Local Time 10:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Drawing Robot
PhenixRising
Posted: 08:53am 23 Apr 2025
I like stuff that actually moves
Would be cool to have a PicoMite version
DaveJacko
Posted: 10:02pm 23 Apr 2025
sorry to bang on about me, but I was rather proud of my drawing machine..
made from a Micromite, cheap stepper module, 2 motors, RC servo and some string.
a mercifully short video here..
https://www.youtube.com/watch?v=Buybf25-wbg
I also like stuff that moves!
Try swapping 2 and 3 over
Frank N. Furter
Posted: 06:57am 24 Apr 2025
That's cool! Would you post your code???
Thanks!
Frank
PhenixRising
Posted: 08:26am 24 Apr 2025
  DaveJacko said  sorry to bang on about me, but I was rather proud of my drawing machine..
Love it...and the mouse trap
darthvader
Posted: 08:31pm 24 Apr 2025
My own from 6 years ago
Drawbot Plotter
DaveJacko
Posted: 09:02pm 24 Apr 2025
OK Frank, do you really want to see my code?
This version just does up/down/left/right from the PC cursor keys
so it is as simple as possible, I can explain more if needed..
' gantry plotter demo DPJ 2020 username "DaveJacko"
' uses Pythag's theorem and Bresenham's line drawing algorithm
init
Pin(enabpin)=0
ls=9333 'steps=350mm = plot area size in steps
xnow=ls/2 'start at centre of plot area
ynow=ls/2
l1now=ls*0.707 '1/sqr(2)
l2now=ls*0.707 '=250mm
mainlp:  ' --- the main loop
t$=Inkey$   ' keypresses, u/d = pen raise/lower
If t$="" Then GoTo mainlp
If t$=" " Then Pin(enabpin)=1:PWM 2,stop: End
If t$="u" Then penup
If t$="d" Then pendn
a$=a$+t$
If Len(a$)>3 Then a$=Right$(a$,3)
If a$=lc$ Then moveby -1,0  'cursor keys move the pen around
If a$=rc$ Then moveby 1,0
If a$=uc$ Then moveby 0,-1
If a$=dc$ Then moveby 0,1
GoTo mainlp
Sub MoveBy(mbx,mby)  ' moveby ie move pen relative to current posn.
mbx=mbx*266 '=1 cm
mby=mby*266
' calc turns from mbx,y
l1now=Sqr(xnow*xnow+ynow*ynow) 'maybe +residual l1now
l2now=Sqr((ls-xnow)*(ls-xnow)+ynow*ynow)
xtarg=xnow+mbx
ytarg=ynow+mby
l1targ=Sqr(xtarg*xtarg+ytarg*ytarg)
l2targ=Sqr((ls-xtarg)*(ls-xtarg)+ytarg*ytarg)
l1mov=l1targ-l1now
l2mov=l2targ-l2now
Print "mbx,mby",,mbx,mby
Print "xnow,ynow",xnow,ynow
Print "xtarg,ytarg",xtarg,ytarg
Print "l1now,l2now",l1now,l2now
Print "l1targ,l2targ",l1targ,l2targ
Print "l1mov,l2mov",l1mov,l2mov
Print
xnow=xtarg
ynow=ytarg
' now turn motors by l1mov,l2mov
'directions..
If l1mov>0 Then Pin(dirxpin)=0 Else Pin(dirxpin)=1
If l2mov>0 Then Pin(dirypin)=1 Else Pin(dirypin)=0
'major axis is..
If Abs(l1mov)>=Abs(l2mov) Then 'l1 is major
l1i=Sgn(l1mov)
l2i=l2mov/Abs(l1mov)
ni=Abs(l1mov) 'num of incs
Print "l1 major"
Else 'l2 is major axis
l2i=Sgn(l2mov)
l1i=l1i/Abs(l2mov)
ni=Abs(l2mov)
Print "l2 major"
l1acc=0:l2acc=0
For i=1 To ni ' do move
l1acc=l1acc+l1i
l2acc=l2acc+l2i
If l1acc>=1 Then l1acc=l1acc-1:Pin(stpxpin)=1
If l1acc<=-1 Then l1acc=l1acc+1:Pin(stpxpin)=1
If l2acc>=1 Then l2acc=l2acc-1:Pin(stpypin)=1
If l2acc<=-1 Then l2acc=l2acc+1:Pin(stpypin)=1
wait1
Pin(stpxpin)=0
Pin(stpypin)=0
Next i
Sub init '---- init
stpxpin=2  ' define step pins
stpypin=3
stpzpin=4
dirxpin=5   '..direction pins
dirypin=6
dirzpin=7
enabpin=9
stoppin=15
'servopin=26 pwm
SetPin 2,dout
SetPin 3,dout
SetPin 4,dout
SetPin 5,dout
SetPin 6,dout
SetPin 7,dout
Pin(9)=1 'enable off
SetPin 9,dout
SetPin 15,din,pullup 'int?
e$=Chr$(27) 'define escape
uc$=e$+"[A" 'cursor keys up/down/right/left
dc$=e$+"[B"
rc$=e$+"[C"
lc$=e$+"[D"
SetTick 1,int1ms  'timer
Pause 100
Sub penup   ' lift the pen
PWM 2,50,7
Sub pendn   ' drop the pen
PWM 2,50,10
Sub int1ms   ' --timer subs
iflag=1
Sub wait1
w1lp:
If Not iflag Then GoTo w1lp
iflag=0
Frank N. Furter
Posted: 07:12am 25 Apr 2025
@DaveJacko:
Thank you very much! I think I need to pick out a few stepper motors from my stash and build something...
@darthvader:
Did you also realize this with MMBASIC?
Frank
PhenixRising
Posted: 07:41am 25 Apr 2025
  darthvader said  My own from 6 years ago
Drawbot Plotter
A couple of DC motors + encoders and the PicoMite could make it superfast
Posted: 09:01am 25 Apr 2025
There's a limit to how fast you can draw a line on paper. :)
We used to have fun with one of the old A3 pen plotters. Expensive pens always worked fine, some of the cheaper ones were decidedly dodgy as they got older. The ink simply didn't have time to get out of the tip on fast lines. Mind you, we could get a lot of cheap pens for the cost of one expensive one. :)
PhenixRising
Posted: 09:20am 25 Apr 2025
  Mixtel90 said  There's a limit to how fast you can draw a line on paper. :)
Oh sure but closed-loop servo blows steppers away
darthvader
Posted: 09:38am 25 Apr 2025
  Frank N. Furter said  @darthvader:
Frank
No , it was like a 3D printer with Marlin.
