Local Time 06:55 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : CAN-bus with picomite/webmite and MCP2515, proof of concept
Arne
Posted: 01:24pm 04 Aug 2025
As I had no idea about CAN-bus I decided to make an absolute minimum test-program for the MCP2515 module to learn something about it. 3 picos (2xRP2350 and 1xRP2350W) with MCP2515 modules have been connected together to one CAN-bus line with a length of about 2 meters. For the test all picos used the same program. Each pico sent one data frame every second with increasing ID. Receiving of frames were initiated by the MCP2515 controller via interrupt line to the relevant pico.
Additional features of the MCP2515 as e.g.
- extended data and remote frames
- data filtering
- etc…
have not been taken into account.
The following test-program is based on my evaluations of the MCP2515 data sheet.
Due no failure handling is implemented it can be possible that the data transfer via the bus suddenly stops e.g. when the same IDs were sent by different nodes at the same time. The controller then initiates a failure and waits for instructions how to go on…
CAN.zip
After my tests here the conclusion:
Implementing a CAN-bus driver as e.g. for the MCP2515 into the picomite (firmware) can be a big benefit because interfacing to several industrial systems/sensors/actuators can be done. Also distributed systems with several picomites for home automation, robotics etc. can easily be designed.
In addition:
- It is a robust industrial standard field bus
- Can have a maximum length of about 5 Km with minimum cabling (2 or 3 wires)
- Depend on bus length/drivers it can handle up to 100 nodes.
- In standard operation 2048 frames with 8 byte data can be transferred.
- Extended and remote frames are possible
Maybe the a.m. infos are interesting …
@Peter: What are you thinking about implementing a CAN-bus driver as e.g. for the MCP2515 into the picomite firmware? For hobby programmers (as me) this can make life much easier (and the code more compact).
Arne
PhenixRising
Posted: 02:00pm 04 Aug 2025
For hobby (non-commercial) purposes, I would be tempted to couple the PicoMite with the ANNEX32 as it supports lots of stuff such as CAN, ModBus, Ethernet, Bluetooth, WiFi, etc.
Could be a great companion as it has a similar, civilized programming syntax.
Edited 2025-08-05 00:01 by PhenixRising
Posted: 04:41pm 04 Aug 2025
Personally, I'd argue against building it in. It would take up space that's better used for stuff that more people would probably use. However, I see no reason why suitable MMBasic routines shouldn't be on FotS, ready for using in a Library.
MMBasic already has CRC error checking implemented, which can be used over any wired or wireless system.
Edited 2025-08-05 02:42 by Mixtel90
Posted: 08:17pm 04 Aug 2025
Hi Arne,
Thank you for creating this example code. It is obvious not finished, but shows how to do it. Very useful. Thanks.
disco4now
Posted: 10:58pm 04 Aug 2025
This thread on FotS has an MMBasic driver for the MCP2515. It uses polling instead of interrupts. It still needs a tidy/clean up as it was initially a control for a power supply but does support filters. It originally was used on Micromite and Armmite F4 so needs changes to SPI OPEN/CLOSE for Picomites.
MMBasic Driver For MCP2515 SPI CAN Adaptor
Edited 2025-08-05 09:20 by disco4now
F4 H7FotSF4xGT
Posted: 06:53pm 05 Aug 2025
Hi Gerry,
Looks like you recently made some changes to the driver (5-8-2025).
Any changes for compatibility to PicoMite ? Or is it just an update to the FOTS page ?
What is the original application you made this for ? A service tool ? (there is a display, a rotary encoder).
disco4now
Posted: 10:42pm 05 Aug 2025
Hi Harm,
Update yesterday was just a fix for the single to double precision function.
The code was initially the start of an application to control one of these CAN based 48V power supplies, to make a battery charger. These are quiet a few different types, probably from de-commission  telephone exchanges.
EMERSON 48V Power supply
I started on a Micromite, then to ARMMITE F4. I then got side tracked adding CAN support to ARMMites (they have inbuilt CAN controller),the plan was to document the driver for the MCP2515 by cleaning the up application but not quite finished yet.
This site has info of these type of deviices
Many use them to charge electric bikes.
