Local Time 08:10 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Waveshare Pico LCD 1.8" 160x128 ST7735 Extra Line of Garbage
jwettroth
Posted: 02:49am 22 Jul 2025
I added a Waveshare Pico LCD 1.8" LCD to my last Amazon order ($13.50) out of boredom.  It lets you plug in a Pico (1 or 2) into the back to make sort of a "backpack", though it uses tall headers so it has 1/4" gap.  Once I get it working, I'll rework it to make it thinner.
Format its a 160 x 128 TFT ala ST7735 (though they call it an 7735s which is 80x128)
Pins connected-
GP8    DATA/NOT COMMAND
GP9    NOT CS
GP10   SPI CLK
GP11   SPI DATA IN
GP12   NOT RESET
GP13   BACKLIGHT
note there is no SPI data out.
I configured as follows with latest firmware (6.0.03) on a PICO 2
OPTION SYSTEM SPI GP10,GP11,GP22   'HAD TO CONFIGURE A MISO EVEN THOUGH NOT USED?
OPTION LCD PANEL ST7735,P,GP8,GP22,GP9,GP13
I got console errors if I tried to leave off the MISO (GP12 Nominally) input in the SYSTEM command so just used an open GPIO.
I couldn't use GP12 for /rst, so reused GP22 as not to burn another pin- no complaints.  I got an error that GP12 can't be used...
It is "sort of" working- I can run GUI test lcd panel, BUT at the far edge of the display (max x), I get a line of garbage that is not addressable.
In reading more about this display, its says that the display starts at 2nd pixel in H and First in V.  Is there a way I can tweak this offset somehow without having to write a new display driver, etc.
Any help appreciated.
Edited 2025-07-22 12:51 by jwettroth
John Wettroth
Doktorn
Posted: 01:27pm 22 Jul 2025
I had a similar issue with the Waveshare Pico-LCD-1.8
Try
POKE Display HRES 161
POKE Display VRES 130
/Lasse
Posted: 01:56pm 22 Jul 2025
These are pretty horrible. A lot of the GP pins are unused but there's no access to them. Goodness knows what they were thinking.
jwettroth
Posted: 02:41pm 22 Jul 2025
Thanks all, I may just send it back.  I was sort of bored and sent myself a gift.  Pretty dumb design overall.  Lots of GPIO pins and the goofy mechanical design.
Thanks for the help learned something anyway.
John Wettroth
Posted: 03:09pm 22 Jul 2025
I designed a couple of little backpacks for it a while ago, so it is possible to do things with them. I never actually made either of these. :)
jwettroth
Doktorn- your fix tweaking the HRES and VRES worked perfectly- thanks again.
Wave share is so prolific with boards!  I went to their site and I'm amazed with the volume.  I hope most are better thought out than this one.  I think I'll just build a little one off gadget maybe.  Beware if you buy this stuff.  With JLPCB etc and KiCad, Waveshare's value added is hard to determine.  Perhaps if I only need one or two but if need any more, I can put in a little effort and get something better with solid documentation (my own).
I notice that they support Micropython, C Arduino and the PICO SDK but no mention of MMBASIC.  It seems that MMBASIC is a pretty legitimate option for the Pico.  Perhaps the PICOcalc with its default use of MMBasic will spread the news more.
John Wettroth
Posted: 03:14pm 22 Jul 2025
*Nothing* supports MMBasic officially apart from what you find in this forum.  :(  Probably because Raspberry Pi don't recognise MMBasic as one of the official languages for anything.
jwettroth
Posted: 03:16pm 22 Jul 2025
Nice job Mixtel!  I really like the second one with extra I/O, RTC and data converters.  Nice work.  An amazing group here.
John Wettroth
