Local Time 13:54 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 'flags' in interrupt routine
58kk90
Posted: 02:46pm 05 Mar 2025
Another 'numpty' question from a newbie.
I have started playing with pin change interrupts on the Pico, and as the manual says the idea is to have as little going on in the actual intetrupt routine as possible, generally just set a flag to indicate something changed etc.
In previous micro's (going back to 8048 / 8051 and then PIC and Arduino ) I would have a byte called for example 'flags' then set individual bits to indicate the event, i'd set each bit in the interrupt routine and then clear it in the main code.
In Pico basic, there doesn't seem to be a byte variable type, which is fine, but how do you folks flag that something has changed in the interupt routine without using a 64bit variable for each event, which seems quite wasteful to me.
Obviously I coud do this
Dim PinChanged as integer
PinChanged =  0
then in the interrupt routine set PinChanged to '1' and then act on it in the main program and set it back to zero, but I feel there must be a better and more efficient way that uses less variable space as it is only using a single 'bit' out of each 64 bit integer variable, if there are lots of different flags does that not use up valuable ram space?
Or is there enough variable space that I need not worry about it and do  it the way I suggested above?
Tony
twofingers
Posted: 03:04pm 05 Mar 2025
Hi Tony,
one possibility would be to use 1-byte strings (actually 2 bytes = Dim myflag$ string  LENGTH 1). The decoding effort would probably cancel out the benefit.
I wouldn't worry about the memory consumption for integers at first, only for very large projects.
Michael
I recently considered using the individual bits of an integer as flags for selected files in the file manager, but that's not worth the extra effort.
Edited 2025-03-06 01:16 by twofingers
Posted: 03:39pm 05 Mar 2025
As Michael suggests, other than for exceptionally large programs, it is a waste of valuable programmer time to try to save extraordinarily cheap bits in MMBasic.
So don't sweat the small stuff, and save your effort for the main chance.
(As a one-time Z80 programmer, I understand the compulsion--if it drives you to save those bits, Cap'n Boing has routines on FruitOfTheShed ( FOTS  ).)
Posted: 03:58pm 05 Mar 2025
Hi @twofingers,
  twofingers said  one possibility would be to use 1-byte strings (actually 2 bytes = Dim myflag$ string  LENGTH 1).
I've not explicitly checked the PicoMite firmware but I don't think that works the way you think it does. All memory allocation in MMBasic is in 256 byte blocks and as a result all (scalar) strings take 256 bytes from the heap, the LENGTH specifier only applies when allocating arrays of strings.
I *think* that Peter added a hack to the Colour Maximite 2 firmware that allows very small strings 1 - 7 (or maybe 8) characters to be stored with the variable storage rather than on the heap but I don't think that hack is present on the PicoMite ... Peter may correct me.
In answer to the OP you can use PEEK and POKE to access single bytes of an INTEGER or engage in bit twiddling, e.g. https://github.com/thwill1000/mmbasic-sptools/blob/master/src/splib/bits.inc or whatever the Captain has posted on https://fruitoftheshed.com.
Edited 2025-03-06 02:02 by thwill
twofingers
Posted: 04:27pm 05 Mar 2025
@Tom,
Thanks for the hint, I think you're right, I vaguely remember.
The manual doesn't help here either.
Best regards
Michael
PhenixRising
Posted: 04:47pm 05 Mar 2025
  58kk90 said  Another 'numpty' question from a newbie.
For efficient serial binary transfers, I set bits:
dim integer a
a=a or 1
a=a or 2
a=a or 4
a=a or 8
a=a or 16
a=a or 32
a=a or 64
a=a or 128
'a now equals 255
if a and 2 then
 a = a xor 2 ' reset the flag
end if
'a now equals 253
58kk90
Posted: 05:11pm 05 Mar 2025
Thank you to all who replied, I guess it's use a single variable for each flag bit then.
@PhenixRising that is probably very close to how I would have eventually done it had I used a single variable for all flags, I wondered if there was something along the line of flags.1 for bit 1 or flags.2 for bit 2 and so on and it just wasn't documented,
but I guess that would require 'flags' to be a byte variable, which we don't have.