Gerry
F4 H7FotSF4xGT
Arne
Posted: 05:25am 06 Aug 2025
Thanks for all the feedback!
I only wanted to learn what is CAN-bus and what can I do with it. So I took one of the mostly and cheapest CAN-modules used to make some practical experiences.
As a result I saw the amazing possibilities you could have if an easy to use driver would be available.
Background:
I use the picomite with monitor/keyboard as a cheap stand alone programmable and easy to use system. MMBasic is a great piece of software. Mainly everything you need (for easy programming) is part of it. For me it’s like a swiss army knife for easy programming and fast prototyping. I understand that the hardware is limited and therefore new functionalities/drivers have to be selected very carefully. It is always a decision for what the hardware/firmware/software shall be used and what benefit does a new functionality brings.
But here maybe provokant questions:
How many times the 3D engine of picomite is/was used?
How many resources does it need?
I myself see it more as a demo to show what is possible…
In my opinion to implement an easy to use CAN-bus driver into the firmware can bring MMBasic and picomite a big step forward. It will open the door to a worldwide standard and raise the acceptance to use it.
Anyway, imagine the possibilities you could have as e.g.:
- distributed systems with hundreds of sensors/actuators
- Interfacing to CAN-conform systems/sensors/actuators
- Data exchange between several picomites (arduinos,ESP‘s,Raspis,PCs…)
- Different separate systems on one CAN-bus
- Easy expandability and long range data transfer
And all that with a 3-wire cable and a cheap adapter for less than 2 Euros!
Now I know why the Industrie is using it for automation,production,cars etc.
Arne
circuit
Posted: 07:15am 06 Aug 2025
Geoff did some work on this in the early days; The "Special Version of V4.5 with support for CAN (Controller Area Network)" is still available on his website.  (See 'Original Colour Maximite' - bottom of the page.
I must agree that Arne's argument for bringing this concept into the current 2040/2350 firmware is very compelling.  I would certainly be very enthusiastic about this for embedded controller applications. Perhaps it might be considered in the next version of the 2350 firmware, currently under Peter's authorship.
Edited 2025-08-06 17:20 by circuit
disco4now
Posted: 07:46am 06 Aug 2025
The original Maximite and the current ARMmite F4 and ARMmite H7 have a CAN controller built into the chip.The latest ARMMite F4 and next (soon) ARMmite H7 now have CAN support build into MMBasic. The Micromite and Picomite chips don't have a CAN controller build into the chip so you would need to access one externally using SPI.
F4 H7FotSF4xGT
PhenixRising
Posted: 10:02am 06 Aug 2025
  Quote  The MCP2515 and MCP2517 are both standalone CAN controllers from Microchip that allow a microcontroller to communicate over a CAN bus using an SPI interface. The main difference is that the MCP2517 is a newer, more advanced version that supports CAN Flexible Data-Rate (CAN FD), while the MCP2515 only supports the older, classic CAN 2.0B protocol.
Key Differences
CAN Protocol Support: This is the most significant difference.
MCP2515: Supports only CAN 2.0B, which has a maximum data rate of 1 Mbps and a data payload of up to 8 bytes.
MCP2517: Supports both CAN 2.0B and the newer, faster CAN FD protocol. CAN FD increases the data payload up to 64 bytes and offers a higher data phase bit rate, up to 8 Mbps.  This makes the MCP2517 much more suitable for modern automotive and industrial applications that require higher throughput and more data per message.
Message Buffers and FIFOs:
MCP2515: Features a limited number of transmit and receive buffers (three transmit and two receive).
MCP2517: Has a more flexible and robust system with 31 FIFOs that can be configured as either transmit or receive queues, along with a transmit queue. This allows for more efficient handling of high-volume message traffic.
SPI Clock Speed: The MCP2517 supports a faster SPI clock speed, up to 20 MHz, compared to the MCP2515's 10 MHz. This faster interface is necessary to handle the increased data rates of CAN FD.
Features and Functionality:
MCP2517 includes additional features for enhanced safety and reliability, such as built-in CRC checks for SPI commands to detect noise and ECC (Error Correcting Code) for its internal SRAM. It also has a 32-bit time stamp for precision logging and bus health diagnostics. The MCP2515 has a more basic feature set.
