Local Time 08:10 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite Firmware Release Version 6.00.03
     Page 1 of 9
Posted: 08:27am 10 Jul 2025
We have a new release of the PicoMite firmware from Peter: Version 6.00.03
Significant changes are:
- Fixes bug in PLAY SOUND when the right channel is specified
- Improves performance of USB keyboards
- Fixes bug in PLAY MP3/FLAC/WAV when playing a directory
- Fixes bugs in handling of BYVAL and BYREF in function/subroutine calls
+ updates to the manual.
This update includes the PicoMite/PicoMiteVGA/WebMite versions and manuals into one file.  The download link is: https://geoffg.net/Downloads/picomite/PicoMite_Firmware.zip
Posted: 08:48am 10 Jul 2025
One minor item missed. So perhaps the next manual update could have:-
  p126 said  MATH WINDOW in(), minout, maxout, out() [,minin!, maxin!]
minimum and maximum floating point values found in the original data (“minin!” and “maxin!”).
Edited 2025-07-10 18:53 by phil99
Posted: 09:15am 10 Jul 2025
Geoff/Peter,
Checked a few firmwares (2040 / 2040VGA / 2350), and can report that when the upgrade is made over 6.00.02 the Options / flash slots / A: drive are not erased.
When the update is made over 5.08.00 then the chip is erased.
Posted: 09:38am 10 Jul 2025
  phil99 said  One minor item missed.
Thanks, I will include that in the next revision of the manual.
Posted: 11:30am 10 Jul 2025
Now that PLAY SOUND right channel is working there appears to be differences between the manual and M (mono) operation.
  Quote  'channelno' specifies the output channel. It can be L (left speaker), R (right
speaker), B (both speakers) or M (mono output with the right channel inverted
compared to the left).
1) M requires quotes while L, R, and B don't.
2) The right channel does not appear to be inverted compared to the left. Same as B.
> PLAY SOUND 1, M, S, 1000, 25 : DO : LOOP
Error : Expected a string
> PLAY SOUND 1, "M",S ,1000, 25 : DO : LOOP
Tested on basic RP2040.
Edited 2025-07-10 21:33 by phil99
Posted: 11:47am 10 Jul 2025
Hi Phil,
You are correct. M does not invert anymore. Peter has removed that since it was not used. It was originally introduced because of a niche application (Game*Mite), and not actually used. I think M should be removed from the manual.
twofingers
Posted: 12:58pm 10 Jul 2025
  Volhout said  ... , and not actually used. I think M should be removed from the manual.
I used it intensively with the PicoPongo.
@Geoff
Thanks for your work, it must be difficult to keep adding new changes.
Michael
Posted: 01:05pm 10 Jul 2025
Hi Michael,
What MMBasic revision is PicoPongo based on ? I think the M inversion has been disabled since 5.09.00. Long time ago. M as Mono may have worked, but not inverted the audio channel R.
Edited 2025-07-10 23:06 by Volhout
twofingers
Posted: 01:24pm 10 Jul 2025
Hi Harm,
  Volhout said  Hi Michael,
RP2350A Edition V6.00.02RC14.
I only used it because I'd never done anything with audio before. I was a complete newbie to game development. My advice above was also meant to be a bit cautious with changes.
Kind regards
Michael
Posted: 01:29pm 10 Jul 2025
I think I left "M" in to avoid breaking anything that had used it. The code for "M" is the same as "B". As Volhout says the original functionality is deprecated.
Edited 2025-07-10 23:30 by matherp
Posted: 08:48am 11 Jul 2025
In another thread Stan has mentioned the ILI8488 SPI S_DO / MISO pin fix isn't shown in the manual.
  Quote  OPTION LCDPANEL ILI9488, OR, DC, RESET, CS [,BL] [,INVERT]
Initialises a TFT display using the ILI9488 controller. This supports 480 * 320 resolution.
Note that this controller has an issue with the MISO pin which interferes with the touch controller.
For this display to work the MISO pin must not be connected.
Is it worth adding it for new users?
The most flexible version of this that works on all the SPI displays I have, including ILI9341 is a diode from LCD S_DO to T_DO and Pico MISO and a 1.8kΩ resistor from LCD CS to T_DO and Pico MISO. The diode can be any type with a junction capacitance of at least 30pF and up to 500pF. eg 1N4004 or 1N5819 are about 100pF.  Anode to LCD S_DO, cathode to T_DO and Pico MISO.
