Local Time 11:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Using MMB4L but not an MMB4L problem
Posted: 12:56pm 17 Mar 2025
On a Pi 5, I'm trying to use MMB4L to retrieve and process the "ENERGY" values for a Sonoff POW R3 16 which has been flashed with Tasmota.
If I run this from the linux command prompt:
curl http://192.168.1.31/cm?cmnd=Status%208
I get this json payload back:
{"StatusSNS":{"Time":"2025-03-17T08:42:25","ENERGY":{"TotalStartTime":"2025-01-14T15:09:38","Total":242.301,"Yesterday":2.520,"Today":0.030,"Power":5,"ApparentPower":10, "ReactivePower":9,"Factor":0.44,"Voltage":123,"Current":0.085}}}
With MMB4L I get a bunch of header information before the data payload.
MMBasic for Linux aarch64 v0.7-alpha.1
Copyright 2011-2025 Geoff Graham
Copyright 2016-2025 Peter Mather
Copyright 2021-2025 Thomas Hugo Williams
> dim m%(100)
> system "curl http://192.168.1.31/cm?cmnd=Status%208",m%()
> longstring print m%()
 % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                Dload  Upload   Total   Spent    Left  Speed
100   233    0   233    0     0   1093      0 --:--:-- --:--:-- --:--:--  1093
I realize that the shell you get with MMB4L's "system" command may not be the same shell you have with the linux command prompt, and that is probably what is happening.
I do not see any obvious switch for curl to suppress the headers. Does anyone see how to get just the payload without further processing in MMB4L (e.g., INSTR to find "{" and then MID$ to extract the payload)?
Edited 2025-03-17 22:59 by lizby
Posted: 01:10pm 17 Mar 2025
Try adding --no-progress-meter to the curl command within the SYSTEM call.
Posted: 01:20pm 17 Mar 2025
Perfect. Thank you.
Asked and answered within 15 minutes. This forum cannot be beat.
