---------- Dim delayMs% = 1 Dim seedPct% = 20 ' sparser starts; try 815 ' ---------- Tiny heap: INTEGER array as raw byte heap ---------- ' Return byte OFFSETS (0 valid). Keep absolute BASE address for MEMORY SET/PEEK/POKE. Const HEAP_BYTES = (2 * NPIX) + 4096 Const HEAP_ELEMS = (HEAP_BYTES + 7) \ 8 Dim HEAP%(HEAP_ELEMS - 1) Dim HEAP_SIZE% = HEAP_ELEMS * 8 Dim HEAP_PTR% = 0 Dim HEAP_BASE% = Peek(VARADDR HEAP%(0)) ' address of first element(bytes) Function MMALLOC%(bytes%) ' 4-byte align bytes% = ((bytes% + 3) \ 4) * 4 If HEAP_PTR% + bytes% > HEAP_SIZE% Then MMALLOC% = -1 ' -1 = failure (0 is a valid first offset) Exit Function EndIf MMALLOC% = HEAP_PTR% HEAP_PTR% = HEAP_PTR% + bytes% Print "HEAP_PTR%";HEAP_PTR%, "bytes%"; bytes%, "HEAP_SIZE%";HEAP_SIZE% End Function ' ---------- Current/Next byte grids ---------- Dim curOff%, nxtOff% Dim paused% = 0 ' Fast clear of a whole grid using MEMORY SET BYTE (absolute address). Sub ZERO_GRID(baseOff%) Memory SET BYTE HEAP_BASE% + baseOff%, 0, NPIX End Sub ' ---------- Framebuffer setup ---------- FRAMEBUFFER CREATE ' create FB F matched to LCD FRAMEBUFFER WRITE F ' send graphics to FB CLS COL_OFF ' ---------- Drawing (diff-only into FB) ---------- Sub DrawCell(c%, r%, isAlive%) Local x%, y% x% = c% * CS : y% = r% * CS If isAlive% Then Box x%, y%, CS, CS, 0, COL_ON, COL_ON ' x,y,w,h,[lw],[c],[fill] Else Box x%, y%, CS, CS, 0, COL_OFF, COL_OFF EndIf End Sub Sub ClearFB CLS COL_OFF End Sub ' ---------- Indexing helper ---------- Function CellIdx%(r%, c%) CellIdx% = r% * COLS + c% End Function ' ---------- Seeds / clear ---------- Sub SeedRandom(pct%) Local r%, c%, v%, ci%, baseCur% ZERO_GRID curOff% ZERO_GRID nxtOff% ClearFB baseCur% = HEAP_BASE% + curOff% For r% = 0 To ROWS - 1 For c% = 0 To COLS - 1 v% = ((Rnd * 100) < pct%) If v% Then ci% = CellIdx%(r%, c%) Poke BYTE baseCur% + ci%, 1 DrawCell c%, r%, 1 EndIf Next c% Next r% End Sub Sub ClearBoard ZERO_GRID curOff% ClearFB End Sub ' ---------- One generation (inline neighbours, absolute PEEK/POKE) ---------- Sub StepLife Local r%, c%, rm1%, rp1%, cm1%, cp1% Local baseCur%, baseNxt%, rowUab%, rowMab%, rowDab%, outRowAb% Local n%, isAlive%, newv% Print "Sub StepLife", Static count% Memory SET BYTE HEAP_BASE% + nxtOff%, 0, NPIX ' fast clear next baseCur% = HEAP_BASE% + curOff% baseNxt% = HEAP_BASE% + nxtOff% For r% = 0 To ROWS - 1 rm1% = r% - 1 : If rm1% < 0 Then rm1% = ROWS - 1 rp1% = r% + 1 : If rp1% = ROWS Then rp1% = 0 rowUab% = baseCur% + rm1% * COLS rowMab% = baseCur% + r% * COLS rowDab% = baseCur% + rp1% * COLS outRowAb% = baseNxt% + r% * COLS For c% = 0 To COLS - 1 cm1% = c% - 1 : If cm1% < 0 Then cm1% = COLS - 1 cp1% = c% + 1 : If cp1% = COLS Then cp1% = 0 ' 8 neighbours (absolute byte reads; no parentheses after BYTE) n% = PEEK(BYTE