In short, the MCP2517 is an evolution of the MCP2515, providing support for the modern CAN FD standard, higher performance, and a more feature-rich, reliable architecture.
Posted: 10:25am 06 Aug 2025
Remember that CAN isn't a lightweight system. If you are trying to feed it over SPI can the Pico even do it? 5MHz, yes, but how much is your program slowed down if you go higher? Do you need more buffers than the Pico's RAM can handle?
Posted: 11:45am 06 Aug 2025
An Armmite looks a better idea.
mozzie
Posted: 04:18pm 07 Aug 2025
G'day Arne,
As you suggest, CAN is a great way of networking multiple controllers if data reliability is important, many years building heavy vehicle control systems has proven to me just how robust it is, even when abused
Thanks for the demo code, I agree that having it built in to the firmware would be great but a few subroutines in the library can also work well depending on what the application would be.
Also keep in mind it is not great for battery powered applications, the idle current of the drivers and MCP2515 is fairly high, shutdown modes do help.
@Mixtel,
Thankfully the MCP2515 isolates most of the "heavy lifting" from the micro-controller so the 5mhz SPI speed is normally overkill. Considering a CAN speed of 250kbps and the overheads, the maximum message speed is approx 2200 messages/sec and these can be filtered / buffered in the MCP2515 to only those required. I have tested MicroMites on 250kbps systems in the past with no problems.
Lyle.
Edited 2025-08-08 02:21 by mozzie
Zonker
Posted: 09:55pm 07 Aug 2025
Good evening Gents..
Two boards for the Pico that have CAN interface using the MCP2515 IC..
https://www.waveshare.com/catalogsearch/result/?q=Pico+CAN+B
https://www.longan-labs.cc/1030018.html
I have both of these but just haven't had the time to get started yet...
Thanks for this thread and help with this subject...
PhenixRising
Posted: 10:01pm 07 Aug 2025
MCP2517 not the MCP2515
Just sayin
PhenixRising
Posted: 12:32pm 08 Aug 2025
For giggles, I asked ChatGPT for a translation of the Python sample code for the Waveshare product:
' Configuration Registers
CANSTAT      = &H0E
CANCTRL      = &H0F
BFPCTRL      = &H0C
TEC          = &H1C
REC          = &H1D
CNF3         = &H28
CNF2         = &H29
CNF1         = &H2A
CANINTE      = &H2B
CANINTF      = &H2C
EFLG         = &H2D
TXRTSCTRL    = &H0D
' Transmit Buffer 0
TXB0CTRL     = &H30
TXB0SIDH     = &H31
TXB0SIDL     = &H32
TXB0EID8     = &H33
TXB0EID0     = &H34
TXB0DLC      = &H35
TXB0D0       = &H36
TXB0D1       = &H37
TXB0D2       = &H38
TXB0D3       = &H39
TXB0D4       = &H3A
TXB0D5       = &H3B
TXB0D6       = &H3C
TXB0D7       = &H3D
' SPI Commands
CAN_RESET    = &HC0
CAN_READ     = &H03
CAN_WRITE    = &H02
CAN_RTS      = &H80
CAN_RTS_TXB0 = &H81
' Initialize SPI
SCK_PIN = 6 ' Set your SCK pin
MOSI_PIN = 7 ' Set your MOSI pin
MISO_PIN = 4 ' Set your MISO pin
CS_PIN = 1 ' Set your CS pin
SPI_Init(SCK_PIN, MOSI_PIN, MISO_PIN, CS_PIN)
' Function to read a byte from the CAN controller
FUNC ReadByte(addr)
   CS_PIN = 0
   SPI_Write CAN_READ
   SPI_Write addr
   res = SPI_Read()
   CS_PIN = 1
   RETURN res
END FUNC
' Function to write a byte to the CAN controller
FUNC WriteByte(addr, data)
   CS_PIN = 0
   SPI_Write addr
   SPI_Write data
   CS_PIN = 1
END FUNC
' Function to reset the CAN controller
FUNC Reset()
   CS_PIN = 0
   SPI_Write CAN_RESET
   CS_PIN = 1
END FUNC
' Function to initialize the CAN controller
