Local Time 09:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : PicoMite is far superior
PhenixRising
Posted: 09:45am 19 May 2025
Tried to inform in the past but always falls on deaf ears.
Posted: 10:14am 19 May 2025
Pico can show it's strength when we have a "PLC PCB that can be ordered from JLC" and fits in a standard DIN rail housing.
Are you up to the task...?
dddns
Posted: 10:45am 19 May 2025
I saw basic 15 years ago on a Atmel1284 emulating ZX81 with already some more speed as the original. Completely written in ASM. There is much interest regarding tinkerers but not in mass. This is a niche where everybody has his own thoughts. And if you would let Annex32 vanish from earth, nobody would care.
I think,one can only support this by showing off his nice solutions.
And I think we are living in the last days of human kind and its the last chance.
PhenixRising
Posted: 10:53am 19 May 2025
  Volhout said  Pico can show it's strength when we have a "PLC PCB that can be ordered from JLC" and fits in a standard DIN rail housing.
Working on it...only one year behind schedule   Things keep evolving and so I keep going back to square one
My first target is to compete with this
It's a PLC + 4-axis motion controller. Its onboard TrioBASIC executes 31 lines/ms
Posted: 12:29pm 19 May 2025
  dddns said  if you would let Annex32 vanish from earth, nobody would care
Not true at all. I would care. From my perspective, it's the best Rapid Development System with wifi (and ESPNow). It gets far less attention than it deserves.
With the caveat: it's not to be used commercially (not a problem for me).
(But it's probably true that not more than a dozen or two would care if Annex is dropped by its creator.)
(And I don't know what Annex has to do with this thread.)
dddns
Posted: 12:44pm 19 May 2025
Try use this and it shouldn't take too long to find out
Posted: 02:37pm 19 May 2025
A PLC is more the software than the hardware. The hardware isn't all that important now as a typical microprocessor emulates true PLC hardware in almost every case. However, it's rare to find a low-end PLC that isn't natively programmed in function block or relay ladder language. They never use C or BASIC. Things like high speed counters or timers are simply modules that the programmer doesn't have to write.
If you want an Arduino or a Pico to emulate a PLC that's fine, but you have to start by writing the programming language(s) for it first. :)  If it doesn't support function block and/or relay ladder then virtually no-one in industry will want it.
It's different when you have the big PLCs, with (in many cases) hundreds of IO points. Many of those can be programmed in a lower level language.
In many cases the low end PLCs are referred to as "intelligent relays", which is a much better description of them IMHO.
Posted: 03:03pm 19 May 2025
  dddns said  Try use this and it shouldn't take too long to find out
Cryptic
PhenixRising
Posted: 03:21pm 19 May 2025
Exactly
GAVI
Posted: 04:35pm 19 May 2025
I use ANNEX and Picomite, each is more suitable than the other for various applications.
Both projects are evolving significantly and I don't think it's fair to denigrate ANNEX