rowUab% + cm1%) n% = n% + PEEK(BYTE rowUab% + c%) n% = n% + PEEK(BYTE rowUab% + cp1%) n% = n% + PEEK(BYTE rowMab% + cm1%) n% = n% + PEEK(BYTE rowMab% + cp1%) n% = n% + PEEK(BYTE rowDab% + cm1%) n% = n% + PEEK(BYTE rowDab% + c%) n% = n% + PEEK(BYTE rowDab% + cp1%) isAlive% = PEEK(BYTE rowMab% + c%) If isAlive% Then newv% = (n% = 2) Or (n% = 3) newv% = (n% = 3) EndIf If newv% Then Poke BYTE outRowAb% + c%, 1 If newv% <> isAlive% Then DrawCell c%, r%, newv% EndIf Next c% Next r% SwapBuffers Inc count% Text 0,0,Str$(count%),,,2,RGB(red) :Print count% FRAMEBUFFER WAIT FRAMEBUFFER COPY F, N End Sub ' ---------- Buffer swap ---------- Sub SwapBuffers 'Print "Sub SwapBuffers" Local t% : t% = curOff% : curOff% = nxtOff% : nxtOff% = t% End Sub ' ---------- Init & main loop ---------- Randomize Timer curOff% = MMALLOC%(NPIX) : If curOff% < 0 Then Print "MMALLOC% failed for cur" :End nxtOff% = MMALLOC%(NPIX) : If nxtOff% < 0 Then Print "MMALLOC% failed for nxt" :End SeedRandom seedPct% FRAMEBUFFER COPY F, N ' show initial frame ' Controls: SPACE pause/resume | R random | C clear | S step (paused) | +/- speed | Q quit Do If Not paused% Then StepLife If delayMs% > -1 Then Pause delayMs% Else Pause 10 EndIf Select Case Inkey$ Case " " : paused% = 1 - paused% Case "r","R" : SeedRandom seedPct% : FRAMEBUFFER COPY F, N Case "c","C" : ClearBoard : FRAMEBUFFER COPY F, N Case "s","S" : If paused% Then StepLife Case "+" : If delayMs% > 0 Then delayMs% = delayMs% - 1 Case "-" : delayMs% = delayMs% + 1 Case "q","Q" : Exit Do End Select Loop FRAMEBUFFER CLOSE CLS COL_OFF Print "Game of Life ended." End Add MODE 2 to the start and it runs on VGA. Very slow in MODE 1 even with OPTION RESOLUTION 640x480, 378000 Edited 2025-08-16 16:30 by phil99 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6197 |
I have to admit, if there is one thing that is good in AI, it is that we, as humans, start thinking.... a lot.... It keeps us busy.. If isAlive% Then newv% = (n% = 2) Or (n% = 3) newv% = (n% = 3) EndIf Volhout PicomiteVGA PETSCII ROBOTS |
I puzzled over that for a while and concluded when isAlive% = 1 then newv% = 1 if either n%=2 or n%=3 and newv% = 0 otherwise. if isAlive% = 0 then newv% = 1 if n%=3 and newv% = 0 otherwise. Edit There is meant to be an ELSE between the lines. My copy / paste error. If isAlive% Then newv% = (n% = 2) Or (n% = 3) Else newv% = (n% = 3) EndIf Edit 2 Yep, that's how it works. > n%=0 :newv% = (n% = 2) Or (n% = 3) : ?newv% 0 > n%=4 :newv% = (n% = 2) Or (n% = 3) : ?newv% 0 > n%=3 :newv% = (n% = 2) Or (n% = 3) : ?newv% 1 > n%=2 :newv% = (n% = 2) Or (n% = 3) : ?newv% 1 > n%=1 :newv% = (n% = 2) Or (n% = 3) : ?newv% 0 > Edited 2025-08-16 17:09 by phil99 |
