Local Time 16:03 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question regarding RP2350 with PSRAM
dddns
Posted: 06:29pm 28 Feb 2025
This question is regarding HDMI and I do not want to spam another thread:
Is it possible to increase the color depth in the current HDMI modes while leaving the clockrate unchanged? Is it just a question of RAM amount? What is the future plan?
I'm asking because I would of cause not hesitate to exchange my ssd1963 LCD against an IPS panel with the size of my choice if it would be possible and implemented.. ..I would like to know to have a plan for myself on how to go on further.
Of cause everybody is invited to answer (the main question)!
Posted: 07:02pm 28 Feb 2025
No: PSRAM isn't fast enough to use as a framebuffer
Posted: 07:47pm 28 Feb 2025
Deleted--posted in wrong thread.
Edited 2025-03-01 05:50 by lizby
dddns
Posted: 07:58pm 28 Feb 2025
  matherp said  No: PSRAM isn't fast enough to use as a framebuffer
Thank you, I think I got it.
The physical framebuffer which delivers the actual picture is realized with the RAM of the pico and processed through the pico in contrast to LCD, where this job is done by the display controller and the internal RAM.
dddns
Posted: 08:19pm 28 Feb 2025
Never the less PSRAM would be fast enough to have 25frames/s at about 160x96 in rgb888 on the ssd. That's almost the size ov7670 delivers. So a "videoeditor.bas" with the option of creating a video with live pictures is not unthinkable :)
I mean with only the use of the blit command.
Edited 2025-03-01 06:21 by dddns
dddns
Posted: 05:11pm 01 Mar 2025
  dddns said  Never the less PSRAM would be fast enough to have 25frames/s at about 160x96 in rgb888 on the ssd. That's almost the size ov7670 delivers. So a "videoeditor.bas" with the option of creating a video with live pictures is not unthinkable :)
Wrong nonsense, sorry.
I found, that only a rp2350 with 8Mb PSRAM and an ILI9341  LCD will be enough, to have roundabout amazing 2.5seconds of 240*130 RGB888 fully flicker free video sequence in 25 frames/s!
This is possible already for months since the implementation of PSRAM.
I saw trees, but not the forest.
Edited 2025-03-02 03:32 by dddns
dddns
Posted: 05:45pm 01 Mar 2025
I did a proof of concept and have a 1,3sec sequence running only by using blit.
There is a command "blit,x,y,x1,y1,w,h" but sadly only to copy content within the physical screen. Copying between blit buffers seems to be not possible.
dddns
Posted: 10:26am 03 Mar 2025
Sample of reading 32 blits of 260x190(that's max for 9341@25frames/s) extracted .bmp frames and then displaying them in
32/25 = 1.28sec length clip on a PGA2350 and ILI9341. Memory shows:
> memory
Program:
  1K ( 1%) Program (37 lines)
255K (99%) Free
Saved Variables:
 16K (100%) Free
RAM:
  1K ( 0%) 5 Variables
4632K (71%) General
1815K (29%) Free
so there is some space left but the blit slots are saturated.
I think it would be a real valuable improvement for everyone using LCDs, to increase the number of available blit slots and to extend the existing
blit x1,y1,x2,y2,w,h
with parameters for source and destination.
Beside just playing a sequence as video, it would be easily possible to generate amazing effects like let a photo realistic man walk through the picture or a digital picture frame with nice animations.
ILI9341.mp4.zip
Posted: 01:43pm 03 Mar 2025
Hi dddns,
Look at "blit memory".
dddns
Posted: 02:13pm 03 Mar 2025
  Volhout said  Hi dddns,
Did not try that yet as I read the manual and thought, that it is only rgb121
Will do :)
Posted: 02:21pm 03 Mar 2025
Blit memory may be "tricked" into doing what you want.
If you just need to copy blocks of memory, use "memory copy".
