Local Time 14:38 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Daylight Saving
palcal
Posted: 09:25pm 27 Feb 2025
FOTS has a daylight saving function Here
This is for the UK where DS starts and ends on the Last Sunday for different months to Australia. It's beyond me to change this for our region.
Has anyone changed this for Australia or have another function for DS.
disco4now
Posted: 09:52pm 27 Feb 2025
Adjusted for southern hemisphere in this thread
F4 H7FotSF4xGT
palcal
Posted: 10:06pm 27 Feb 2025
Thanks for that, will try.
Posted: 10:19pm 27 Feb 2025
It would appear that program preceded the addition of the inbuilt DAY$() function.
Finding the first Sunday may be easier with something like:-
If Day$(Date$) = "Sunday" then ...
palcal
Posted: 10:53pm 27 Feb 2025
I did have a SUB using that, but it didn't work too well so before I tried anything, I thought I would ask.
I need something that if power is applied after DS has started it still recognised.
Edited 2025-02-28 08:56 by palcal
GerryL
Posted: 11:29pm 27 Feb 2025
here is an alternative that I have extracted from my original weather station program, the sub test at the bottom was a check to see it worked on rollover in April and October.  The only changes you would need is the CONSTANTS of cSTD_TIME_ZONE and CDTS_TIME_ZONE
 dim integer gn_UTCHour
 dim integer gn_UTCMin
 dim integer gn_UTCSec
 dim integer gn_UTCDate
 dim integer gn_UTCMonth
 dim integer gn_UTCYear
 dim integer gn_UTCDay
 dim integer gn_LocalHour
 dim integer gn_LocalDate
 dim integer gn_LocalMonth
 dim integer gn_LocalYear
 dim integer gn_LocalDay
 dim integer gn_LocalMins
 dim integer gn_LocalSecs
 ' time conversion
 CONST cSTD_TIME_ZONE = 9.5 ' Adelaide
 CONST CDTS_TIME_ZONE = 10.5
 CONST cSTANDARD_TIME_ZONE = cSTD_TIME_ZONE * 3600 ' + seconds, (i.e South Australia Central Standard Time, +9.5 Hrs from Z time)
 Const cLOCAL_TIME = 1
 Const cZULU_TIME = 2 ' GMT, time zone =0
FUNCTION GetDSTStart(ls_Year as String, ln_TimeType as Integer) as integer
' returns time in seconds since 1970 of the actual first second of DST
' DST start occurs at 0200 local on First Sunday in October or 1630Z on Saturday just prior to First Sunday in October
' ls_Year is the year for the calculation in format of "yyyy"
' ln_TimeType determines what the start time will be referenced to, i.e. Zulu (GMT) or local time.
 local as integer ln_Start
 ln_Start = EPOCH("01-10-" + ls_Year + " 02:00:00") + GetOffsetSeconds(ls_Year, "10") ' 2am first sunday of October
 if ln_TimeType = cZULU_TIME then ln_Start = ln_Start - cSTANDARD_TIME_ZONE '1630Z on Sat prior to first Sunday of Oct
 GetDSTStart = ln_Start
end Function
FUNCTION GetDSTEnd(ls_Year as String, ln_TimeType as Integer) as integer
' returns time in seconds since 1970 of the actual first second of Standard Time (non DST period) in UTC (Z or GMT Time)
' DST end occurs at 0300 local on First Sunday in April or 1630 UTC on Saturday just prior to First Sunday in  April
 local as integer ln_End
 ln_End = EPOCH("01-04-" + ls_Year + " 03:00:00") + GetOffsetSeconds(ls_Year, "04") ' 3am fist sunday of April
if ln_TimeType = cZULU_TIME then ln_End = ln_End - cSTANDARD_TIME_ZONE - 3600 '1630Z on Sat prior to first Sunday of month
GetDSTEnd = ln_End
end Function
Function GetOffsetSeconds(ls_Year as String, ls_Month as String) as integer