Sorry: forgot to set OPTION DISPLAY before I did the listing. Corrected version attached. If you want to stop the game ending in a fixed loop add a tiny bit of randomness If isAlive% Then newv% = (n% = 2) Or (n% = 3) Else newv% = (n% = 3) EndIf If Rnd<0.001 Then newv% = Not newv% 'add random element ' Conway's Game of Life PicoMite + ILI9341 (320x240) ' Byte-per-cell grids + fast MEMORY SET clear + framebuffer single-blit per tick. ' Toroidal edges, diff-only drawing, sparse seeding by default. ' NOTE: PEEK/POKE/MEMORY SET BYTE must NOT have '(' right after BYTE. Option EXPLICIT Option BASE 0 Option DEFAULT INTEGER ' ---------- Display / grid ---------- Const W = MM.HRES, H = MM.VRES Const CS = 4 ' cell size (pixels Const COLS = W \ CS ' 160 Const ROWS = H \ CS ' 120 Const NPIX = ROWS * COLS ' 19,200 bytes per grid ' Colours (RGB888; firmware maps to FB palette automatically) Const COL_OFF = RGB(0,0,0) Const COL_ON = RGB(255,255,255) ' ---------- Tunables ---------- Dim delayMs% : delayMs% = 1 Dim seedPct% : seedPct% = 12 ' sparser starts; try 815 ' ---------- Tiny heap: INTEGER array as raw byte heap ---------- ' Return byte OFFSETS (0 valid). Keep absolute BASE address for MEMORY SET/PEEK/POKE. Const HEAP_BYTES = (2 * NPIX) + 4096 Const HEAP_ELEMS = (HEAP_BYTES + 7) \ 8 Dim HEAP%(HEAP_ELEMS - 1) Dim HEAP_SIZE% : HEAP_SIZE% = HEAP_ELEMS * 8 Dim HEAP_PTR% : HEAP_PTR% = 0 Dim HEAP_BASE% : HEAP_BASE% = Peek(VARADDR HEAP%(0)) ' address of first element(bytes) Function MMALLOC%(bytes%) ' 4-byte align bytes% = ((bytes% + 3) \ 4) * 4 If HEAP_PTR% + bytes% > HEAP_SIZE% Then MMALLOC% = -1 ' -1 = failure (0 is a valid first offSet ) Exit Function EndIf MMALLOC% = HEAP_PTR% HEAP_PTR% = HEAP_PTR% + bytes% End Function ' ---------- Current/Next byte grids ---------- Dim curOff%, nxtOff% Dim paused% : paused% = 0 ' Fast clear of a whole grid using MEMORY SET BYTE (absolute address). Sub ZERO_GRID(baseOff%) Memory SET BYTE HEAP_BASE% + baseOff%, 0, NPIX End Sub ' ---------- Framebuffer setup ---------- FRAMEBUFFER CREATE ' create FB F matched to LCD FRAMEBUFFER WRITE F ' send graphics to FB CLS COL_OFF ' ---------- Drawing (diff-only into FB) ---------- Sub DrawCell(c%, r%, isAlive%) Local x%, y% x% = c% * CS : y% = r% * CS If isAlive% Then Box x%, y%, CS, CS, 0, COL_ON, COL_ON ' x,y,w,h,[lw],[c],[fill] Else Box x%, y%, CS, CS, 0, COL_OFF, COL_OFF EndIf End Sub Sub ClearFB CLS COL_OFF End Sub ' ---------- Indexing helper ---------- Function CellIdx%(r%, c%) CellIdx% = r% * COLS + c% End Function ' ---------- Seeds / clear ---------- Sub SeedRandom(pct%) Local r%, c%, v%, ci%, baseCur% ZERO_GRID curOff% ZERO_GRID nxtOff% ClearFB baseCur% = HEAP_BASE% + curOff% For r% = 0 To ROWS - 1 For c% = 0 To COLS - 1 v% = ((Rnd * 100) < pct%) If v% Then ci% = CellIdx%(r%, c%) Poke BYTE baseCur% + ci%, 1 DrawCell c%, r%, 1 EndIf Next c% Next r% End Sub Sub ClearBoard ZERO_GRID