Forum Index : Microcontroller and PC projects : PicoMite: available RAM (heap} ?
Hi folks, I'm away from my Picos at the moment (and in any case don't have any RP2350). Could someone tell me how much RAM (heap) the non-USB, non-VGA, non-HDMI PicoMite firmware 6.00.xx has on the RP2040 and RP2350 ? The output of the MEMORY command would do, though that includes the variable table in the RAM calculation. Thanks in advance, Tom Edited 2025-04-14 06:36 by thwill MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1782 |
Hi Tom, > option list PicoMite MMBasic RP2350A Edition V6.00.02RC12 OPTION FLASH SIZE 4194304 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 150000 > memory Program: 0K ( 0%) Program (0 lines) 288K (100%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 336K (100%) Free option list PicoMite MMBasic Version 5.07.06b4 OPTION COLOURCODE ON OPTION CPUSPEED (KHz) 378000 OPTION DISPLAY 40, 80 > memory Program: 0K ( 0%) Program (0 lines) 116K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 148K (100%) Free Opps, 2040 + 5.07.06b4 Kind regards Michael Edited 2025-04-14 06:58 by twofingers |
PicoMite MMBasic RP2040 Edition V6.00.01RC10 Copyright 2011-2024 Geoff Graham Copyright 2016-2024 Peter Mather > memory Program: 1K ( 0%) Program (38 lines) 127K (100%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 156K (100%) Free |
| circuit Guru Joined: 10/01/2016 Location: United KingdomPosts: 309 |
PicoMite MMBasic RP2350B Edition V6.00.02RC12 Copyright 2011-2025 Geoff Graham Copyright 2016-2025 Peter Mather > memory Program: 0K ( 0%) Program (0 lines) 288K (100%) Free Saved Variables: 16K (100%) Free RAM: 0K ( 0%) 0 Variables 0K ( 0%) General 336K (100%) Free > PicoMiteRP2350V6.00.02RC12.uf2 Freshly loaded; no options set. Edited 2025-04-14 20:01 by circuit |
Many thanks. Tom MMBasic for Linux, Game*Mite, CMM2 Welcome Tape, Creaky old text adventures |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12059 |
If you want the definitive then look at configuration.h on github. Search for HEAP_MEMORY_SIZE and decode the #ifdefs for the version |
