Local Time 07:31 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using a pico to create Hdmi for the Cmm2.
Plasmamac
Posted: 02:45pm 07 Aug 2025
Hi ,
Is it possible to create a compagnion device for Hdmi output from cmm2?
Maybe a dumb idea but i like to hear some ideas from you. I know where a some vga2hdmi adapters but .
Just for interrest
Gtx
Plasma
Plasmamac
Posted: 02:53pm 07 Aug 2025
Option Hdmi on
- creates a Dma(?) driver which sends the video buffer to a pico . The pico can produce Hdmi in the same way as picomite.
Plasma
Posted: 03:08pm 07 Aug 2025
When did that appear? How is the PicoMite connected to the CMM2?
Plasmamac
Posted: 03:11pm 07 Aug 2025
Its just a idea , connecting to pico with the best , fastest way
Plasma
Posted: 03:40pm 07 Aug 2025
Ah. Still won't work at much speed though. No matter how you shift the data to the Pico it still isn't as fast as the hardware HSTX module. Also, the Pico runs appreciably slower than the CMM2 and has a lot less RAM so you have an instant bottleneck.
The ARMmite is probably closer to driving HDMI as it has a hardware display port. I doubt if even that would be fast enough for HDMI though.
Of course, a VGA+audio to HDMI converter is less than three quid from Aliexpress...
Edited 2025-08-08 02:04 by Mixtel90
Posted: 05:03pm 07 Aug 2025
There are plenty of commercial VGA->HDMI converters that work with CMM2.
