Local Time 09:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : A question to Windows Experts - USB driver
Gadgetguy
Posted: 01:58pm 19 May 2025
Hello all,
I have a new question.
It seems that the Serial to USB driver I have installed a while ago (on my windows11 laptop) is not optimal for the picomite (as it offers a max speed of 115K baud), so I would like to remove it.
I spent a lot of time on google and found various tools to remove the driver (it is a CH341 driver), but I cannot as non of those tools work. One seems to remove it, but the moment I plug the Picomite in, the ch341 driver is back.
I also tried to download the correct driver - to simply replace the CH341 one, but Microsoft says its in windows and does not offer a download.
I tried Zadig - did not work either
Any suggestions please? How can I get rid off the CH341 driver (as I guess I should get more than 115200 baud). Or is 115200 typically sufficient?
Thank you!
Edited 2025-05-20 00:45 by Gadgetguy
Posted: 02:55pm 19 May 2025
"is 115200 typically sufficient?"
Yes, typically. It has been pushed several multiples higher, but the use case need for that is rare.
ville56
Posted: 03:24pm 19 May 2025
I usually use the good old device manager
device manager -> COM ports -> right click on the COMx: you want to remove -> deinstall device and click on "try to remove the driver".
The text above may appear a bit different on your installation as I'm using a german windows version and have no english installation at hand. Should work, just tried it, now I have to reinstall the driver again ....
73 de OE1HGA, Gerald
Posted: 04:27pm 19 May 2025
I'm surprised that the driver is limited to that speed. The CH341 is capable of going much faster.
