Local Time 09:50 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite V6 MMBasic manual?
Gadgetguy
Posted: 10:07am 08 May 2025
Hello all,
I see that the most recent (beta) firmware for the Maximite Color 2 is V6.00
The official manual is (as far as I can see) for V5.07.01
Is there somewhere an updated manual for the Maximite V6.00 please?
Or should I just look at the PicoMite manual Ver 6.00 - will that be accurate (except the PIO part)?
Thank you for your help!
Edited 2025-05-08 20:09 by Gadgetguy
Posted: 10:11am 08 May 2025
Typically a user manual update happens when a beta or release candidate becomes a final release. Since 6.00 on the CMM2 is beta, use the 5.7 user manual. It is the only available.
Gadgetguy
Posted: 10:28am 08 May 2025
  Volhout said  Hi,
Thank you. So there is no way to find out what has changed between 5.7 and 6.0 on the cmm2?
Posted: 10:34am 08 May 2025
It's mostly internal stuff
MATH commands are now as per PicoMite
Includes MEMORY PACK/UNPACK as per PicoMite
Includes BLIT MEMORY as per PicoMite (Petscii compatibility)
Fixes various bugs
Gadgetguy
Posted: 10:52am 08 May 2025
  matherp said  It's mostly internal stuff
Fixes various bugs
Thank you
