Local Time 10:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Pass an Array *name* to a SUB?
toml_12953
Posted: 06:54am 23 Apr 2025
Is there any way to pass the name of an array to a SUB? I don't want to pass the array itself but rather the name of the array so I can use a single call that selects between MATH M_PRINT and MATH V_PRINT without worrying whether the table in question is an array or a vector.
Posted: 07:45am 23 Apr 2025
Pass both but use the zeroeth value or a flag to indicate which task you want?
I can't se how you could pass a name other than as a string. If you did that the string itself could be the array, but you may need to copy it into a proper local array to manipulate it.
Edited 2025-04-23 17:47 by Mixtel90
vegipete
Posted: 07:20pm 23 Apr 2025
Could you use the Bound function to determine the dimensionality (?) of the passed array?
toml_12953
Posted: 08:50pm 23 Apr 2025
  vegipete said  Could you use the Bound function to determine the dimensionality (?) of the passed array?
Hmmm. That might work. I'll investigate. Thanks!
dddns
Posted: 04:35pm 24 Apr 2025
pass it as string and then
single :Execute "Dim " + yourstring$ + "(" + Str$(your_value) + ")"
Two dimensional: Execute yourstring + "(" + Str$(your_value) + "," + Str$(your_value) + ") = " + Str$(your_value)
If you want to see what your code is doing replace the execute with print.
Edited 2025-04-25 02:47 by dddns