FUNC Init(speed)
   PRINT "Reset"
   Reset()
   PAUSE 100
   ' Set baud rate
   WriteByte(CNF1, 0x03) ' Example for 125Kbps
   WriteByte(CNF2, 0xB8)
   WriteByte(CNF3, 0x03)
   ' Set TXB0
   WriteByte(TXB0SIDH, 0xFF)
   WriteByte(TXB0SIDL, 0xE0)
   WriteByte(TXB0DLC, 0x40 OR 0x08) ' DLC = 8
   ' Set RXB0
   WriteByte(RXB0SIDH, 0x00)
   WriteByte(RXB0SIDL, 0x60)
   WriteByte(RXB0CTRL, 0x60)
   WriteByte(RXB0DLC, 0x08)
   ' Enable interrupts
   WriteByte(CANINTE, 0x01)
END FUNC
' Function to send data
FUNC Send(CAN_ID, CAN_TX_Buf, length)
   WriteByte(TXB0SIDH, (CAN_ID >> 3) AND &HFF)
   WriteByte(TXB0SIDL, (CAN_ID AND &H07) << 5)
   WriteByte(TXB0DLC, length)
   FOR j = 0 TO length - 1
       WriteByte(TXB0D0 + j, CAN_TX_Buf(j))
   NEXT j
   WriteByte(CAN_RTS_TXB0)
END FUNC
' Function to receive data
FUNC Receive(CAN_ID)
   WriteByte(RXB0SIDH, (CAN_ID >> 3) AND &HFF)
   WriteByte(RXB0SIDL, (CAN_ID AND &H07) << 5)
   CAN_RX_Buf = []
   WHILE TRUE
       IF (ReadByte(CANINTF) AND &H01) THEN
           len = ReadByte(RXB0DLC)
           FOR i = 0 TO len - 1
               CAN_RX_Buf[i] = ReadByte(RXB0D0 + i)
           NEXT i
           ' Clear the interrupt flag
           WriteByte(CANINTF, 0)
           RETURN CAN_RX_Buf
       ENDIF
   WEND
END FUNC
' Main program
PRINT "--------------------------------------------------------"
PRINT "Initializing CAN..."
Init("125KBPS")
PRINT "Sending data..."
id = &H123 ' Example CAN ID
data = [1, 2, 3, 4, 5, 6, 7, 8] ' Example data
dlc = 8
Send(id, data, dlc)
' Loop to receive data
WHILE TRUE
   readbuf = Receive(id)
   PRINT "Received Data: "; readbuf
   PAUSE 500
WEND
Was supposed to be MMBasic but it isn't quite right.
Zonker
Posted: 09:07am 11 Aug 2025
Interesting...
I have never played with ChatGPT, How did you converse with it..??
Did you give it a copy of the MMbasic manual and MCP2515 PDF files..?
Just.. Awesome..!!
PhenixRising
Posted: 10:06am 11 Aug 2025
I tried copy/pasting the python code but it was too much so I described the product and stated that there was python code that I'd like translated to Micro mite Basic.
After this, I tried Phind.com because it is claimed to be better for coding.
Here I could paste and the generated code was closer to Micromite.
Still had "FUNC" instead of "FUNCTION" but other than that, pretty close.
Phind gives me errors like it's not working but it eventually does work.
Arne
Posted: 10:45am 10 Sep 2025
Now the demo „CAN_FILTER.BAS“ with filter function and error evaluation example.
CAN.zip
Due I have no SD-Card connected to the test picos I made two small tools to transfer test-files over the can bus. With „CAN_TRANSMIT.BAS“ you can send (if there is no other traffic on the bus) a file and receive it  in parallel on all connected picos where „CAN_RECEIVE.BAS“ is started.The file will be stored in „RECEIVED.BAS“.
During my tests I found out that the picos, depend on CPU-speed/HDMI/VGA etc. , when there is high traffic on the bus miss interrupts. Because of this behavior the relevant picos do not read out the receive buffer of the relevant module and it stucks in failure condition.
Is it possible with MMBasic to give a single I/O pin used for interrupts a higher priority? Maybe in the future?
Otherwise the bus speed must be reduced or additional data mirroring may be implemented into the relevant basic program to assure that the sent data was received correctly.
Have fun
Arne