'e.g if month starts on a Monday then returns 86400 *6, Tuesday is 86400 * 5, Sunday = 0
 local as integer ln_Offset
 local as String ls_Day
 ls_Day = DAY$("01-" + ls_Month + "-" + ls_Year)
 SELECT CASE ls_Day
   CASE "Sunday"
     ln_Offset = 0
   CASE "Monday"
     ln_Offset = 1
   CASE "Tuesday"
     ln_Offset = 2
   CASE "Wednesday"
     ln_Offset = 3
   CASE "Thursday"
     ln_Offset = 4
   CASE "Friday"
     ln_Offset = 5
   CASE "Saturday"
     ln_Offset = 6
   CASE ELSE
     ln_Offset = 0 ' error if here
   END SELECT
   if ln_Offset <> 0 then
     ln_Offset = 7 - ln_Offset
     ln_Offset = ln_Offset * 86400 ' now seconds
   endif
   GetOffsetSeconds = ln_Offset
End Function
SUB StringUTCtoLocal (sYear as string, sDateTime as string)
' sYear as 20xx, sDateTime = dd-mm-yyyy hh:mm:ss
local as integer ln_UTCTime, ln_StartDST, ln_EndDST, ln_LocalTime
ln_StartDST = GetDSTStart(sYear,cZULU_TIME) 'Oct
   ln_EndDST = GetDSTEnd(sYear, cZULU_TIME) 'April
'print "date time = ",sDateTime
ln_UTCTime = EPOCH(sDateTime)
'print "UTC = ", ln_UTCTime, " Start = ",ln_StartDST, "End = ", ln_EndDST
   if ln_UTCTime < ln_StartDST AND ln_UTCTime > ln_EndDST then 'less than oct and more than april
     gf_LocalTimeZone =cSTD_TIME_ZONE
   else
     gf_LocalTimeZone = CDTS_TIME_ZONE
   end if
  ln_LocalTime = ln_UTCTime + gf_LocalTimeZone * 3600
   sDateTime = DATETIME$(ln_LocalTime) ' dd-mm-yyyy hh:mm:ss
  ' print "date Time = ",ls_TempString1
   gn_LocalDate = val(left$(sDateTime,2)) 'dd
gn_LocalMonth = val(mid$(sDateTime,4,2)) 'month
gn_LocalYear = val(mid$(sDateTime,7,4)) 'year, 4 digit
gn_LocalHour = val(mid$(sDateTime,12,2)) 'hour
gn_LocalMins = val(mid$(sDateTime,15,2)) 'min
gn_LocalSecs = val(mid$(sDateTime,18,2))
END SUB
SUB Test
' convert UTC to local
StringUTCtoLocal ("2025", "05-04-2025 16:29:59")
print "UTC Input = ","05-04-2025 16:29:59"
print "LOCAL Out = ",gn_LocalDate, "-", gn_LocalMonth,"-",gn_LocalYear,"   ",gn_LocalHour,":",gn_LocalMins,":",gn_LocalSecs
StringUTCtoLocal ("2025", "05-04-2025 16:30:01")
print "UTC Input = ","05-04-2025 16:30:01"
StringUTCtoLocal ("2025", "04-10-2025 16:29:59")
print "UTC Input = ","04-10-2025 16:29:59"
StringUTCtoLocal ("2025", "04-10-2025 16:30:01")
print "UTC Input = ","04-10-2025 16:30:01"
End SUB
Test
Posted: 12:22am 28 Feb 2025
 ' as shown, dst starts on the first sunday of April
 ' change the month in the mth1start line to suit and add 7 for second sunday etc.
 ' for last sunday, use the following month and subtract 7 from the dst1
 ' do the same for mth2start and dst2
 ' for the northern hemosphere. reverse the final IF statement
FUNCTION dst()
 LOCAL mth1start, mth2start, dst1, dst2, dateNow$, daynumnow
 dateNow$ = DATE$
 daynumnow = EPOCH(dateNow$+" 00:00:00")/86400
 mth1start = EPOCH("01-04-"+MID$(dateNow$,7,4)+" 00:00:00")/86400
 dst1 = 3-(mth1start MOD 7)
 dst1 = mth1start+dst1 ' first sunday in april in current year. add 7 for 2nd sunday
 mth2start = EPOCH("01-10-"+MID$(dateNow$,7,4)+" 00:00:00")/86400
 dst2 = 3-(mth2start MOD 7)
 dst2 = mth2start+ dst2 ' first sunday in october in current year. add 7 for 2nd sunday
 IF daynumnow < dst1 OR daynumnow >= dst2 THEN ' swap for northern hemisphere
   dst = 1
 ELSE
   dst = 0
 ENDIF
END FUNCTION
palcal
Posted: 12:31am 28 Feb 2025
Thanks all, I'll have a play around.
