Local Time 10:40 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with sprite(C)
William Leue
Posted: 01:42pm 05 Apr 2025
I don't know if this is one of my usual mistakes or whether it is a problem with MMBasic 5.07.
When I do
sn% = 9
a% = sprite(C, sn%, 1)
I get the error message "Error in line xxx: 1 is invalid (valid is 0 to 1)
-Bill
Posted: 06:44am 06 Apr 2025
Hi Bill,
Assume this is CMM2 ?
When I read the manual correct, there can be multiple collisions with a sprite. Each of them can cause a collisions. So the sn% value tops at the number of actual collisions at that particular moment. Setting sn% to 9 means that you are sure there are 9 collisions at that moment. Meaning you have at least 10 sprites on screen.
Again, just reading the manual, and having zero experience with CMM2.
William Leue
Posted: 08:13pm 06 Apr 2025
Thanks, Volhout. However, I don't think that is correct. The manual says:
SPRITE(C, (#)n, m)
Returns the number of the sprite which caused the "m"th collision of sprite n.
In my case I have more than 9 sprites and I want to know the number of the sprite that collided with my sprite #9. So I set n = 9 and m = 1, because there will never be more than 1 collision at a time.
-Bill
Posted: 08:42pm 06 Apr 2025
I suspect the error message is rubbish and the issue is that that the sprite is involved in 0 collisions and thus there is no collision 1.
William Leue
Posted: 12:32pm 07 Apr 2025
Tom, that makes sense. I wish this had been implemented better in MMBasic: I would prefer it to return zero if there were no collisions instead of erroring. Now I will have to bracket it with a 'on error skip' statement, which wastes time in a time-critical part of the code.
-Bill
Posted: 01:12pm 07 Apr 2025
  William Leue said  Tom, that makes sense. I wish this had been implemented better in MMBasic: I would prefer it to return zero if there were no collisions instead of erroring. Now I will have to bracket it with a 'on error skip' statement, which wastes time in a time-critical part of the code.
I had much the same thought when porting/rewriting this code for MMB4L but ultimately decided I had to maintain the existing behaviour.
A related issue is that if you use SPRITE(C, #n) to get the number of collisions and then read and handle them using SPRITE(C, #n, m) then things get screwy if in handling a collision you actually resolve it such that the collision is no longer happening; the 'm' indexes all shift down one because of the removal of a collision.
@LeoNicolas saw this in his `Knightmare` port ... I think I improved his code slightly in this area (or broke it in a different way), but I still may have ended up deploying ON ERROR SKIP.
If you are reading Peter then maybe in the next version something like the command:
       SPRITE COLLISIONS #n, num, collisions()
might prove more flexible.
On return:
 `num` - the number of collisions sprite #n is involved in.
 `collisions` - the numbers of the other sprites/screen boundaries that sprite #n is collided with. If this array is too small then either ERROR or just fill it up to the number of available elements.
LeoNicolas
Posted: 02:59pm 07 Apr 2025
Yep Tom, that error was a pain. At the end I just used an ON ERROR SKIP do avoid the problem
