Local Time 11:02 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : "option escape" and the local console
dddns
Posted: 09:20pm 24 Mar 2025
Hello!
I would like to print simultaneously on the local and the serial console.
The output should look identical.
Using "option escape" allows, to use some possible ANSI/VT-100 escape sequences within a string having the backslash as escape character(manual page 23)
It is also possible to send individual values.
All the listed escape codes on manual page 23/24 work and get executed on both console. Individual codes like using fore/background colors work as well on the serial (VT-100)console. But on the local console, unlisted codes won't be suppressed but get printed out in clear text. But I must admit, that I might not understand the manual correctly regarding usage.
My only idea how to get around this is to disable the local console output and print with the "text" command to it while printing to serial with "print @(x,y)".
But that would of cause have the disadvantage of processing it twice.
I would very much appreciate some suggestions!
Edited 2025-03-25 07:23 by dddns
dddns
Posted: 05:40pm 25 Mar 2025
No answer is still an answer. Will use occam's razor to analyze but fear bad..
Edited 2025-03-26 03:41 by dddns
Posted: 06:09pm 25 Mar 2025
Printing to the display (what you call the local console) can't handle ANSI escape codes, just the handful of escape characters mentioned p23-24 of the manual, and as a result such ANSI escapes just get printed as plain text.
  @dddns said  My only idea how to get around this is to disable the local console output and print with the "text" command to it while printing to serial with "print @(x,y)".
I believe that is what you will have to do, it's certainly what I did:
https://github.com/thwill1000/mmbasic-sptools/blob/master/src/splib/examples/txtwm.bas
https://github.com/thwill1000/mmbasic-sptools/blob/master/src/splib/txtwm.inc
But now I fear you will have follow up questions .
Edited 2025-03-26 04:29 by thwill
Posted: 06:13pm 25 Mar 2025
For a fully fledged example, see the program 'kingdom/kingdom.bas' in:
https://github.com/thwill1000/mmb4l/releases/download/v0.7-alpha.1/gamepack-1.0.0.tgz
Edited 2025-03-26 04:14 by thwill
Posted: 06:36pm 25 Mar 2025
In the CMM2 firmware the editor and file manager work on both an external serial console and the screen. The way it works is that the firmware builds the screen image using VT100 escape codes mixed with the text and when applicable a single function is called that outputs the codes on the serial port and interprets the codes to output to the display. For text only information this approach works well.
In this code DisplayPutC is effectively the same as TEXT MM.HPOS,MM.VPOS,A$  where A$ is a single character. It automatically wraps if it gets to the end of a line and also interprets CR and LF.
Changing gui_fcolour and gui_bcolour is the same as the COLOUR forground,background command.
gui_font_width is the same as MM.FONTWIDTH
MX470Cursor(0,0) is the equivalent of TEXT 0,0,""
This concept is how I would do it if trying to display text only information in colour on both outputs
void parseanddisplay(char *p, int len){
int i=0,j;
char seq[12];
while(i<len){
while(p[i]!='\033'){
DisplayPutC(p[i]);
i++;
i++;
if(p[i]=='['){ //escape sequence found
mymemset(seq,0,12);
j=0;
seq[j++]=p[i];
do {
i++;
seq[j++]=p[i];
} while (!(IsAlpha(p[i])));
if(seq[strlen(seq)-1]=='H'){
if(strlen(seq)==2){
MX470Cursor(0,0);
else {
int rows,cols;
sscanf(&seq[1], "%d;%d", &cols, &rows);
MX470Cursor((rows-1)*gui_font_width,(cols-1)*gui_font_height);
else if(strncmp(seq,"[K",2)==0){ // erase to end of line
int i=E.screencols-(CurrentX/gui_font_width);
while(i--)DisplayPutC(' ');
else if(strncmp(seq,"[?25l",5)==0)ShowCursor(false);
else if(strncmp(seq,"[?25h",5)==0)ShowCursor(true);
else if(strncmp(seq,"[36m",4)==0){gui_fcolour=CYAN;gui_bcolour=BLACK;}
else if(strncmp(seq,"[37m",4)==0){gui_fcolour=WHITE;gui_bcolour=BLACK;}
else if(strncmp(seq,"[32m",4)==0){gui_fcolour=GREEN;gui_bcolour=BLACK;}
else if(strncmp(seq,"[39m",4)==0){gui_fcolour=WHITE;gui_bcolour=BLACK;}
else if(strncmp(seq,"[35m",4)==0){gui_fcolour=MAGENTA;gui_bcolour=BLACK;}
else if(strncmp(seq,"[31m",4)==0){gui_fcolour=RED;gui_bcolour=BLACK;}
else if(strncmp(seq,"[34m",4)==0)gui_bcolour=BLUE;
else if(strncmp(seq,"[33m",4)==0){gui_fcolour=YELLOW;gui_bcolour=BLACK;}
else if(strncmp(seq,"[m",2)==0){
gui_fcolour=WHITE;
gui_bcolour=BLACK;
else if(strncmp(seq,"[7m",3)==0){
int i=gui_fcolour;
gui_fcolour=gui_bcolour;
gui_bcolour=i;
i++;
Edited 2025-03-26 04:42 by matherp
dddns
Posted: 07:57pm 25 Mar 2025
Many Thanks, I think I understood and giving a direction is more than useful!
