Local Time 10:21 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Disk Support mmbasic
Plasmamac
Posted: 06:42am 07 Apr 2025
Plasma
Plasmamac
Posted: 07:08am 07 Apr 2025
Pete’s great Cmm2 Device remember me on an old idea.
I like floppy Disk support on the Mmbasic.
Found the Arduino Fdc from DHansel on GitHub and bought an old Drive.
After some problems I’ve got finally some results
Format /Dir on Floppy
So I think with minimal hardware we can get floppy 💾 on mmbasic via xmodem (atm).
Maybe I can converting the Arduino code to a pico to become the full support with.
Gtx
Plasma
Plasmamac
Posted: 07:15am 07 Apr 2025
Some infos:Infos
Plasma
Plasmamac
My phone sux.. sorry
Edited 2025-04-07 17:16 by Plasmamac
Plasma
Amnesie
Posted: 07:20am 07 Apr 2025
I like this idea and asked (1 or two years ago) whether floppy drive support will be available on MMBASIC, but as far as I remember Peter said no. It brings some retro vibes   ... I have a lot of floppy disks and don't know what to do with them
Greetings
Daniel
Posted: 08:43am 07 Apr 2025
If you really, really want a floppy drive the best way is probably to hang a FDC chip onto a Raspberry Pi then write some COM port routines to connect to the Pi. Very much like the old Commodore drives worked. It needs nothing doing to the PicoMite, there are no buffers needed and only ASCII commands and data to be handled. The PicoMite USB system won't handle a USB connection to drives so the Arduino system isn't suitable.
You'll just have to work at it though. :)  Start here.
Don't even consider what is effectively writing a FDC into an Arduino. It's not worth the effort and a proper FDC chip will get all the timings right. Floppy handling can get messy even with a FDC and personally I'd recommend not bothering. SD cards are so much better. Last time I had a big clear out I must have binned over 200 3.5" disks. :)
Edited 2025-04-07 18:44 by Mixtel90
Frank N. Furter
  Amnesie said  ... I have a lot of floppy disks and don't know what to do with them
You could also sell your old disks here: https://forum.classic-computing.de/forum/
Frank
dddns
Posted: 09:15am 07 Apr 2025
I'd like to interpret this idea as I would like to access my PC drive.
So I think about doing this with a library providing the commands and attach it via a USB serial converter and the second UART to the PC. The PC side is running a small receiver program acting as server.
Ideal would be, if this could also be integrated/used with @Javavi file manager..
Edited 2025-04-07 19:15 by dddns
Posted: 09:50am 07 Apr 2025
The Pico has insufficient resources for the full USB stack that is needed for data devices. That's why it is limited to keyboards, mice and controllers.
PeteCotton
Posted: 05:06pm 07 Apr 2025
  Plasmamac said  Found the Arduino Fdc from DHansel on GitHub and bought an old Drive.
This is very cool/exciting. I will follow along with great interest.
  dddns said  I'd like to interpret this idea as I would like to access my PC drive.
Oooh - that is also an excellent idea.
A while back I toyed with the idea of using RFID cards to "store" data like a floppy. The way it would work would be that you'd have an ESP-01 chip on the CMM2 motherboard providing a cloud link. Putting the RFID card in the reader (like putting a floppy in a drive) would identify which files in the cloud to load into the computer. Given that CMM2 files are so tiny, they would load quickly. Of course, you would need software to read that - so I was going to build it into my old File Manager program, so that it would appear on the desktop like a normal disk.
https://www.thebackshed.com/forum/ViewTopic.php?TID=17452&PID=229772#229772
I know what you're thinking - that sounds like a waste of time - and you're right. In my defense, I didn't day it was a "good" idea
Another alternative was to 3D-print a floppy disk and embed an SD card in the tip. Then build a corresponding 3.5" drive, that is really an SD Card reader in disguise. You put the 3.5" floppy in the drive, with a satisfying "clunk" like the old days. And hey presto - you can read the "disk".
Posted: 10:26am 08 Apr 2025
  PeteCotton said  Another alternative was to 3D-print a floppy disk and embed an SD card in the tip. Then build a corresponding 3.5" drive, that is really an SD Card reader in disguise. You put the 3.5" floppy in the drive, with a satisfying "clunk" like the old days. And hey presto - you can read the "disk".
Now that's a clever idea!
Kinda pointless in the scheme of things, but a brilliant way to disguise an SD card as a floppy in an old floppy drive!
Might have to look into doing something like that, just for the nostalgia of it!
Posted: 02:46pm 08 Apr 2025
if you do, some sort of wiping contacts might be an idea. The contacts on the SD card may not last long with continual use.
Actually, maybe something like the Sinclair Microdrive  size or a 2.5" disk might be better than a 3.5" system. Less plastic yet still large enough to hold.
Or just a "kerplunk" sound effect triggered by inserting or removing a SD card. :)
Edited 2025-04-09 00:52 by Mixtel90
PeteCotton
Posted: 08:52pm 09 Apr 2025
  Mixtel90 said  Or just a "kerplunk" sound effect triggered by inserting or removing a SD card. :)
And a grinding sound as you read/write to the disk!
Posted: 07:47am 10 Apr 2025
To simulate a hard disk you could have the squealing sound of tortured bearings just before all the data is deleted forever! :)
Plasmamac
Posted: 06:55pm 11 Apr 2025
To become shure my disk are ok I’ve got another drive for testing. 7 from 11 Disks are working, the rest not , even format can’t help .
Like the Disk drive idea but I fear the end of Disks is near maybe creating some Fake with scard inside . 🤪
The monitor command with the read option show’s error stats if you can’t read from your Disks.
Plasma
Posted: 05:50am 12 Apr 2025
Quite a few people have posted on the internet regarding SD card in a 3.5” disk then being read by a converted FDD.
Here is just one example…
PeteCotton
Posted: 06:00am 12 Apr 2025
  WhiteWizzard said  Quite a few people have posted on the internet regarding SD card in a 3.5” disk then being read by a converted FDD.
Oh wow - that is very cool. They're using an original drive - which I feel would need more work modding than just building a "new" 3D printed reader from scratch.
As Mick suggested, it looks like they are using wiping contacts. that seems like the logical choice.
Posted: 07:14am 12 Apr 2025
Thanks WW, that's really cool! But doesn't a 32GB 3.5" floppy seem just a little unnatural? You wouldn't get the fun of changing it very often. :)
I'm not sure if the contacts are actually wiping, but that design will probably wipe well enough for the contact to be reliable. I wonder if pogo pins would work here?
Plasmamac
Posted: 03:59pm 16 Apr 2025
Bought a new pack of Hd. 3,5 Disks, all working 👍
Just a info
Plasma