Tony.
ville56
Posted: 05:13pm 05 Mar 2025
I usually define bitmasks as constants with meaningful names. AND and OR operators do the setting and testing. So i can use a single integer as an eventflag cluster for up to 64 flags.
Gerald
73 de OE1HGA, Gerald
PhenixRising
Posted: 06:00pm 05 Mar 2025
  ville56 said  I usually define bitmasks as constants with meaningful names. AND and OR operators do the setting and testing. So i can use a single integer as an eventflag cluster for up to 64 flags.
Gerald
Sure but unlike a compiler, the constants are not replaced with literals and so the interpreter loses time finding the value of those constants, right?
I haven't heard much about MMReplace but from what I understand, it's a post-processor(?) where constants and long variable names can be replaced just prior to sending to the Mite(?)
Posted: 07:44pm 05 Mar 2025
like this?
https://fruitoftheshed.com/wiki/doku.php?id=mmbasic:bit_manipulation_functions
I use these routines (and my timer pack) ***EXTENSIVELY*** in my code. actually the ones I use are really optimised for speed. I can post that if you want
Edited 2025-03-06 05:47 by CaptainBoing
ville56
Posted: 08:11pm 05 Mar 2025
Sure  you can either optimize runtime or memory consumption. Variable names are hashed as i understood to speed up the lookup. But it still is an interpreter.
PhenixRising
Posted: 08:54pm 05 Mar 2025
@CaptainBoing
  Quote  'Clear a flag
Sub FlagRes(b As Integer)
Flag=Flag Or &o1<<b Xor &o1<<b
So we OR followed by XOR to clear a bit whose state is not known.
In other BASICs I can use AND NOT to achieve the same. Doesn't work in MMBasic though.
Posted: 09:27pm 05 Mar 2025
Unless you're desperate for every byte of memory just (KISS) use one variable per flag. Easy to read, easy to write, easy to maintain, easy to reuse.
It'll be much faster than some of the stuff just posted, too, especially in the interrupt routine.
ville56
Posted: 09:39pm 05 Mar 2025
use INV instead of NOT.
e.g. Flag=Flag and inv (1<<b)
should work this way ....
PhenixRising
Posted: 10:18pm 05 Mar 2025
  ville56 said  use INV instead of NOT.
I don't believe so (away from my PicoMite)
If the flag is already zero and I want to set to zero, INV will make it a one.
Using OR and XOR works because OR will always set the flag to a one, no matter the existing state.
Posted: 11:48pm 05 Mar 2025
Looks OK.
PRINT HEX$(INV (1<<b))
can be used to check.
Posted: 04:01am 06 Mar 2025
  Quote  Looks OK.
Yes.
> a=3 : b=4 : c=0 'a, b = individual flags, c = 64 bit combined flags
> c = c or (1<<a) :? bin$(c,64) 'set flag a in c
0000000000000000000000000000000000000000000000000000000000001000
> c = c or (1<<b) :? bin$(c,64) 'set flag b in c
0000000000000000000000000000000000000000000000000000000000011000
> c = c and (inv (1<<a)) :? bin$(c,64) 'reset flag a
0000000000000000000000000000000000000000000000000000000000010000
> c = c and (inv (1<<a)) :? bin$(c,64) 'repeat to check that flag a doesn't invert
But as previously mentioned it saves very little.
More could be saved by putting a number of short strings in one string with mid$().
Posted: 06:58am 06 Mar 2025
I do not know your application.
But if speed is some form of important, use 64bit integers.
The math the ARM must do to execute most commands is peanuts compared to the time it takes the interpreter to decode the basic command.
In general: fewer basic commands = higher speed.
so
a%=pin(gp0)
if a% then
is so much faster than manipulating bits in a 64 bit integer.
Posted: 07:55am 06 Mar 2025
Agreed. Especially in an interrupt routine where you don't want to hang about.
You can do bit twiddling elsewhere, but I wouldn't recommend it in interrupts.
  phil99 said  More could be saved by putting a number of short strings in one string with mid$().
Yes, at the cost of a slower interrupt routine.
I'd go for an integer flag to keep the interrupt routine short, simple and fast.
Saving maybe 7 bytes doesn't seem vital.
Using a string has memory overheads, too, so I'd go for bits within an integer if I was absolutely desperate for RAM space (which seems vanishingly unlikely to this extent).
