Forum Index : Microcontroller and PC projects : PEEK and POKE FLOAT var! 32 bit
Posted: 07:39am 20 Jun 2025
Both PEEK and POKE FLOAT var! are described in the Picomite manual as 32bit but they both appear to be 64 bit.
The manual needs updating.
I have a use for 32bit PEEK/POKE FLOAT.
I have written a function for PEEK and will try POKE next but I was wondering if there is a 32bit version lurking in the firmware somewhere.
disco4now
Posted: 10:37am 20 Jun 2025
Not sure if this is what you are doing.
Is this any help
Gerry
F4 H7FotSF4xGT
Posted: 10:59am 20 Jun 2025
Something like: convert to 32-bit then use POKE WORD.
Worst case, extract 4 bytes & use POKE BYTE.
Posted: 10:47pm 20 Jun 2025
Thank Gerry, that should be useful.
I have a routine to read *.OPT files and there are 2 floats in the structure.
This is what I came up with:
   CASE "float"
     b1%= ASC(INPUT$(1,#3)) : b2%= ASC(INPUT$(1,#3)) :b3%= ASC(INPUT$(1,#3)) :b4%= ASC(INPUT$(1,#3))
     tempint% = ((b4%*256+b3%)*256+b2%)*256+b1%
     mantissa = tempint% AND &h7FFFFF
     mantissa = mantissa +&h800000
     exponent = (tempint% >>23)AND &hFF
     exponent = exponent - 127
     sign = (tempint% >>31)AND 1
     tempfloat! = mantissa*2^-23*2^exponent * 10000 ' multiply by 10k to match OPTION LIST
     IF sign THEN tempfloat!=0-tempfloat!
     readdata$ = STR$(INT(tempfloat!))+" ("+STR$(b1%)+" "+STR$(b2%)+" "+STR$(b3%)+" "+STR$(b4%)+")"
I didn't think of converting to 64bit at the bit level.
Posted: 07:31am 22 Jun 2025
One interesting issue I found was
2^exponent
In the third last line it was overflowing with large numbers even though the result was going into a float.
I changed it to
2.0^exponent
to force a float and all was well
I ended up using a combination of this code and the FoTS code
