does any of you know if the Waveshare mentioned in the subject (ILI9488 driver, SPI bus) display does work with the PicoMite AND the sd card also? If yes, which options are necessary to get both parts working? If touch would work too, even better, but not necessary.
Thanks a lot for your input!
Best regards,
Christian
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12059
