Local Time 09:50 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Setting multiple pins simultaneously
     Page 1 of 3
Nimue
Posted: 12:26pm 12 May 2025
Good afternoon from a wet Wales.
Let's say I have 6 LEDs on on GP2 - GP7.
I can set them for outout with SETPIN GP2, DOUT etc and control them with PIN(GP2) = 1 etc.
I am randomly lighting one of the 6 (other five off).  Currently doing this with a clunky Select Case:
pseudoish code:
Select Case LEDon
 CASE 1
   PIN(GP2) = 1
   PIN(GP3) = 0
   PIN(GP4) = 0
   PIN(GP5) = 0
   PIN(GP6) = 0
   PIN(GP7) = 0
 CASE 2 - 'etc etc
Questions:
(1) Is there a way to set all pins low in one simple command? ie PIN(ALL) = 0
(I could abstract this to a SUB, setting each pin individually, so asking in case I've missed something) -- that way I only need to set the pin that is on.
(2) Ideally what I want to do is:
PIN (INT(RND * (m - n + 1)) + n) = 1
 where n=2, m=6 so that it picks a random pin from 2 to 6.  Is there an easy way to achieve this?  I could construct the "GP2" part as a string and use "EVAL" - but that feels clunky.  Again, asking in case I've missed the obvious.
Cheers all.
Posted: 12:46pm 12 May 2025
Hi Nimue,
Look at the PORT command. You can write a value to multiple pins at once, as if it where a parallel port.
Edited 2025-05-12 22:48 by Volhout
Nimue
Posted: 12:51pm 12 May 2025
  Volhout said  Hi Nimue,
Perfect - that will sort it.  Thankyou.
One of the downsides of not printing the manual is I loathe browsing PDFs like a paper manual.  Time to print one again I think.
Posted: 12:55pm 12 May 2025
@Nimue,
Wait a bit... 6.00.02 to be released soon, and then you can print the latest manual.
I am also waiting for it. For me 6.00.02 will be the version I settle on (for RP2040 VGA / pico RP2040 that will most likely not change much anymore, since it took so much squeezing already, it will kill Peter if we ask for more...).
Edited 2025-05-12 22:56 by Volhout
Nimue
Posted: 01:03pm 12 May 2025
It amazes me how much is now crammed in - for my mostly trivial use cases, I almost want "less" so I can see the wood for the trees and get back to the "BASIC" in MMBasic.   But of course, it just means I don't use those new spicy features, so not in any way a criticism of all the work going on here.
My use case for what it's worth is to create a "demo" mode for a 1978 SIMON game - so that it can be left on randomly cycling through the colours.  As is, the SIMON uses both a 9V and x2 D cells.  Retrofitting a 'Mite and 4 LEDs (+USB power bank) is far more suitable for use as an ornament.
For what its worth, will post it went up and running.
Posted: 01:07pm 12 May 2025
  Nimue said  Good afternoon from a wet Wales
kind of goes without saying   you'll get some sun soon - we haven't had a drop of rain to be worth mentioning here in central England in about 6 weeks... but we have had that pesky north wind which really takes the edge off the sun
So... As @Volhout has already pointed out, the PORT command is your friend here. It allows you to address a whole load of pins in one go - sounds exactly what you want. Set your GPIO pins so they act as the bits of the port (doesn't have to be 8 bits) and then you just write a value to the port and the binary represenation would light up the LEDs of your choice
Assuming your LEDs are active on logic 1...
If you want single LEDs to light, choose a number between 0 and 5 (to keep the LED numbers nice and "computery), then PORT 2^number for just a single LED. When you want them all off, just write 0 to the PORT
For n=1 to 100'sparkle the LEDs
 PORT(GP2,6) = 2^Int(Rnd*6)
 Pause 100
Next
PORT(GP2,6) = 0' all LEDs off
hth
Posted: 01:15pm 12 May 2025
Beat me to it, though slightly different method.
