Local Time 08:58 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 'Option wifi' within programs ?
DigitalDreams
Posted: 09:48am 27 May 2025
Can we have this allowed within programs please Peter ?. It would be MUCH easier moving from one known wifi to another then....
Posted: 10:35am 27 May 2025
No
Posted: 02:16pm 27 May 2025
A man of few words, is Peter. :)
There will be good reasons why not though.
Posted: 02:34pm 27 May 2025
It is always polite to speak with 2 words...
NO, NO...
Edited 2025-05-28 00:38 by Volhout
Posted: 03:42pm 27 May 2025
Getting the Webmite/Pico2-W to run reliably has been a nightmare - it's basically a c..p design. There is no chance I'm going to change anything on this port relating to anything to do with the wifi/web operations
Marcel27
Posted: 05:29am 28 May 2025
  matherp said  Getting the Webmite/Pico2-W to run reliably has been a nightmare - it's basically a c..p design. There is no chance I'm going to change anything on this port relating to anything to do with the wifi/web operations
PhenixRising
Posted: 05:35am 28 May 2025
  Volhout said  It is always polite to speak with 2 words...
NO, NO...
Reminds me of an old friend talking to his 9 year-old daughter:
Friend: "So how's it going at school?"
Daughter: "Fine"
Friend: "Well can you expand upon that?"
Daughter: "Fiiiiiiiiiiiiiiiiiinnnnnnnnnnnnnnnnnne"
Edited 2025-05-28 15:36 by PhenixRising
damos
Posted: 11:42pm 05 Jun 2025
I have the same problem, and would be quite happy for the system to reboot as soon as it hits the option wifi line of code.
I have a solution for myself. Switch the console to a serial port on the webmite and put the user interface on a second Picomite which sends the option wifi command to the webmite through the serial port. This has the advantage of being able to display friendly messages while the webmite is rebooting.
This means the webmite can have really simple code that just handles the HTTP requests and the picomite drives the touch screen and handles the UI. It can also be used as a watchdog for the webmite. The hardware watchdog really doesn't work well on HTTP as the code can regularly take longer than the watchdog time limit. I think you could output a "." every second or so to show the processor is running and the picomite will send a "^C" and cpu restart if it gets no serial activity for 10s. You could use the software watchdog on the webmite, but the serial activity means the picomite can also display an online indication.
Posted: 01:07am 06 Jun 2025
That looks like a good solution.
Below is what I have been using. It's adapted from the work of others here.
Sub MM.STARTUP
  Pause 200
  On error skip 6
  If MM.Info(ip address) = "0.0.0.0" Then    'test for WiFi link
    Print "WiFi not found";
    Pause 8000
    Print "...Rebooting now"
    CPU restart  'endless re-boot until WiFi found
  Local float TZ = 10, DS = 1    'Time Zone, Daylight Saving
  Local integer n = 0
  Do While Date$ = "01-01-2024" 'test internet connection, wait for date$ to update
   On error skip
    WEB NTP TZ+DS, "203.12.160.2" 'Second choice is 0.au.pool.ntp.org or 1.au.pool.ntp.org
   Inc n : Print n; " tries", DateTime$(now),
   Pause 2000
   If n=15 Then End Sub 'give up!
  Print
  RUN 'start main program
toml_12953
Posted: 02:58am 06 Jun 2025
  DigitalDreams said  Can we have this allowed within programs please Peter ?. It would be MUCH easier moving from one known wifi to another then....
I agree but, to be Zen about it, it is what it is.
Edited 2025-06-06 13:37 by toml_12953
Posted: 03:51am 06 Jun 2025
deleted
Edited 2025-06-06 13:53 by phil99
Posted: 05:16am 06 Jun 2025
The webmite is easy to break but if you really want to try, this should work:
print "started"
END "option wifi "+chr$(34)+"myWiFi"+chr$(34)+","+chr$(34)+"myPWord"+chr$(34)
It causes a reboot with the new WiFi
Posted: 10:36am 06 Jun 2025
  phil99 said  That looks like a good solution.
Sub MM.STARTUP
  Pause 200
  On error skip 6
    Pause 8000
  Local integer n = 0
   On error skip
   Pause 2000
  Print
Should really use
If n=15 Then Exit Sub 'give up!
Posted: 11:10am 06 Jun 2025
Should really use
Both execute the same code
Posted: 12:34pm 06 Jun 2025
  matherp said
Should really use
I know - but it's wrong and if someone ever changes the parser or writes another it'll show up as a bug.
Posted: 12:59pm 06 Jun 2025
In this instance it doesn't matter if it fails with an error as it has failed to find the internet and the program is abandoned.
damos
Posted: 01:07am 10 Jun 2025
  TassyJim said  The webmite is easy to break but if you really want to try, this should work:
print "started"
Thanks Jim,
I will give this a go before proceeding with my option. It basically does what I need and saves a second processor and serial port.
