Local Time 09:24 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Watering system and email
PhilP
Posted: 10:53am 24 May 2025
Good morning. In my quest to set up a new email service with SMTP2GO and failing to use Geoff's emailing guide I am trying to do it via the watering programme without any of the hardware. I am hoping that I can understand the code and establish an email service through the programme. However I am having problems. What am I doing wrong???
I am using a Pico 2 W with the following options.
WebMite MMBasic RP2350A Edition V6.00.01
OPTION AUTORUN  ON
OPTION FLASH SIZE 4194304
OPTION CPUSPEED  150000 'KHz
OPTION WIFI GNXB6EFC0, ************, PICO78FB9216274
OPTION TCP SERVER PORT 80
OPTION TELNET CONSOLE ON
OPTION COUNT GP10,GP6,GP7,GP8
The programme seems to run OK as shown below but I can't get to the watering system set up pages to establish the email service at the IP address given.
01-01-2024 00:00:17  ====================== Booting...
01-01-2024 00:00:17  Checking connection to WiFi
01-01-2024 00:00:17  Connected.  IP address is 192.168.1.116
01-01-2024 00:00:17  Getting UTC time
ntp address 77.104.162.218
got ntp response: 24/05/2025 10:35:00
got ntp response: 24/05/2025 11:35:00
24-05-2025 11:35:00  Using timezone1 current date/time = 24-05-2025 11:35:00
24-05-2025 11:35:23  Sending default page. Auto refresh set to 44679 seconds.
24-05-2025 11:35:28  Sending default page. Auto refresh set to 44675 seconds.
I have have tried the IP address through both Chrome and Firefox browers but neither works
Looks like there’s a problem with this site
http://192.168.1.116/ sent back an error.
Error code: 404 Not Found
Thanks for any help
Phil
Posted: 11:20am 24 May 2025
ignore
Edited 2025-05-24 21:21 by CaptainBoing
Posted: 11:27am 24 May 2025
assuming everything is set up for HTTP (it isn't specifically mentioned in the list) http://192.168.1.116/   on it's own must serve a default document - without a URI after the site address (e.g. a page name), the server (your Pico) is being asked to provide a document by the browser that it doesn't know about - hence the 404 "document not found"
so, if your Pico is creating a document called fred.htm, try and be specific and provide that as the URI in the web address: http://192.168.1.116/fred.htm
If this doesn't progress things, use wireshark to snoop the traffic (filter on the IP address both ways) and see what the conversation is.
Edited 2025-05-24 21:29 by CaptainBoing
Posted: 11:41am 24 May 2025
I am having trouble understanding the problem.
You say "I can't get to the watering system set up pages to establish the email service at the IP address given".  But you don't explain any further.  For example. what IP address?.
Then you claim that http://192.168.1.116 "sent back an error".  That is the address of your RPi card - that is not directly related to getting email notifications working.
None of this makes sense.
To make it worse, you are using a Pico 2 W.  The software has not been tested with this board!
I suggest that you:
- Use a RP2040 Pico.
- Get the software working so that you can connect to the main web page generated by the software.
- Set up an account with SMTP2GO
- Register a Verified Sender and create an associated username and password.
- Enter that in the Setup page.
- Then test that you can send an email.
Posted: 11:52am 24 May 2025
The watering system works fine with a genuine Pico2-W. What isn't supported by MMBasic is the Pimoroni wireless version based on the RP2350B.
PhilP
Posted: 01:02pm 24 May 2025
Geoff - sorry to be so confusing but I was trying to follow the instruction on your https://geoffg.net/retic.html page. I a trying to get to the General Settings Page to set up an email that way. I have the credentials from SMTP2GO to enter.
In the Construction Pack Note it says "As part of installing the firmware you should have noted the IP address given to the controller by your router. To setup the controller enter this address into the address bar of a web browser and you should see the home page as described here: https://geoffg.net/retic.html." It is this IP address I mentioned in my previous and was expecting this to be the way to get the Configuration Pages.
The software doesn't mention any restriction on type of Pico W to use so I thought that with the appropriate firmware a Pico-2 W would work as I happened to have one.
Thanks to matherp for confirming this.
Perhaps I am just being thick!!
Phil
Posted: 07:36am 25 May 2025
  PhilP said  Perhaps I am just being thick!!
Not at all.
The first thing that you need to do is get access to the home web page of the Watering Controller.  You can then worry about setting up the email later.
Can you do that?
From your log listing it shows that your Gardening Controller received at least two web page requests and sent the default web page (ie, the home page) both times, so something is working.  Once you can see the home page you can click on the GENERAL SETTINGS button at the bottom (you may have to scroll up) and that will open up the settings page for entering the email info.
Have you got there?
Finally:
  PhilP said  I have have tried the IP address through both Chrome and Firefox browers but neither works
Where did you enter this address?  Just saying "have tried the IP address" does not give much information!  There is a misunderstanding floating around here but I cannot see what it is.  The more information that you give the more we will be able to help you.
You should download the PicoMite User Manual (https://geoffg.net/Downloads/picomite/PicoMite_User_Manual.pdf) and read the chapter starting on page 71.  There may be a clue in there somewhere.  That chapter also talks about sending emails using SMTP2GO.
Edited 2025-05-25 17:43 by Geoffg
PhilP
Posted: 11:49am 25 May 2025
Geoff - thanks for your patience. In response to your first question, my problem is finding the home web page of the Watering Controller.  Once I have got there I think I will be OK for setting up an email account. I managed with SENDGRID!!
I understood that the home page was at the IP address given in the start up message of the programme as shown on the Tera Term dialogue i.e.
25-05-2025 12:30:01  Checking connection to WiFi
25-05-2025 12:30:01  Connected.  IP address is 192.168.1.116
It was this address in entered into the browsers and got Error code: 404 Not Found. If it is not there where do I find the home page? Captain Boeing suggested I add a URI?
Phil
Posted: 12:42pm 25 May 2025
Have you set the server port address?
OPTION TCPIP SERVER PORT 80
dddns
Posted: 12:44pm 25 May 2025
Can you ping the system from your client? Obviously yes, but please try
Posted: 01:16pm 25 May 2025
Yes, the IP address of your Pico W 2 is 192.168.1.116
So, you should be able to type that into the address bar of your browser and you should be able to see the home page.  You could also use:
192.168.1.116/index.html
http://192.168.1.116/index.html
they should all work the same.
When you do this you should see something like the following on the console:
xx-xx-xxxx yy:yy:yy  Sending default page. Auto refresh set to zzzzz seconds
This is the BASIC program saying that it has just sent the default web page (index.html) to a browser that asked for it.  The puzzling thing is that this is exactly what your console log shows... so something requested and received the home web page just 25 seconds after your Pico W 2 booted up.
I cannot see what the problem is.  The software works fine with the Chrome browser and is used by many people so it must be something strange that is happening in your browser or on your network.  All I can suggest is that you try to diagnose the problem and perhaps the answer will drop out.
Martin H.
Posted: 01:26pm 25 May 2025
Could the problem be due to the security settings of the browser or operating system?
Many current browsers deny http access and therefore only allow https connections, unless you explicitly allow it
'no comment
