Forum Index : Microcontroller and PC projects : CMM2 sending prompts to Grok/Copilot/ChatGPT
| ManiB Senior Member Joined: 12/10/2019 Location: GermanyPosts: 190 |
Hello, I had the idea of using my CMM2 to send prompt inputs via the ESP-01 to an ESP gateway, which forwards the prompt to an AI and sends the response back to the CMM2. I have attached the MMBasic programme and the C# programme for the ESP gateway below. The communication does not necessarily have to run via an ESP-01 module, it could also work via the serial connection. But unfortunately I couldn't test it because API queries to the AI have to be paid for. Perhaps one of you has the ability to test this. MMBasic-Testprogramm: ' CMM2Grok: A simple MMBasic program to send prompts to Grok via ESP-01 Telnet ' Open the serial port COM2 with 115200 baud open "COM2:115200" as 4 ' Main program loop do ' Display prompt and read user input input "CMM2Grok - Enter your prompt (type QUIT to exit): ", prompt$ ' Check if the user entered "QUIT" if ucase$(prompt$) <> "QUIT" then ' Send the prompt to the ESP-01 print #4, prompt$ ' Wait for a response up to 5 seconds startTime = timer ' Get the current timer value in milliseconds endTime = 5000 ' Set 5 seconds response$ = "" ' Initialize response string do while (timer - startTime) < endTime ' Loop for 5 seconds if loc(4) > 0 then endTime = 200 response$ = response$ + input$(loc(4), 4) ' Append incoming data endif pause 10 ' Short pause to avoid high CPU usage loop ' Display the response if any was received if response$ <> "" then print "Response: "; response$ else print "No response received within 5 seconds" endif else ' Exit the program when "QUIT" is entered print "CMM2Grok exiting..." exit do endif loop ' Close the serial port close #4 Visual Studio C# Console Programm: using System; using System.IO; using System.Net.Sockets; using System.Text; using System.Net.Http; using System.Threading; using System.Threading.Tasks; //using System.Text.Json; namespace ESPGateway { /// <summary> /// ESP-Gateway: A simple Telnet bridge between an ESP-01 (ESP-Link) and the Grok API. /// Receives data from a CMM2 via Telnet, sends it to Grok, and forwards the response back. /// Released for the TheBackShed Forum, no external dependencies. /// Compatible with .NET Framework (e.g., 4.8). /// </summary> class Program { private static TcpClient client; private static NetworkStream stream; private static readonly string espIp = "192.168.178.100"; // IP of the ESP-01 private static readonly int espPort = 23; // Default Telnet port private static readonly string grokApiUrl = "https://api.xai.com/grok"; // Hypothetical Grok API URL private static readonly string grokApiKey = "YOUR_API_KEY"; // Replace with your API key private static readonly string copilotApiUrl = "https://api.copilot.microsoft.com/v1/engines/davinci-codex/completions"; // Copilot API URL private static readonly string copilotApiKey = "YOUR_API_KEY"; // Replace with your API key private static readonly string chatGptApiUrl = "https://api.openai.com/v1/chat/completions"; private static readonly string chatGptApiKey = "YOUR_API_KEY"; private static readonly string ai = "ChatGPT"; // selects ai "ChatGPT", "Copilot" or "Grok" static void Main(string[] args) { Console.WriteLine("ESP-Gateway starting..."); Console.WriteLine("Establishing connection to {0}:{1}", espIp, espPort); while (true) // Reconnection logic { try { // Establish Telnet connection (synchronous) client = new TcpClient(); client.Connect(espIp, espPort); // Synchronous instead of ConnectAsync stream = client.GetStream(); Console.WriteLine("Connected to ESP-01 Telnet"); // Start receiving data in a separate thread Task.Factory.StartNew(ReceiveData, TaskCreationOptions.LongRunning); // Keep the main thread alive Console.WriteLine("Press Enter to exit..."); Console.ReadLine(); break; // Exit program on user input } catch (Exception ex) { Console.WriteLine($"Connection error: {ex.Message}"); Console.WriteLine("Reconnecting in 5 seconds..."); Thread.Sleep(5000); // Wait before retrying (synchronous) } finally { stream?.Close(); client?.Close(); } } } /// <summary> /// Receives data from the ESP-01 and processes it. /// </summary> static void ReceiveData() { byte[] buffer = new byte[1024]; while (true) { try { if (stream.DataAvailable) { int bytesRead = stream.Read(buffer, 0, buffer.Length); // Synchronous read string data = Encoding.UTF8.GetString(buffer, 0, bytesRead).Trim(); Console.WriteLine($"Received from CMM2: {data}"); string response = ""; if (ai == "ChatGPT") { // Send data to ChatGPT (async call within sync method) response = SendToChatGPT(data).GetAwaiter().GetResult(); Console.WriteLine($"Response from ChatGPT: {response}"); } else if (ai == "Copilot") { // Send data to Copilot (async call within sync method) response = SendToCopilot(data).GetAwaiter().GetResult(); Console.WriteLine($"Response from Copilot: {response}"); } else if (ai == "Grok") { // Send data to Grok (async call within sync method) response = SendToGrok(data).GetAwaiter().GetResult(); Console.WriteLine($"Response from Grok: {response}"); } else { response = "AI_NOT_DEFINED!"; } // Send response back to ESP-01 byte[] responseBytes = Encoding.UTF8.GetBytes(response + "\r\n"); stream.Write(responseBytes, 0, responseBytes.Length); // Synchronous write stream.Flush(); } Thread.Sleep(100); // Reduce CPU load } catch (Exception ex) { Console.WriteLine($"Error receiving data: {ex.Message}"); break; // Exit loop on error (reconnection in Main) } } } /// <summary> /// Sends the prompt to the Grok API and returns the response. /// </summary> static async Task<string> SendToGrok(string prompt) { // Check if the API key is the placeholder, then return a dummy response if (string.Equals(grokApiKey, "YOUR_API_KEY")) { string dummyResponse = $"Grok says: Hello back to '{prompt}'!"; await Task.Delay(500); // Simulate network delay return dummyResponse; } using (var httpClient = new HttpClient()) { try { httpClient.DefaultRequestHeaders.Add("Authorization", $"Bearer {grokApiKey}"); var content = new StringContent( $"{{\"prompt\": \"{prompt}\"}}", Encoding.UTF8, "application/json" ); HttpResponseMessage response = await httpClient.PostAsync(grokApiUrl, content); if (response.IsSuccessStatusCode) { string result = await response.Content.ReadAsStringAsync(); // API response parsing would go here (e.g., JSON) return result; // Simplified, adjust to actual API } return $"API error: {response.StatusCode}"; } catch (Exception ex) { return $"API connection error: {ex.Message}"; } } } /// <summary> /// Sends the prompt to the Copilot API and returns the response. /// </summary> static async Task<string> SendToCopilot(string prompt) { // Check if the API key is the placeholder, then return a dummy response if (string.Equals(copilotApiKey, "YOUR_API_KEY")) { string dummyResponse = $"Copilot says: Hello back to '{prompt}'!"; await Task.Delay(500); // Simulate network delay return dummyResponse; } using (var httpClient = new HttpClient()) { try { httpClient.DefaultRequestHeaders.Add("Authorization", $"Bearer {copilotApiKey}"); var content = new StringContent( $"{{\"prompt\": \"{prompt}\", \"max_tokens\": 100}}", Encoding.UTF8, "application/json" ); HttpResponseMessage response = await httpClient.PostAsync(copilotApiUrl, content); if (response.IsSuccessStatusCode) { string result = await response.Content.ReadAsStringAsync(); // API response parsing would go here (e.g., JSON) return result; // Simplified, adjust to actual API } return $"API error: {response.StatusCode}"; } catch (Exception ex) { return $"API connection error: {ex.Message}"; } } } /// <summary> /// Sends the prompt to the ChatGPT API and returns the response. /// </summary> static async Task<string> SendToChatGPT(string prompt) { if (string.Equals(chatGptApiKey, "YOUR_API_KEY")) { await Task.Delay(500); return $"ChatGPT says: Hello back to '{prompt}'!"; } using (var httpClient = new HttpClient()) { try { httpClient.DefaultRequestHeaders.Add("Authorization", $"Bearer {chatGptApiKey}"); string requestBody = "{\"model\":\"gpt-4\",\"messages\":[{\"role\":\"user\",\"content\":\"" + prompt + "\"}],\"max_tokens\":200}"; var content = new StringContent( requestBody, Encoding.UTF8, "application/json" ); HttpResponseMessage response = await httpClient.PostAsync(chatGptApiUrl, content); if (response.IsSuccessStatusCode) { string result = await response.Content.ReadAsStringAsync(); return result; // API-Response als String zurückgeben } return $"API error: {response.StatusCode}"; } catch (Exception ex) { return $"API connection error: {ex.Message}"; } } } } } Edited 2025-03-10 09:17 by ManiB |