PORT(GP2,6) = 1 << CInt(Rnd * 5)
Edited 2025-05-12 23:24 by phil99
Nimue
hth
Cloudy, wet, a cool 19'C.  Mind you Newport is always miserable
  Quote  2^Int(Rnd*6)
Oh my, forgetting my binary from back in the day bit banging the parallel port on AcronElectrons/Plus 1 -- memory is failing me.   Perfect, nice.  Off to tinker.
Nimue
Posted: 01:17pm 12 May 2025
  phil99 said  Beat me to it, though slightly different method.
PORT(GP2,6) = 1 << CInt(Rnd * 6)
Yikes, from banging to bit shifting in one simple post -- like it.  Again, off to play.
PhenixRising
Posted: 01:20pm 12 May 2025
  Nimue said  It amazes me how much is now crammed in
It's mind boggling
I'm not aware of any MCU development that comes close. Just when you think there is something to be desired...there it is
I miss so many developments myself but I will never complain
Posted: 01:30pm 12 May 2025
I made a mistake. 6 pins is 0 to 5 so:-
or
PORT(GP2,6) = 1 << Rnd * 5
As MMBasic automatically converts the float to an integer in this situation.
Edited 2025-05-12 23:36 by phil99
Nimue
Posted: 04:36pm 12 May 2025
Mmmmm curious behaviour (most likely something I am doing)
Version 6.0001 -- plain old Mite via serial terminal.  Fresh flash.
Testing with x4 leds, GP2-GP5
PORT(gp2,4) = &B1111  indeed turns on all 4 LEDS
PORT(gp2,4) = &B0000  does not turn the leds off
Reissuing PORT(gp2,4) = &B1111 turns off the LEDs.
It looks like setting a bit to "0" is not turning off, but setting to "1" toggles the state between 0 and 1 back to 0.
Print "Starting..."
Print "ALL on"
Port(gp2,4) = &B1111
Pause 1000
Print "All off"
Port(gp2,4) = &B0000  'Looks like it does nothing - ie LEDS still lit
Pause 1000
Print "Trying &B1111"
Port(gp2,4)=&B1111    'indeed turns off LEDS
Pause 1000
Therefore once the bit pattern is not all 1111's or all 0000's issuing PORT(GP2,4) = 1 << Rnd * 3  as per this thread only turns off leds once they recive a "1" ie turn off when already on.
This is most likely something I am doing...... any pointers...
Edited 2025-05-13 02:42 by Nimue
Posted: 04:41pm 12 May 2025
That looks wrong...  :(
Nimue
Posted: 04:43pm 12 May 2025
  Mixtel90 said  That looks wrong...  :(
Yea - addressing them with PIN() - works fine.
The port() command seems to only flip the bits with a 1 - the 0 seems to not change the state.
The code is simple, so not sure I'm missing anything here....
Posted: 04:59pm 12 May 2025
There was a bug in 6.00.01, it's mentioned in the bug list on Geoff's site. Upgrade to the latest 6.00.02RC23
Edited 2025-05-13 03:00 by matherp
Posted: 05:08pm 12 May 2025
I take it that you configured the pins as DOUT first?
Posted: 05:21pm 12 May 2025
Works for me with PicoMite MMBasic RP2040 Edition V6.00.02RC20
Nimue
Posted: 06:08pm 12 May 2025
  matherp said  There was a bug in 6.00.01, it's mentioned in the bug list on Geoff's site. Upgrade to the latest 6.00.02RC23
100% nailed it - upgraded, now works as expected.
Thanks all for the steer.
Nimue
Posted: 06:10pm 12 May 2025
  Mixtel90 said  I take it that you configured the pins as DOUT first?
Yes!!
Is there a way to configure a range of pins at once or individual SetPin?
Regardless -- all shipshape now.
Posted: 06:13pm 12 May 2025
No official way to SETPIN a range, no.
     Page 1 of 3
