Local Time 17:46 24 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : RP2350B weact
guma1975
Posted: 10:03am 04 Mar 2025
Hello.
I ordered this pcb from here.
https://pl.aliexpress.com/item/1005008404804398.html?aff_fcid=462c03b2748148e6b5581318d53135f1-1741081937572-06119-_oofC5PP&tt=CPS_NORMAL&aff_fsk=_oofC5PP&aff_platform=shareComponent-detail&sk=_oofC5PP&aff_trace_key=462c03b2748148e6b5581318d53135f1-1741081937572-06119-_oofC5PP&terminal_id=37e83931330948c2abe9075449702469&afSmartRedirect=y&gatewayAdapt=glo2pol
https://www.cnx-software.com/2025/02/03/tiny-weact-rp2350b-core-board-exposes-all-48-i-os-from-the-raspberry-pi-rp2350b-microcontroller/
I wonder if it will work on all pins.
PS Sorry for my English, but I'm old enough to use a translator. Best regards.
javavi
Posted: 12:45pm 04 Mar 2025
Edited 2025-03-04 22:54 by javavi
PhenixRising
Posted: 12:54pm 04 Mar 2025
  guma1975 said  Hello.
Tip: Your aliexpress link only needs to be up to the "?"
  Quote  https://pl.aliexpress.com/item/1005008404804398.html
Furthermore, if you use the button:
You can create a direct link
Posted: 01:00pm 04 Mar 2025
It will probably meet the Raspberry Pi specification. I wouldn't take any bets on it exceeding the specification though.
Personally I wouldn't buy one until I had the schematic.
Edited 2025-03-04 23:01 by Mixtel90
guma1975
Posted: 01:04pm 04 Mar 2025
it's actually enough for this
Edited 2025-03-04 23:07 by guma1975
PhenixRising
Posted: 01:07pm 04 Mar 2025
Schematic shows USB-C. At first, I thought it was micro-USB.
RP2350B_SCH.pdf
Posted: 01:29pm 04 Mar 2025
Sensible people. They put PSRAM CS on GP0 and the LED on GP25.
dddns
Posted: 03:44pm 04 Mar 2025
I really like the layout of this WeAct as there is no need to route the traces on a PCB through the pins. It only lacks on having the bootsel broken out and that it has no PSRAM by default (but you can easily solder it).
The best layout (for Hobbyists) is Peters 64-pin dual-in-line RP3250B development board
Too bad that it wont't be produced, but hope dies last
@guma1975 Please report back when you got it how overclocking works.
Posted: 05:04pm 04 Mar 2025
Who says it won't? There is some demand for a RP2350B wired to pins that is breadboard friendly. No other implementation has done that so far. It just needs someone to see it and decide to back it.
RENATO
Posted: 03:07pm 13 Oct 2026
In my opinion, this would be a real springboard for the work conceived and done by Geoff Graham. And the community could support this version and not go crazy supporting 1000 versions of the firmware. What do you think? Ronny
Posted: 03:29pm 13 Oct 2026
  Quote  And the community could support this version and not go crazy supporting 1000 versions of the firmware. What do you think? Ronny
Perhaps you should read into the subject more before pontificating. There aren't 1000 of versions. There are versions supporting RP2040 vs RP2350, VGA vs HDMI vs LCD, Web vs Bluetooth vs neither. All of these are in general H/W agnostic and can be configured by the user to suit a wide variety of boards with different pinouts.
Posted: 07:16pm 13 Oct 2026
Ronny:
MMBasic on the Picomite is *specifically designed* to be able to run on varied hardware. Yes, you could make a single version, but that would rule out all future hardware development unless you kept producing new versions of MMBasic.
If you want a single MMBasic file then I suggest that you get a Pico Computer 3 board (or my own PC3x DIY modular design which is more or less functionally the same). You can then configure everything automatically using a single OPTION command.
There is no problem in producing your own hardware that is incompatible with the Pico Computer 3. It's just a little more involved in configuring it. MMBasic is very flexible. Such hardware may be optimised for a particular task.
Gerad
Posted: 08:40pm 13 Oct 2026
A reliable board. I just bought 10 of them. The size reminds me of the Intel 486. WeAct PSRAM CS  is connected to GP0. Perhaps the PSRam option can also be set to GP0. If not—no problem—remove R14 and connect the solder pad to GP47, and the PSRAM will work. This is described several times on the forum.
RM2 Wi-Fi module. Connect the GP23, GP24, GP25, and GP29 to the RM2. To ensure the board runs without a reset, you’ll need to remove the zero-ohm resistor on the WeAct board (see photo).Firmware Webmite 7.0.00B8 works without any patches, etc., without any problems.
Gerad
Edited 2026-10-14 06:50 by Gerad
Wölfi
Posted: 02:01pm 15 Oct 2026
  Mixtel90 said  There is some demand for a RP2350B wired to pins that is breadboard friendly.
I really like the Weact-Boards and for me breadboarding with it is no issue, for myself i solved it just like this:
Just taken the connectors from above with female header pins and some sticky tape right under it ("Nano-Tape").
Such adaptors are actually not necessary:
https://youtu.be/nIj9mBf7mcs?t=143
I think those make it much more complicated.
--- by the way for german users (or I think also dutch) if available in a local ACTION store:
https://www.action.com/de-de/p/3010756/nano-tape/
great stuff, cheap and reliable.
Posted: 02:16pm 15 Oct 2026
I did a PCB for that module some time ago. Here
The audio side didn't work well but everything else was fine. I fitted a PSRAM chip.
Wölfi
Posted: 03:02pm 15 Oct 2026
Really neat!
Another idea I’ll try next is to use long pin headers to bring all the connectors to the top of the standalone Picomite carrier board, plugging into the female headers underneath and passing right through the top cover.
Even on a PCB like yours, such long pins would provide a great opportunity to access the same connectors directly.