Previously I used 10kΩ for the resistor but the 4" IPS ILI9488 panels have 4.7kΩ pullups on the SD card SPI pins. 1.8kΩ is low enough for LCD CS to pull MISO to logic low when LCD S_DO goes low. !.8kΩ is high enough not to unduly load either T_DO or SD_DO. All the SD cards I have work with it.
Edited 2025-07-11 21:11 by phil99
Posted: 04:06pm 11 Jul 2025
Please could you update the 6.00.03 download with the attached. Fixes a bug in the CHAIN command when PSRAM is not enabled
PicoMiteV6.00.03.zip
dddns
Posted: 04:33pm 11 Jul 2025
I think there's something wrong in the archive. File size for all 2350 versions 2,1MB..
homa
Posted: 04:45pm 11 Jul 2025
  matherp said  Geoff
Hello Peter,
please check your ZIP file. I wanted to install the "PicoMiteHDMIUSBV6.00.03.uf2" directly, but that didn't work. Even deleting with the clear-tool didn't help. The file from Geoff download on the other hand works. I noticed that your file has 2088KB vs 1481KB!?!
Matthias
Posted: 05:37pm 11 Jul 2025
Strange - I just use a batch file to build everything and nothing has changed since the original release except one tiny fix for CHAIN
Try
dddns
Posted: 05:51pm 11 Jul 2025
This one is fine for me. Many thanks!
PicoMiteHDMI MMBasic USB RP2350B Edition V6.00.03
Posted: 08:19pm 11 Jul 2025
  phil99 said  In another thread Stan has mentioned the ILI8488 SPI S_DO / MISO pin fix isn't shown in the manual.
the "fix" is not mentioned for ili94xx but it works  with 10kr and any diode.
just says don't connect mosi.
but I got the display to be same as ili9341, touch, sd card, and same read screen capabilities
Initialises a TFT display using the ILI9488 controller. This supports 480 * 320 resolution.  Note that this
controller has an issue with the MISO pin which interferes with the touch controller.  For this display to work the
I can connect it and seems ok... with diode resistor
stan
homa
Posted: 08:32pm 11 Jul 2025
  matherp said  Strange - I just use a batch file to build everything and nothing has changed since the original release except one tiny fix for CHAIN
Try
Thank you! It works perfectly now.
Posted: 09:27pm 11 Jul 2025
  matherp said  Geoff
Please could you update the 6.00.03 download with the attached. Fixes a bug in the CHAIN command when PSRAM is not enabled.
Done, using the latest (updated) files dated 12/7/2025.
Edited 2025-07-12 07:32 by Geoffg
Posted: 12:48am 12 Jul 2025
As reported by Mixtel90 in the other thread CHAIN still isn't quite right.
Mick's test with some extra Prints.
> option list
PicoMite MMBasic RP2040 Edition V6.00.03
OPTION FLASH SIZE 16777216
OPTION COLOURCODE ON
OPTION CPUSPEED (KHz) 200000
> list "q1.bas"
Print
Print "This is the Main program (q1.bas)"
Print "MM.CMDLINE$ = ";MM.CMDLINE$
If MM.CMDLINE$<>"chainret" Then
 Print "Array and Vars prepared in Main (q1.bas):"
 Dim integer d(5)=(1,2,3,4,5,6),z1=1,z2=2,z3=3,z4=4
 Print "d() = "; :Math V_Print d()
 Print "z1,z2,z3,z4= ";z1;z2;z3;z4
 Print "Passing array & Vars to q2.bas:"
 Print
 Chain "a:/q2.bas"
If MM.CMDLINE$="chainret" Then
 Print
 Print "Array & Vars returned from q2.bas:"
 Print
Print "The End"
End
> list "q2.bas"
Print "This program (q2.bas) is chained from Main (q1.bas)"
Print "Array & Vars received from q1.bas"
print "d() = "; : math v_print d()
For i=1 To 6
  d(6-i) = i
Next
z1=5 : z2=6 : z3=7 : z4=8
Print
Print "Array & Vars about to be returned to Main (q1.bas)"
print "d() = "; :math v_print d()
print
Chain "q1.bas","chainret"
> RUN
MM.CMDLINE$ =
d() = 1, 2, 3, 4, 5, 6
z1,z2,z3,z4=  1 2 3 4
d() = 0, 0, 0, 0, 0, 0
d() = 6, 5, 4, 3, 2, 1
z1,z2,z3,z4=  5 6 7 8
MM.CMDLINE$ = chainret
The End
Same result if d(5) integer or float.
Edited 2025-07-12 15:25 by phil99
     Page 1 of 9
