Local Time 08:46 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Help with code
allie
Posted: 11:12pm 16 Jun 2025
Hi all! I'm playing around in writing my code for the CMM2 Gen2 for my Lath and Milling machine project with MMBasic 5.07.01. I know I don't have to use line numbers, I'm old school (commodore 64 days). And the way you use the GOSUB routines has changed.
For now I still like using them. I'll change it later after I get a working program. Most of what I have now works fine, except for this. I'll leave out comments for now.
15 PRINT : PRINT
18 D$="NOTHING"
20 PRINT"       L FOR LATH OR M FOR MILL"
25 PRINT : PRINT
30 INPUT"       L OR M" ;LM$
35 PRINT : PRINT
40 GOSUB 1000   'ROUTINE FOR PRINT" XI FOR X AXIS IN * XO FOR X AXIS OUT" SAME Y AXIS
   ' EVERY THING WORKS GOOD UP TO HERE
   ' PROBLEM WITH THESE LINES
42 PRINT : PRINT : PRINT"LM$ =" ;LM$
45 IF LM$ <> "L" OR LM$ <> "M" THEN CLS : GOTO 20
   ' WHEN LM$ = L OR M IT CLS SCREEN AND GOES TO LINE 20
   ' IT SHOULD GO TO THE NEXT LINE.
50 IF LM$="L"THEN INPUT" INPUT FOR LATH XI * XO * YI * YO";D$
REGARDS ALLIE
Edited 2025-06-17 09:16 by allie
EDNEDN
Posted: 11:31pm 16 Jun 2025
Did you mean:
45 IF LM$ <> "L" AND LM$ <> "M" THEN CLS : GOTO 20
Because the original If condition is always going to evaluate to being true.
Edited 2025-06-17 09:34 by EDNEDN
Posted: 12:13am 17 Jun 2025
Option B:-
45 If Not(LM$ = "L" Or LM$ = "M") THEN CLS : GOTO 20
Should do the same thing.
allie
Posted: 12:34am 17 Jun 2025
Did you mean:
I was thinking the or would work as I used it in other places. Thanks for the input. I changed it to (and) and all is good.
Regards Allie
allie
Posted: 12:37am 17 Jun 2025
  phil99 said  Option B:-
I tried this also and it worked too.
Thank you both for the quick response.
Regards Allie
Posted: 06:44am 17 Jun 2025
if instr("LMlm",LM$)=0 then
cls
goto 20
endif
It's not a great idea to use multi-statement lines that begin with an IF statement. There is the danger that commands may not do what you expect! Far better to make use of ELSE and ENDIF simply because they are available and make your code much clearer.
When someone is entering keyboard commands you need to make sure that the character case will be detected or nothing will happen - and you'll have a confused user! So:
32 LM$ = UCASE$(LM$)
will make sure that your string comparisons will work, even if they enter lower or mixed case characters.
INSTR() is a great function for this sort of thing. It will search the test string and return the position of the search string or zero if it's not found. In the above example it will return 1 for "L", 2 for "M", 3 for "l" or 4 for "m".
Or you could use the full IF/ENDIF tree with slight rearrangement:
20 CLS
22 PRINT:PRINT
24 PRINT"       L FOR LATH OR M FOR MILL"
25 PRINT : PRINT
35 PRINT : PRINT
IF LM$ = "L" then
'do something with the lathe
ELSE IF LM$ = "M" then
'do something with the mill
ELSE
GOTO 20
ENDIF
Jumping out of the IF/ENDIF with a GOTO is a bit naughty (it used to mess the return stack up), but MMBasic is quite well behaved. :)
allie
Posted: 10:53am 23 Jun 2025
Hello all.
I am hooking my PicoMite to My CMM2 Gen2 with the TX and RX Comms and I'll will be using the console on the CMM2 Gen2.
Question: which TX,RX com pins on the CMM2 GEN2 should I use? Com 1 or Com 2.
Regards Allie
