Local Time 10:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : WS2812 - SK 6812W DEVICE Command
Hansaplast
Posted: 06:06am 22 Apr 2025
[Quote]
Full support for the WS2812 multi colour LED chip which can be daisy chained into long strings? really?
But how to address 200 LED's in a single line?
Any Idea or help?
Dim a%(19)=(&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000,&h00ff0000)
>Only max. 20<
 DEVICE ws2812 w, GP3, 200, a%()
This is not working correct!
Edited 2025-04-22 16:07 by Hansaplast
Posted: 07:06am 22 Apr 2025
You don't. That's the clumsy way to set up the array. :)
DIM it first then fill it using a READ loop. You can split the values over DATA statements. or, to set a single colour for the string, just assign each dimension value in the loop.
If using DATA statements you can RESTORE to a label, so you can have several sets of values.
Posted: 07:07am 22 Apr 2025
Dim a%(199)
For i=0 to 199
A%(i)=&h00ff0000
Next
And then send the array
Hansaplast
Posted: 07:46am 22 Apr 2025
Hello
Thanks a lot. Let me have a try
_______________________________
Dirk
