Local Time 08:10 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : how do fill backtround whit yellow color keep the gui elements
tenij000
Posted: 09:37am 21 Jul 2025
how do i fill the background in yellow color keep the gui elements
GUI SETUP 1
GUI BUTTON     #25, "CALC",  160, 60, 60, 30, RGB(0,0,0), RGB(0,255,0)
Font 3
GUI SETUP 2
' === Hoofdvelden ===
GUI TEXTBOX    #1,  10,  10, 300, 30, RGB(white), RGB(gray) ' Invoerveld
GUI BUTTON     #2, "DEL", 260, 50, 50, 30, RGB(255,255,255), RGB(255,0,0) ' Verwijder laatste teken
GUI DISPLAYBOX #3, 10, 50, 240, 30, RGB(white), RGB(gray)    ' Resultaat
GUI BUTTON     #4, "=", 205, 195, 60, 30, RGB(0,0,0), RGB(0,255,0)
' === Knoppenrijen (cijfers en operatoren) ===
chars$ = "789/456*123-0.+"
id = 10
x0 = 10 : y0 = 90
w = 60 : h = 30 : m = 5
For i = 1 To Len(chars$)
 cx = ((i - 1) Mod 4)
 cy = Int((i - 1) / 4)
 x = x0 + cx * (w + m)
 y = y0 + cy * (h + m)
 teken$ = Mid$(chars$, i, 1)
 GUI BUTTON #id, teken$, x, y, w, h, RGB(white), RGB(200,200,200)
 id = id + 1
Next
' === Eigen REPLACE functie ===
Function REPLACE$(tekst$, zoek$, vervang$)
 Local p, result$
 result$ = ""
   p = Instr(tekst$, zoek$)
   If p = 0 Then
     result$ = result$ + tekst$
     Exit Do
   result$ = result$ + Left$(tekst$, p - 1) + vervang$
   tekst$ = Mid$(tekst$, p + Len(zoek$))
 REPLACE$ = result$
End Function
' === Hoofdlus ===
text 10,10,""+str$(a)
 ' Bereken knop (#4)
 If CtrlVal(#4) = 1 Then
   expr$ = CtrlVal(#1)
   expr$ = REPLACE$(expr$, " ", "")
   If Left$(expr$,1)="=" Then expr$ = Mid$(expr$,2)
   On ERROR SKIP
   result = Eval(expr$)
   CtrlVal(#3) = Str$(result)
   CtrlVal(#4) = 0
 ' DEL knop (#2)
 If CtrlVal(#2) = 1 Then
   tekst$ = CtrlVal(#1)
   If Len(tekst$) > 0 Then CtrlVal(#1) = Left$(tekst$, Len(tekst$)-1)
   CtrlVal(#2) = 0
 ' Knoppen 10 t/m 24 (invoer)
 For id = 10 To 24
   If CtrlVal(#id) = 1 Then
     toevoeg$ = Mid$(chars$, id - 9, 1)
     CtrlVal(#1) = CtrlVal(#1) + toevoeg$
     CtrlVal(#id) = 0
 Next
 ' navigatie knop (#25)
 If CtrlVal(#25) = 1 Then
    CtrlVal(#25) = 0
    gui page 2
 Pause 50
Posted: 12:29pm 21 Jul 2025
Is this what you are after?
CLOUR foreground_colour, RGB(Yellow)
  Quote  COLOUR fore [, back] or COLOR fore [, back]
Sets the default colour for commands (PRINT, etc) that display on the on the attached LCD panel.
'fore' is the foreground colour, 'back' is the background colour.
The background is optional and if not specified will default to black.
Or perhaps start the program with:-
CLS RGB(yellow)
Then add your GUI elements. After closing a GUI element use:-
BOX x, y, w, h, 1, RGB(yellow), RGB(yellow)
To restore yellow to that area.
tenij000
Posted: 10:33pm 21 Jul 2025
thx
