Local Time 10:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Can MMbasic access larger system flash ?
vincenthimpe
Posted: 05:37pm 29 Apr 2025
The default Pico module comes with a 2MB flash memory
However, the rp2040 can use up to 16Mb using a W25Q128.
Can the interpreter use this extra space as drive A ?
Trying to avoid requiring an external SDcard.
I'm rolling my own board using a bare rp2040 so i can stick any QSPI flash there i want.
PhenixRising
Posted: 05:40pm 29 Apr 2025
Already does this
Posted: 05:44pm 29 Apr 2025
AFAIK the flash is allocated for the firmware, then the flash slots 0-3 then any remaining up to the limit is allocated to A:. I have some YD-RP2040 16MB clones that use the remaining available space so I assume that's how MMBasic handles it. :)
vincenthimpe
Posted: 07:07pm 29 Apr 2025
  PhenixRising said  Already does this
great !
