Forum Index : Microcontroller and PC projects : sd card
Posted: 01:25am 05 Jun 2025
I use OPTION SDCARD GP22, GP6, GP7, GP4
why is GP22 always used? what else could I use, same side of the board?
stan
Posted: 01:42am 05 Jun 2025
  manual said  SD Card I/O Pins
Alternatively, where no other devices share the SPI bus with the SD card it can be set up with:
OPTION SDCARD CS_pin, CLK_pin, MOSI_pin, MISO_pin
In this case the pins can be assigned completely flexibly and do not need to be capable of SPI operation but SD card performance will be better if valid SPI pins are chosen.
AlbertR
Posted: 06:18am 05 Jun 2025
check OPTION LIST
and LIST PINS
