Local Time 09:50 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : identify what cpu running on (picomite)
vincenthimpe
Posted: 07:12pm 07 May 2025
is there a command that can tell me what cpu i am running on ?
RP2040 , RP2350A RP2350B and so on ?
Posted: 10:02pm 07 May 2025
Try ?mm.device$.
I don't have a way at present to determine whether it distinguishes between RP2040, RP2350A, RP2350B.
vincenthimpe
Posted: 10:55pm 07 May 2025
that just prints PicoMite. i need to know the actual cpu . the base address for the control registers is different . since i'm writing a library i want to make it self-detecting.
ebbandflow
Posted: 11:05pm 07 May 2025
In absence of a more direct solution, what about setting pins (or other options) that will only work on specific models, and use the error/lack of error and the process of elimination?
Posted: 11:30pm 07 May 2025
print mm.device$
WebMite RP2350A
> print mm.ver
6.0002
disco4now
Posted: 02:38am 08 May 2025
All using RP2350A have it appended to mm.device$
All using RP2350B have it appended to mm.device$
If neither is present it is an RP2040
? mm.device$
PicoMiteHDMIUSB RP2350A
F4 H7FotSF4xGT
