Local Time 08:24 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMiteVGA: out of memory problem
Amnesie
Posted: 02:42pm 09 Jul 2025
Hello,
working on my gui editor I encountered the problem that I ran out of memory.
Do I interpret the manual wrong?!
Manual Page: 83
PicoMiteVGA RP2350 184Kb
My program size is: 132 KB (135.168 Bytes)
It runs on resolution 640, 720 but not on 848 & 800
there is a "trick" I can get it to work:
set the resolution to 640, then:
load "gui_editor_b23c"
load it in the flash and then change the resolution to 848 and press F2.. this will work... hm...
Here is my file:
gui_editor_b23c.zip
Greetings
Daniel
Peter63
Posted: 04:23pm 09 Jul 2025
print mm.info(heap), is only 137984 using 848
/peter63
Posted: 04:37pm 09 Jul 2025
What you are seeing is correct. You can only load a program as big as the heap available as the heap is used to buffer the ascii program ready for tokenising and 848 and 800 modes pinch heap for the framebuffer.
if(Option.CPU_Speed==Freq848){ //adjust the size of the heap
   framebuffersize=424*240*2;
   heap_memory_size=HEAP_MEMORY_SIZE-framebuffersize+320*240*2;
   FRAMEBUFFER=AllMemory+heap_memory_size+256;
   MODE1SIZE=MODE1SIZE_8;
   MODE2SIZE=MODE2SIZE_8;
   HRes=848;
if(Option.CPU_Speed==FreqSVGA){ //adjust the size of the heap
   framebuffersize=400*300*2;
   MODE1SIZE=MODE1SIZE_V;
   MODE2SIZE=MODE2SIZE_V;
   MODE3SIZE=MODE3SIZE_V;
   MODE5SIZE=MODE5SIZE_V;
   HRes=800;
   VRes=600;
By loading in a "standard" mode you have the normal VGA heap available (184Kb) so you can load/edit and save the program. Assuming the running program then doesn't exceed the reduced heap when you switch mode all is OK. I'm afraid you will have to live with your "trick" if you want to run in 800 or 848 modes.
Amnesie
Posted: 05:20pm 09 Jul 2025
Peter,
thank you for this good explanation, I didn't knew that! Ok, then I have to do some "shrinking" and code optimization. I have already ideas, the most space is taken by the PRINT (save) routine of the final GUI, If I can outsource this to a second *.bas file but preserve the variables, I could solve the problem   I don't know how to do this right now, but I am sure I find a way for this
EDIT: Isn't the Library function exactly for that purpose? I could put all my "save routine" into the library. Good time to look further into the manual! But I have a "feeling" that this could be a solution.
Greetings
Daniel
Edited 2025-07-10 03:42 by Amnesie
Amnesie
Posted: 05:59pm 09 Jul 2025
What the?
How cool is that? I thought.. well this will be complicated with all those Library stuff, but I tried it a few minutes ago and it works. What a wonderful feature!
I excluded what takes the most space, and this is the save routine the whole sub in the library and now everything works.
MMBASIC is full of features! This was the first time I used the Library.
But not only this, I think this GUI editor wouldn't be possible with the features:
Option Escape and OPTION CONTINUATION LINES as well.
Greetings
Daniel
Edited 2025-07-10 04:17 by Amnesie
dddns
Posted: 05:30am 10 Jul 2025
Hello Amnesie,
that's why I argued for PSRAM in the other thread.
I'm using HDMI on a 16:9 screen and OPTION RESOLUTION 848 or 800 are the best.
But without PSRAM, e.g. framebuffer or blit are not possible in Mode 3.
With PSRAM, you have more than 6 Mb of heap:
> memory
Program:
  0K ( 0%) Program (0 lines)
288K (100%) Free
Saved Variables:
 16K (100%) Free
RAM:
  0K ( 0%) 0 Variables
  0K ( 0%) General
6480K (100%) Free
Posted: 07:11am 10 Jul 2025
Yes, but if you assume the presence of PSRAM you are tying your code to very few available platforms, none of them from Raspberry Pi. That rather loses the point of the PicoMite as something that anyone can get by loading free firmware onto a cheap and easily available module.
Amnesie
Posted: 09:36am 10 Jul 2025
  Mixtel90 said  Yes, but if you assume the presence of PSRAM you are tying your code to very few available platforms, none of them from Raspberry Pi. That rather loses the point of the PicoMite as something that anyone can get by loading free firmware onto a cheap and easily available module.
Agree 100% - this is the reason I won't take a look at PSRAM. It is all nice and good, but for me it isn't the point of picoMite anymore (in this case!). I would reduce the potential users and exclude them, force them to have a PSRAM. No... I won't do that.
And: isn't the cool thing to try squeezing water out of stones?
Greetings
Daniel
Edited 2025-07-10 20:59 by Amnesie
