Local Time 11:35 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMedit, SELECT CASE bug
ville56
Posted: 10:18am 12 Mar 2025
@Jim,
please have a look at the following:
an empty CASE in a SELECT statement causes the "format indentation" to get nuts.
 '+++++++++++++ Main loop ++++++++++++++++
 do
   if rot_ef = 1 then
     rot_ef = 0
     select case rot_state
       CASE 1
     end select
     end if
     loop
if a line, even blank, is inserted, all is ok
 do
   if rot_ef = 1 then
     rot_ef = 0
       CASE 1
         'blank line
     end select
   end if
 loop
Gerald
73 de OE1HGA, Gerald
Posted: 01:35am 13 Mar 2025
Thanks.
It is a bug I am aware of but I haven't put a high priority on it.
ville56
Posted: 06:24am 13 Mar 2025
OK, thanks for your precious work. Using MMbasic would make only half the joy for me without MMedit and MMCC. Great contribution.
Gerald
PhenixRising
Posted: 07:36am 13 Mar 2025
  ville56 said  OK, thanks for your precious work. Using MMbasic would make only half the joy for me without MMedit and MMCC. Great contribution.
Gerald
circuit
Posted: 10:44am 13 Mar 2025
Gerald
I echo that appreciation; MMEDIT is in constant use across all my "mites".
