Forum Index : Microcontroller and PC projects : Interesting Output to console
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056 |
I updated the date and time on a program on a PI Pico running 6.0001 and got this printout on the console. The 260325 132322 CTime=2 Valves=0 is expected the line after it unusual. OA47 |
Oops, wrong thread. Edited 2025-03-26 12:59 by phil99 |
I am getting this text back on my console during log printouts. 290325 145639 RTU Status for Port 3 VOF 290325 145642 RTU04VOF-0.3 Low Battery Voltage D:\Dropbox\PicoMite\PicoMite\lfs.c:1969:warn: Unable to split {0x63, 0x71} 290325 145642 RTU Status for Port 4 VOF I am wondering if one of the authors of MMBasic might see the reference. Any thoughts Geoff of Peter? OA47 |
| matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12059 |
It's internal to the LFS file system and appears to relate to the flash disk itself being too full or to the file header area being too full or too fragmented // find size of first split, we do this by halving the split until // the metadata is guaranteed to fit // // Note that this isn't a true binary search, we never increase the // split size. This may result in poorly distributed metadata but isn't // worth the extra code size or performance hit to fix. lfs_size_t split = begin; while (end - split > 1) { lfs_size_t size = 0; int err = lfs_dir_traverse(lfs, source, 0, 0xffffffff, attrs, attrcount, LFS_MKTAG(0x400, 0x3ff, 0), LFS_MKTAG(LFS_TYPE_NAME, 0, 0), split, end, -split, lfs_dir_commit_size, &size); if (err) { return err; } // space is complicated, we need room for tail, crc, gstate, // cleanup delete, and we cap at half a block to give room // for metadata updates. if (end - split < 0xff && size <= lfs_min(lfs->cfg->block_size - 36, lfs_alignup( (lfs->cfg->metadata_max ? lfs->cfg->metadata_max : lfs->cfg->block_size)/2, lfs->cfg->prog_size))) { break; } split = split + ((end - split) / 2); } if (split == begin) { // no split needed break; } // split into two metadata pairs and continue int err = lfs_dir_split(lfs, dir, attrs, attrcount, source, split, end); if (err && err != LFS_ERR_NOSPC) { return err; } if (err) { // we can't allocate a new block, try to compact with degraded // performance LFS_WARN("Unable to split {0x%"PRIx32", 0x%"PRIx32"}", dir->pair[0], dir->pair[1]); break; } else { end = split; } } |
Thankyou Peter, I have cleared some files from the SD Card and I hope that will be the end of the message. OA47 |
OA47: how full (as a percentage) was the SD card, and how much space (im Mb) was available? Peter: could this error be trapped and/or returned as a meaningful error message of the form (for example) of "Drive D: has insufficient free space"? if not trappable, given the enormous capacities of SD cards compared to the size/speed of the RP2040 and RP2350, perhaps MMbasic could impose a maximum usage of, for example, 95% of total capacity? i don't see such a limit causing any hardship. cheers, rob :-) |
Unfortunately, when I type FILES I get, 4 directories, 3 files, 0 bytes free But when I put the SD card into the PC I get 245MB free of 246MB OA47 |
| Volhout Guru Joined: 05/03/2018 Location: NetherlandsPosts: 6197 |
Wauw, That is an old SD card (from around 2002). 256Mb..... Maybe it can't cope with the SPI clock speed PicoMite is using. Volhout Edited 2025-04-02 15:54 by Volhout PicomiteVGA PETSCII ROBOTS |
We seem to be getting confused. The original error relates to the flash disk - drive A: and is nothing to do with the SDcard with is drive b and uses FatFS. That error only occurs in LittleFS used for the flash disk. |
Didn't I mention I don't throw away much 😁 OA47 |
Your dead right there Peter. I have ported this program over from the F4 platform and it never occurred to me that I was writing to the FLASH and not to the SD card. Guess I will have to modify the File PATH. Is there an emoji to represent embarrassment whist eating humble pie? OA47 |
