Local Time 10:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : [Picomite] The best method to clear the keyboard buffer.
twofingers
Posted: 02:35pm 01 May 2025
What is the best method to clear the keyboard buffer?
I know this method:
Do :Loop Until Inkey$=""
Do :key$=inkey$:Loop Until key$<>""
However, I'm not sure if it's the only or the best one. Are there alternatives, e.g., to prevent "overshooting" when scrolling through lists?
Is there a way to adjust the firmware?
Kind regards
Michael
PhenixRising
Posted: 05:51pm 01 May 2025
I guess it depends on what you're doing but in my case, if there's a character in the RX buffer, I evaluate it with a SELECT-CASE. Use it or lose it.
Posted: 07:12pm 01 May 2025
  twofingers said  What is the best method to clear the keyboard buffer?
I know this method:
Kind regards
Michael
The method you describe will work in general (PS2 keyboard/USB keyboard/console). All other methods I know are specific, either to USB or PS2...
In games we use a similar method to your second to keep the last valid key to control the game, the las one before the empty buffer responds with "".
Edited 2025-05-02 05:14 by Volhout
twofingers
Posted: 02:06pm 02 May 2025
@Volhout
Thanks for the confirmation, Harm. It's working great for me right now, too. I just need to figure out why it sometimes doesn't work so well and keeps running uncontrollably.
I vaguely remember that there used to be access to the keyboard ring buffer. I just wanted to make sure I hadn't overlooked anything.
@PhenixRising
thanks! Unfortunately, I don't understand your answer. My question was about the "overshooting" when outputting lists (e.g., FM) controlled by the up/down cursor keys. I think that's answered sufficiently.
Kind regards
Michael
