Local Time 13:54 25 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Reading the console's output?
ebbandflow
Posted: 03:01pm 20 Feb 2025
I have been reading and searching, but figure ASKING couldn't hurt either.
Is there a way (for instance), to read the console's output into a string for use by the running program? Or perhaps there a console output buffer that can be accessed?
twofingers
Posted: 03:06pm 20 Feb 2025
AFAIK: NO.
(I'm also looking for a way to redirect the output, similar to batch files.)
Michael
Posted: 03:12pm 20 Feb 2025
link the Console Tx pin to the COM1 Rx pin then read it from there
ebbandflow
Posted: 04:13pm 20 Feb 2025
Thank you for the quick responses! I'm surprised that this is not built-in but glad to know there's a work around, I'm going to give this a shot.
Posted: 04:46pm 20 Feb 2025
I'm not sure why you would want it TBH. While a program is running the console would usually only show error messages, which would often be fatal so the program wouldn't be running to process them. :)
Posted: 05:01pm 20 Feb 2025
  Mixtel90 said  I'm not sure why you would want it
some functions natively print their output without the option to capture it... I have found in the past on the 'mite platform that MEMORY had useful output
years ago that I had to find a way to capture the directory of a disc and it was only possible dipping into m/code... untill I used a tiddly routine to copy characters from the screen. Getting it as a string would have really made life simple.
programming 102 never dismiss a use case because you can't think of a use case. In my book, everything like this should output a string - you can print it if you want - PRINT USING is a *very* good case in point... the nicely formatted output is useful in dozens of theatres.
h
Edited 2025-02-21 03:08 by CaptainBoing
ebbandflow
Posted: 05:21pm 20 Feb 2025
...programming 102 never dismiss a use case because you can't think of a use case.
Posted: 05:52pm 20 Feb 2025
Just because *I* can't think of a use for it doesn't mean that there isn't one, I know that.
My saying that I can't think of a reason doesn't mean that I'm saying that there isn't a reason. The two are not equivalent. There is no dismissal. :)
Sometimes such information is given by the MM.INFO() commands in a far more usable form than having to parse a string to look for it. It's always worth checking them first.
ebbandflow
Posted: 06:35pm 20 Feb 2025
Unfortunately I need an exact copy of the data sent to the console and preferably in string form so I don't have to recreate the wheel. It's a little silly but hopefully connecting a few pins will work.
Posted: 06:44pm 20 Feb 2025
  Quote  link the Console Tx pin to the COM1 Rx pin then read it from there
Not applicable if using a USB console.
Why not just use print # to send to a file?
Posted: 06:46pm 20 Feb 2025
I'm intrigued....  :)
ebbandflow
Posted: 07:36pm 20 Feb 2025
Perhaps if I enable the console over both serial and USB?
  matherp said  Why not just use print # to send to a file?
I'm not sure if I understand what you're proposing exactly. Would this method send all console output to a file or only things explicitly printed to it? I.E. would it mirror the console's output to a file?
Posted: 10:17pm 20 Feb 2025
What are you expecting to see coming from the console that won't have originated in your program?
Posted: 10:49pm 20 Feb 2025
He mentioned the MEMORY command which only outputs to the console.
Something like the Pipe "|" operator to redirect such output is, I think, what he is after.
Posted: 08:15am 21 Feb 2025
It was the good Cap'n that mentioned MEMORY. In any event, by the time you detect an error when reading that it's likely to be a bit late to delete a load of variables to make more space. :)  We now have MM.INFO(HEAP) anyway, which is the only memory that matters.
Posted: 10:26am 21 Feb 2025
  Quote  Perhaps if I enable the console over both serial and USB?
Been playing with that.
OPTION SERIAL CONSOLE COM1,GP0,GP1,B
Dim s$
SetPin GP5, GP4, COM2 'link GP5 to GP0
Open "COM2:115200" As #2
Print "   Issuing MEMORY command"
Pause 9
s$ = Input$(255,#2) 'clear Rx buffer
s$ = ""
Memory
Pause 44
Print "                                  " 'add some paddimg
Print "Waiting for COM2 input"
s$ = Input$(200,#2)
Print @(0,280)"Received by COM2"
Print @(0,300)s$ :Print :Print
End
Output
Program:
  2K ( 1%) Program (84 lines)
178K (99%) Free
Saved Variables:
 16K (100%) Free
RAM:
  2K ( 0%) 12 Variables
  1K ( 0%) General
225K (100%) Free
Received by COM2
Program:
178K (99%) Free
Saved Variables:
 16K (100%) Free
RAM:
  1K ( 0%) General
225K (100%) Free
Edited 2025-02-21 20:47 by phil99
Footnote added 2025-02-22 21:32 by phil99
A minor refinement.
Dim s$
SetPin gp5, gp4, COM2 : Open "COM2:115200" As #2
Pause 9
s$ = Input$(255,#2) : s$ = "" 'clear Rx buffer
Memory
Pause 40
Print Space$(20) :Print :Print 'add some padding
s$ = Input$(200,#2)
Print "Received by COM2"
Print S$ :Print
Posted: 12:15pm 21 Feb 2025
well that works.
Not saying it is the best or only way, but it works well and nice to see it do so with the complications on the Pi console that Pete pointed out...  we have a solution, we just need a problem
An enjoyable canter
h
Edited 2025-02-21 22:20 by CaptainBoing
