Local Time 10:04 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Y-Axis Flipped in PicoMite
toml_12953
Posted: 10:36am 28 Apr 2025
In MMBasic, the Y-Axis is reversed from the usual orientation so that y=0 is the top of the screen.
In some variants of MMBasic, there's a OPTION Y_AXIS UP command that flips the Y-Axis so it follows the usual Cartesian coordinate system.
PicoMite doesn't have this option. Is there any chance of getting it in a future release?
Edited 2025-04-28 20:37 by toml_12953
Posted: 10:47am 28 Apr 2025
The only version with that option is the CMM2 and that was done specifically at the request of a teacher for use in school. All other versions of MMBasic behave like the PicoMite as do historical versions of Basic like BBC Basic. It adds significant complexity so the answer is no.
Posted: 09:47pm 28 Apr 2025
y0=screen height-1
Edited 2025-04-29 07:48 by stanleyella
Posted: 10:27pm 28 Apr 2025
If writing to the screen from an array MATH WINDOW can be used to both scale the data to fit the desired display area and invert it so 0 is at the bottom.
  Manual said  This command can massively simplify scaling data for plotting etc.
Edited 2025-04-29 08:32 by phil99
Posted: 08:20am 29 Apr 2025
This solves your problem, adds very little time-wise in the drawing etc and harks back to the screens of the 80s & 90s
I use it all the time as it is just more logical for my old brain
they co-habit very nicely with the existing graphic commands and i generally inter-mingle them as I see fit, so I end up with "sensible"-looking stuff like this (which makes much sense to my addled gourd):
Sub ButtonDown(x As Integer,y As Integer,w As Integer,h As Integer,t$,col As Integer)
 Move x+(w/2)-MM.FONTWIDTH*(Len(t$)/2),y+(h/2)+MM.FONTHEIGHT/2
 Colour col,cGy
 Text Gx,Gy,t$
 Move x,y
 DrawR 0,h:DrawR w,0
 Colour &hffffff
 DrawR 0,-h:DrawR -w,0
h
Edited 2025-04-29 18:47 by CaptainBoing