palcal
Posted: 01:10am 28 Feb 2025
@ TassyJim
I tested your code by putting in a dummy date, it works OK BUT I had to change the last lines to
  dst = 0
ELSE
  dst = 1
ENDIF
END FUNCTION
I reversed dst = 0 and dst = 1
Posted: 01:24am 28 Feb 2025
TassyJim's method is excellent, simpler than any other that I have seen.
This version lets you put in any test date. If the brackets are empty it works as before.
If you need to invert DST add
DS = NOT DST()
to your program.
' TassyJim's amended Daylight Saving function
' If a date (as a string) is specified such as "28/02/2025" it is used, else Date$ is uesd.
Function dst(TestDate$)
 Local mth1start, mth2start, dst1, dst2, dateNow$, daynumnow
 If TestDate$ = "" Then
   dateNow$ = Date$
  Else
   dateNow$ = TestDate$
  daynumnow = Epoch(dateNow$+" 00:00:00")/86400
 mth1start = Epoch("01-04-"+Mid$(dateNow$,7,4)+" 00:00:00")/86400
 dst1 = 3-(mth1start Mod 7)
 mth2start = Epoch("01-10-"+Mid$(dateNow$,7,4)+" 00:00:00")/86400
 dst2 = 3-(mth2start Mod 7)
 If daynumnow < dst1 Or daynumnow >= dst2 Then ' swap for northern hemisphere
   dst = 1
 Else
   dst = 0
End Function
> ? dst()
1
> ? dst("07-04-2025")
0
> ? not dst()
0
> ? not dst("07-04-2025")
1
Footnote added 2025-02-28 12:33 by phil99
Removed the extra variable, it is redundant.
Function dst(dateNow$)
Local mth1start, mth2start, dst1, dst2, daynumnow
If dateNow$ = "" Then dateNow$ = Date$
Footnote added 2025-02-28 20:48 by phil99
> for n=22 to 31:d$=str$(n)+"-03-2025":? d$, dst(d$), day$(d$) :next
22-03-2025       1      Saturday
23-03-2025       1      Sunday
24-03-2025       1      Monday
25-03-2025       1      Tuesday
26-03-2025       1      Wednesday
27-03-2025       1      Thursday
28-03-2025       1      Friday
29-03-2025       1      Saturday
30-03-2025       0      Sunday
31-03-2025       0      Monday
palcal
Posted: 01:48am 28 Feb 2025
My stupid mistake it starts in Oct so yes we are in DS now if you don't live in Qld.
Edited 2025-02-28 11:53 by palcal
Turbo46
Posted: 03:51am 28 Feb 2025
You could see Geoff’s Super Clock for an example.
palcal
Posted: 04:48am 28 Feb 2025
@ Turbo46....I looked at that but got lost in all the code.
Posted: 11:13am 28 Feb 2025
  phil99 said  TassyJim's method is excellent,
I have yet to see any garbage from him... the man's a machine!
In my defence    I program almost exclusively for MicroMites so i don't have the luxury of EPOCH() etc. Probably a lot to ask everyone to remember that... there are always improvements and I love to see them.
h
Edited 2025-02-28 21:23 by CaptainBoing
Posted: 11:46am 28 Feb 2025
My last footnote shows DST ending on the last Sunday in March instead of the first in April.
Something to look into.
Posted: 08:20pm 28 Feb 2025
I will have to check the code.
In Australia
Daylight Saving Time (DST) is used in the Australian Capital Territory, New South Wales, South Australia, Tasmania, and Victoria.
It starts the 1st Sunday of October and ends the 1st Sunday of April.
This is a political decision so anything can happen to change those dates.
I do have a pre epoch() version of the function somewhere...
