Forum Index : Microcontroller and PC projects : this display also works ILI9341V
| tenij000 Senior Member Joined: 30/05/2025 Location: NetherlandsPosts: 107 |
ILI9341V shop the none touch version i try out |
| EDNEDN Guru Joined: 18/02/2023 Location: United StatesPosts: 308 |
That looks like a really good deal. It is obviously some promotional deal because they will only let you get 1 at the $.99 price with free shipping. Thanks for the link!!!! |
Well... Go Figure!!!! I ordered the display and I also asked my wife to order one. They didn't send the displays. They sent a teaspoon and some make up brushes. No electronics at all. And the teaspoon had big scratches and gouges in it. @tenijooo Did you place an order? Did you get anything? |
I got one with no touch chip. works but bit small to see out |
I ordered 2 with touch but paid about AU$10 for each about US$6.50. Still an OK price. I got them OK and both no problems. "It is better to be ignorant and ask a stupid question than to be plain Stupid and not ask at all" |
They come in 2 sizes both same 320x240. mine are years old and were cheap then but they work fine. I like car reversing monitors for small displays but as said no touch. |
Ha! My wife got stiffed. I asked her to complain and see if they make it right. But my order actually got delivered today. I haven't connected it up and tested it yet. But at least they sent 1 of the 2 that was ordered. Edited 2025-07-13 13:54 by EDNEDN |
er... that don't travel the pond. |
Stan: your displays are ILI9341 aren't they? Not ILI9341V. I think that's a newer version. Whether there's any difference I don't know. Also, there are at least two versions of the ILI9341 that I know of, the version numbers are written on them. You have to supply your own backlight transistor and/or series resistor for the early version (pre V 2.0, I think). Mick Zilog Inside! nascom.info for Nascom & Gemini |
I connected led backlight to 5V, no resistor or prob so far. why dim it I don't know ... pwm?? it dim enough as is ![]() I did try short the 5v reg link and used 3.3v to run and led backlight, worked Edited 2025-07-14 06:24 by stanleyella |
i use this https://github.com/tenij000/picomite touch version pcb also never connected the 5volt |