curOff% ClearFB End Sub ' ---------- One generation (inline neighbours, absolute PEEK/POKE) ---------- Sub StepLife Local r%, c%, rm1%, rp1%, cm1%, cp1% Local baseCur%, baseNxt%, rowUab%, rowMab%, rowDab%, outRowAb% Local n%, isAlive%, newv% Static count% Memory SET BYTE HEAP_BASE% + nxtOff%, 0, NPIX ' fast clear next baseCur% = HEAP_BASE% + curOff% baseNxt% = HEAP_BASE% + nxtOff% For r% = 0 To ROWS - 1 rm1% = r% - 1 : If rm1% < 0 Then rm1% = ROWS - 1 rp1% = r% + 1 : If rp1% = ROWS Then rp1% = 0 rowUab% = baseCur% + rm1% * COLS rowMab% = baseCur% + r% * COLS rowDab% = baseCur% + rp1% * COLS outRowAb% = baseNxt% + r% * COLS For c% = 0 To COLS - 1 cm1% = c% - 1 : If cm1% < 0 Then cm1% = COLS - 1 cp1% = c% + 1 : If cp1% = COLS Then cp1% = 0 ' 8 neighbours (absolute byte reads; no parentheses after BYTE) n% = PEEK(BYTE rowUab% + cm1%) n% = n% + PEEK(BYTE rowUab% + c%) n% = n% + PEEK(BYTE rowUab% + cp1%) n% = n% + PEEK(BYTE rowMab% + cm1%) n% = n% + PEEK(BYTE rowMab% + cp1%) n% = n% + PEEK(BYTE rowDab% + cm1%) n% = n% + PEEK(BYTE rowDab% + c%) n% = n% + PEEK(BYTE rowDab% + cp1%) isAlive% = PEEK(BYTE rowMab% + c%) If isAlive% Then newv% = (n% = 2) Or (n% = 3) Else newv% = (n% = 3) EndIf If newv% Then Poke BYTE outRowAb% + c%, 1 If newv% <> isAlive% Then DrawCell c%, r%, newv% EndIf Next c% Next r% SwapBuffers Inc count% Text 0,0,Str$(count%),,,2,RGB(red) FRAMEBUFFER WAIT FRAMEBUFFER COPY F, N End Sub ' ---------- Buffer swap ---------- Sub SwapBuffers Local t% : t% = curOff% : curOff% = nxtOff% : nxtOff% = t% End Sub ' ---------- Init & main loop ---------- Randomize Timer curOff% = MMALLOC%(NPIX) : If curOff% < 0 Then Print "MMALLOC% failed for cur":End nxtOff% = MMALLOC%(NPIX) : If nxtOff% < 0 Then Print "MMALLOC% failed for nxt":End SeedRandom seedPct% FRAMEBUFFER COPY F, N ' show initial frame ' Controls: SPACE pause/resume | R random | C clear | S step (paused) | +/- speed | Q quit Do If Not paused% Then StepLife If delayMs% > 0 Then Pause delayMs% Else Pause 10 EndIf Select Case Inkey$ Case " " : paused% = 1 - paused% Case "r","R" : SeedRandom seedPct% : FRAMEBUFFER COPY F, N Case "c","C" : ClearBoard : FRAMEBUFFER COPY F, N Case "s","S" : If paused% Then StepLife Case "+" : If delayMs% > 0 Then delayMs% = delayMs% - 1 Case "-" : delayMs% = delayMs% + 1 Case "q","Q" : Exit Do End Select Loop FRAMEBUFFER CLOSE CLS COL_OFF Print "Game of Life ended." End Edited 2025-08-16 17:39 by matherp |
Thanks for that. I noticed it eventually settles into an almost static state with just a few cells flipping back and forth. Edit. Adding Peter's extra line improves the lifespan of Life. If Rnd<0.001 Then newv% = Not newv% 'add random element On a Pico 1 LCD it is about 8700 iterations and a Pico 2 VGA 12600 and still evolving. Edited 2025-08-16 22:15 by phil99 |
