Local Time 08:24 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem playing audio, fails on GUI button press
astro1
Posted: 10:58am 12 Jul 2025
If an mp3 or flac file not being played, GUI buttons react and program continues to run.
With either mp3 or flac file playing, pressing a GUI button causes the program to "freeze" with the audio just a sluttering sound. Need to reset.
Running firmware PicoMiteRP2350V6.00.03.
Test code:
OPTION EXPLICIT
OPTION DEFAULT NONE
dim last%, offset%
last%=mm.vres
offset%=int((mm.hres-(int(mm.hres/70)*70))/3)
gui button #6,"menu|MENU",offset%+(70*0),last%-(70*2),70,70,rgb(cyan),rgb(blue)
gui button #8,"pause|PAUSE",offset%+(70*1),last%-(70*2),70,70,rgb(white),rgb(magenta)
gui button #9,"again|AGAIN",offset%+(70*0),last%-(70*3),70,70,rgb(black),rgb(cyan)
'play flac "b:/music.flac"
play mp3 "b:/movie.mp3"
'PLAY TONE 500, 500 : PAUSE 2000
do
text 10,10, time$
pause 100
loop
Posted: 11:28am 12 Jul 2025
I'm not sure that there's a satisfactory answer to this. The GUI uses an interrupt to detect a button press and PLAY SOUND depends on an interrupt. You can't delay PLAY SOUND with anything or there's a risk of breaking the sound up as a minimum.
{Mick sits back with popcorn to wait for further replies...}