Edited 2025-03-01 06:23 by TassyJim
Posted: 08:39pm 28 Feb 2025
I had over simplified the code.
Should have left it alone...
FUNCTION dst(TestDate$)
IF TestDate$ = "" THEN
  dateNow$ = DATE$
 ELSE
ENDIF
dst1 = (10-(mth1start MOD 7)MOD 7)
dst2 = (10-(mth2start MOD 7)MOD 7)
  dst = 1
ELSE
  dst = 0
ENDIF
END FUNCTION
Posted: 09:05pm 28 Feb 2025
Perfect, tested April and October for next 4 years plus 2050.
Streamlined my "If TestDate" add-on. Extra variable not needed
 dst1 = (10-(mth1start Mod 7)Mod 7)
 Inc dst1, mth1start ' first sunday in april in current year. add 7 for 2nd sunday
 dst2 = (10-(mth2start Mod 7)Mod 7)
 Inc dst2, mth2start ' first sunday in october in current year. add 7 for 2nd sunday
   dst = 1
 Else
   dst = 0
End Function
Edited 2025-03-01 07:23 by phil99
Posted: 09:39pm 28 Feb 2025
Sorry, still stuffed it. Bracket in wrong place.
This is better:
 DIM startdate$= "01-01-2024"
 DIM startday, tdate$,n,dstchange = 1
 startday = EPOCH(startdate$+" 00:00:00")/86400
 FOR n = 0 TO 3660
   tdate$ = LEFT$(DATETIME$((startday+n)*86400),10)
   IF dst(tdate$) <> dstchange THEN
     dstchange = dst(tdate$)
     PRINT tdate$
   ENDIF
 NEXT n
   dateNow$ = DATE$
 ELSE
 ENDIF
 dst1 = (10-(mth1start MOD 7))MOD 7
 dst2 = (10-(mth2start MOD 7))MOD 7
   dst = 1
 ELSE
   dst = 0
 ENDIF
END FUNCTION
Posted: 02:29am 01 Mar 2025
A version for the micromites without epoch()
dstchange = 1
startday = toJD(startdate$)
 FOR n = 0 TO 3660
   tdate$ = datex$(startday+n)
   IF dstx(tdate$) <> dstchange THEN
     dstchange = dstx(tdate$)
     PRINT tdate$
   ENDIF
 NEXT n
FUNCTION dstx(dateNow$) AS INTEGER
 LOCAL INTEGER mth1start, mth2start, dst1, dst2, daynumnow
 IF dateNow$ = "" THEN
   dateNow$ = DATE$
 ENDIF
 daynumnow = toJD(dateNow$)
 mth1start = toJD("01-04-"+MID$(dateNow$,7,4))
 dst1 = (13-(mth1start MOD 7))MOD 7
 mth2start = toJD("01-10-"+MID$(dateNow$,7,4))
 dst2 = (13-(mth2start MOD 7))MOD 7
   dstx = 1
 ELSE
   dstx = 0
 ENDIF
END FUNCTION
FUNCTION toJD(myDate$)' valid for Gregorian dates after Oct 15, 1582
LOCAL d, m, y, ff
d = VAL(LEFT$(myDate$,2))
m = VAL(MID$(myDate$,4,2))
y = VAL(RIGHT$(myDate$,4))
ff=FIX((m-14)/12)
toJD = FIX((1461*(y+4800+ff))/4)+FIX((367*(m-2-12*ff))/12)-FIX((3*(FIX(y+4900+ff)/100))/4)+d-32075
END FUNCTION
FUNCTION datex$(jd)' valid for Gregorian dates after Oct 15, 1582
LOCAL l,n,i,j,d,m,y
l = jd+68569
n = FIX((4*l)/146097)
l = l-FIX((146097*n+3)/4)
i = FIX((4000*(l+1))/1461001)
l = l-FIX((1461*i)/4)+31
j = FIX((80*l)/2447)
d = l-FIX((2447*j)/80)
l = FIX(j/11)
m = j+2-(12*l)
y = 100*(n-49)+i+l
datex$ = STR$(d,2,0,"0")+"-"+STR$(m,2,0,"0")+"-"+STR$(y,2)
END FUNCTION
It should work with integers or floats.
