Forum Index : Microcontroller and PC projects : v6.00.01 vs 02 - pdf summary of differences?
| Gadgetguy Senior Member Joined: 26/04/2025 Location: FrancePosts: 104 |
Hello all, it is amazing to see that 6.00.02 is close to a formal release with associated documentation. Thank you all for the work on it - as a newbie it is amazing to see how quickly MMBasic evolves. I have just printed the full .01 manual - and if possible I would like to avoid printing the full .02 manual. Will there be maybe a PDF summary of the changes so I can print only that? Thank you so much for sharing your insights. |
Maybe one of the PDF tools would help with that. (pdfdiff etc) John |
Sorry, but I'm not planning on doing that. However, Peter often produces a change log which is almost as good. In the past I tried using Word's document compare feature to highlight the new text but it created a corrupted mess - perhaps the manual and its formatting has got too complicated for that to work. Geoff Geoff Graham - http://geoffg.net |
Thank you,noted. Lets hope Peter will produce the Change Log you mention. In any case I truly appreciate all the amazing work! |
Just wait for the manual... :) I've tried to keep up with changes previously. Now I prefer to stick with a release long enough for me to actually do something with it other than test it! Peter lists what changes have been made each time he does a release candidate. That's the closest you're likely to get to a change log. Everything else is just interim changes, which may or may not appear in a release candidate. . Edited 2025-05-13 22:03 by Mixtel90 Mick Zilog Inside! nascom.info for Nascom & Gemini |
| amiga Regular Member Joined: 08/05/2025 Location: BelgiumPosts: 53 |
Hi GadgetGuy, Try to ask ChatGPT make a structured doc containing the new fautures when comparing the nex and old doc IA est good tool for this kind of job. @+ AlfaMiga .. from Belgiun ...hot summer .. no rain ! Farmers begin mode PANIC 🥵🌞 |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
@Amiga You were faster! I asked ChatGPT about it today, and it confirmed your assumption. I'll try it when the new manual is ready. Michael |
