Local Time 08:10 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMBasic bit operator's.... and two's compliment
DigitalDreams
Posted: 02:41pm 22 Jul 2025
Trying to invert an 8-bit binary number and display the result.
Dim as integer a
A=57
Print bin$(a,8)
Working as expected.... Now add
A=inv(a)
Print bin$(a,8)
Works as expected (inverting all bits) YET Displays ALL 64 bits not the low 8 !?!?
On the subject, do we have any commands to handle (convert, display) 8-bit two's compliment binary numbers or do we have to manually manipulate ?. Yes I'm trying to read and write two's compliment binary numbers on the i2c bus.
Edited 2025-07-23 00:55 by DigitalDreams
twofingers
Posted: 04:10pm 22 Jul 2025
  DigitalDreams said  Trying to invert an 8-bit binary number and display the result.
Dim as integer a
A=57
Print bin$(a,8)
A=inv(a)
Print bin$(a,8)
do you mean something like that?
a=INV(57) And 2^8-1
Michael
Posted: 04:22pm 22 Jul 2025
  Quote  Yes I'm trying to read and write two's compliment binary numbers on the i2c bus.
BIN2STR$
PhenixRising
Posted: 04:44pm 22 Jul 2025
BIN2STR$
I love these functions
Edited 2025-07-23 02:45 by PhenixRising
DigitalDreams
Posted: 04:59pm 22 Jul 2025
BIN2STR$
Not entirely useful. I take it the i2c commands strip higher bits from 64 bit integers and only deal with the low 8 ?
Posted: 05:19pm 22 Jul 2025
Very likely. AFAIK the I2C system in MMBasic is strictly byte-orientated. If you wanted to send anything longer you would have to split into bytes first. You could send four elements of an array to send a 64-bit integer that way.
Posted: 05:44pm 22 Jul 2025
BIN2STR$ and STR2BIN are specifically designed for things like I2C communication
Suppose you want to send a 16-bit signed integer to a I2C device
a$=bin2str$(int16,myint)
i2c send addr%,0,2,a$
If it wants the bytes the other way round
a$=bin2str$(int16,myint,BIG)
Same when receiving from i2c - just use str2bin
I wrote these functions specifically to make I2C comms to all sorts of devices easy.
Posted: 06:03pm 22 Jul 2025
Ah, so the I2C data is still sent as bytes, but as string characters rather than as elements of a single-dimensional array.  :)
DigitalDreams
Posted: 06:52pm 22 Jul 2025
  matherp said  BIN2STR$ and STR2BIN are specifically designed for things like I2C communication
Ah, I see !. Thanks for clarifying Peter....
