Local Time 13:54 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Binary values in files
PilotPirx
Posted: 01:00pm 07 Mar 2025
Hello,
a question concerning MMBasic:
I want to read 8-bit binary values from a file. However, the examples in the manuals always refer to ASCII characters. How do I sequentially read a binary value from a non-text file?
Posted: 01:07pm 07 Mar 2025
You can input anything, I think. Try it!
You'll have to use the function INPUT$() I expect.
Posted: 01:10pm 07 Mar 2025
Naively:
' read-binary.bas
Dim s$
Open Mm.CmdLine$ For Input As #1
Do While Not Eof(#1)
 s$ = Input$(1, #1)
 Print Hex$(Asc(s$), 2) + " ";
Print
And run with:
RUN "read-binary.bas", "file-to-read.bin"
Edited 2025-03-07 23:10 by thwill
twofingers
Posted: 01:11pm 07 Mar 2025
ASCII characters are 8-bit binary values.
For example
Open fileName$ For Input As #1
 For x = 0 To pageSize
   buffer$(x) = Input$(1,#1)
 Next x
Close #1
MIchael
PilotPirx
Posted: 01:25pm 07 Mar 2025
That's it. I love this forum! Thank you!
William Leue
Posted: 02:40pm 07 Mar 2025
You can also use the SAVE DATA and LOAD DATA commands to save and restore variable values, including arrays. This is fast.
-Bill
zeitfest
Posted: 12:10am 08 Mar 2025
It's a pity MMBasic does not have a 8-bit (byte or char) datatype, AFAIK
Posted: 12:33am 08 Mar 2025
I think these
  Quote  MEMORY PACK source%()/sourceaddress%, dest%()/destaddress%, number, size
MEMORY UNPACK source%()/sourceaddress%, dest%()/destaddress%, number, size
or POKE / PEEK are as close as you will get.
Posted: 08:02am 08 Mar 2025
A Byte variable would probably take a lot more CPU power than it saves. The chip registers are 32 bits. If you want anything less you need CPU cycles and workspace to pack and unpack them. Of the two, memory is cheaper than CPU cycles if you want a fast system.
You can easily use a string as an array of 255 bytes by using POKE VAR and PEEK VAR with your index added to VARPTR for the string. No such trick for individual bits though, but at least you can store 255 values in 256 bytes of ram. Speed isn't great.
zeitfest
Posted: 10:14am 08 Mar 2025
Apart from the associated overheads involved I think MMBasic uses 8 bytes/64 bits for each numerical variable.
Posted: 10:27am 08 Mar 2025
  zeitfest said  Apart from the associated overheads involved I think MMBasic uses 8 bytes/64 bits for each numerical variable.
Each variable takes ~64 bytes because of the variable descriptor. Strings > 7 chars and arrays also allocate a minimum of 256 bytes from the heap. I believe that the variable storage and heap are still independent which is why the MEMORY command reports them separately.
And if anyone wonders why I'm sometimes vague on the internals it's because (as well as my bad memory) the PicoMite and MMB4L share a grandparent rather than a parent so there is an increasing divergence in their internals.
Edited 2025-03-08 20:34 by thwill
twofingers
Posted: 12:39pm 08 Mar 2025
  thwill said  ... Each arrays also allocate a minimum of 256 bytes from the heap. ...
Do you mean for every element? I don't think so. I wouldn't say it like that.
Dim string test$(90000) length 1
For i = 0 To 90000
test$(i)=Right$(Str$(i),1)
Print @(0)i,test$(i);
Next
Print
Print "Heap: ";MM.Info(Heap)
Print
Memory
End
Michael
Posted: 12:50pm 08 Mar 2025
  twofingers said  Do you mean for every element? I don't think so.
I didn't say it was for every element, I said an array takes a minimum of 256 bytes of heap.
If the array requires more storage it is allocated in additional 256 byte pages.
A native BYTE type would't save any memory, but would provide convenience over PEEK and POKE.
Posted: 12:56pm 08 Mar 2025
... If you wanted to be pedantic arrays of 8 BYTEs or less could be implemented so they don't require the additional 256 bytes of an array.
twofingers
Posted: 01:07pm 08 Mar 2025
@Tom
Thanks for the clarification.
