Local Time 08:58 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoVision -- pimoroni
amiga
Posted: 08:19pm 13 Jun 2025
Hi all nice people on this little blue planete,
This morning i saw this UFO :: PicoVision https://shop.pimoroni.com/products/picovision?variant=41048911904851
2 RP2040(50) ..
I dream to have a Picomite for this concept
- CPU 1 :: MMBASIC_CORE for application (and why not with WebMite)
- CPU 2 :: MMBASIC_GPU  for display data
Dream Dream ... it's the one way to heaven ...
From Belgium (22:17/ Friday 13 !! no black cat .. very hot .. 30°C for my little country .. hot like Hell)
have a nice day , evening or good nigth depending where you are ..
Alfa Miga
Perhaps , confusing ::
i mean ::
RP2040-1 :: MMBASIC_CORE for application (and why not with WebMite)
RP2040-2::  MMBASIC_GPU  for display data .
Edited 2025-06-14 06:54 by amiga
Posted: 08:55pm 13 Jun 2025
To sleep—perchance to dream. Ay, there’s the rub!
For in that sleep of death what dreams may come,
Posted: 09:33pm 13 Jun 2025
Remember that they needed two RP2040 chips because the RP2040 can just about create DVI output with a lot of cheating to get the resolution to look right. The RAM is insufficient to have a normal framebuffer and any sort of program.
A single RP2350 probably knocks the spots off that board, even running under MMBasic. At least the display can be completely controlled dynamically. The HSTX does most of the hard work that the display driving RP2040 does.
Remember that the Pico W isn't receiving video data, it doesn't have enough bandwidth for that.
amiga
Posted: 10:26pm 13 Jun 2025
  Mixtel90 said  Remember that they needed two RP2040 chips because the RP2040 can just about create DVI output with a lot of cheating to get the resolution to look right. The RAM is insufficient to have a normal framebuffer and any sort of program.
you're right ... sometimes dreams go to nightmare ... but never seen nightmare changed in dreams ..
It's too hot, take my mattress down to the cellar .. it's cool there for sleeping... especially for my bottles of wine.
alfa miga
amiga
Posted: 10:33pm 13 Jun 2025
my idea is using webmite with a HDMI display , cause actually is not possible .. small ressource for webmite and DVI output with a single RP20xx .
it's why this solution seems to be interesting with 2 RP20xx according my very short experience with MMBASIC and RP20xx i'm not a guru only an old junior ...
Alfa Miga
Posted: 06:45am 14 Jun 2025
It's probably easier to use a PicoMite HDMI and something like a ESP8266-01S linked to it over a COM port. Then you can send it commands over a wireless link, very much like they did sending commands to a ANSI terminal over RS-232. The PicoMite would convert the commands into something to do on the display. Any sort of RF or even a IR receiver could do this.
You still can't send actual video over link, it's not fast enough, You can send commands like "draw a line from x,y to x1,y1 in colour c and thickness t". You just need to create (or adapt) a language to do it in. ANSI might be a good starting point. You could even send Videotext in theory, but it gets more complicated.
